LG Washer/Dryer Power Fail
  • lotas
    • Jan 2016
    • 4710
    • Russia
    #61
    Re: LG Washer/Dryer Power Fail
    Your module is faulty, it has three phases for powering the motor and two of its phases are broken, there is a short circuit on three IGBT transistors.
    • hugokernel
      • Nov 2023
      • 11
      • France
      #62
      Ok, thanks for the answer!
      I'll try to reconnect the washing machine without the motor driver to see if the machine turns on.
      • hugokernel
        • Nov 2023
        • 11
        • France
        #63
        I did a few tests earlier, put everything back in place (TOP246 and other components removed for testing) then plugged everything back in.
        Result: Nothing happens when I press the button on the machine (although I'm not really sure, perhaps a relay has been activated).
        In a nutshell:
        The initial problem was that the power resistor linked to the ignition burned immediately when the Power button was pressed.
        After removing the motor driver, it turned out to be short-circuited.
        I repeated the test without the driver fitted, and nothing happened.
        Maybe the TOP246 didn't really appreciate it and should be changed.
        What can you deduce from this?
        Thanks for your advice.
        • hugokernel
          • Nov 2023
          • 11
          • France
          #64
          Small update, I finally received the Mutsibishi PS21964-4S motor driver and proceeded with the change, I also changed the TOP246YN.
          A few solderings later, I reconnected the whole thing: it worked again, great joy, but after 24h of operation, the machine stopped during the end of a cycle (I suppose spinning/drying).
          After dismantling, the TOP246YN literally exploded.
          When I reassembled the TOP246, as I no longer had a thermal tab, I used a double thermal face for the connection between the TOP and the radiator, perhaps this was a bad idea.
          I've read the feedback about replacing the TOP246 with a TOP248 (with resistor in series), so I'm going to try that as well as using good thermal paste.​
            • 31159
            did you change the top related capacitors?
            and did you spin the blower by hand to check the bearings?
            i think i know the answer to both
            always start with the simple stuff - dont go breaking out thermal imagers or arduino's on the first try!
            • hugokernel
              • Nov 2023
              • 11
              • France
              #66
              Capacitors tested and ok.
              The big one (330uf) has an ESR of ~1Ω​.
              From what I've read, I would have done it if it was a dryer model, but it's just a wash version.
              I didn't change the brushless driver to play I did it because it was burnt out (thanks to lotas for the explanation).
                • 31159
                title said "washer/dryer" ??
                • hugokernel
                  • Nov 2023
                  • 11
                  • France
                  #68
                  Same board, same components, why can't I benefit from/exchange information?
                    • 31159
                    because it confuses people - you should have started a new thread.
                    • hugokernel
                      • Nov 2023
                      • 11
                      • France
                      #70
                      In this case, I was confused by the thread title, by "Washer/Dryer" I read Washer and/or/xor Dryer.
                      I picked up this thread along the way because it was the latter that helped me and the information was there.
                      I'll know next time, but thanks for the help.
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        Replaced emmc.
                        Terminal log
                        UART
                        AC_ON
                        E-B
                        FDE enabled
                        06-01-2025, 02:11 AM
                      • mariukonie
                        Bosch WDU28560GB/02 washer-dryer - time jumps, blocked door, codes E60 and -09
                        by mariukonie
                        Bosch WDU28560GB/02 washer-dryer. After selecting the spin program, the clock jumps from 0:13 immediately to 0:05 and counts down the minutes to zero. The pump turns on and the door locks, but nothing else happens, the drum doesn't spin. After the countdown ends, it does not open the door, it can only be opened by pulling the emergency handle next to the filter. No error is shown. When I select spinning and hold my finger in the lower left corner of the screen, after 5 seconds E60 and -09 are shown alternately. What could be the problem? Is it possible to turn on the service mode so that the washer-dryer...
                        12-04-2023, 04:01 PM
                      • CapLeaker
                        Bosch Nexxt 500 dryer blinking start button - no start fix
                        by CapLeaker
                        My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                        Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                        I like these easy evening fixes!
                        12-07-2023, 04:38 PM
                      • notallbad
                        Heat pump tumble dryer regas
                        by notallbad
                        Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                        The dryer currently in question runs on R134a.
                        The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                        I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                        07-16-2023, 01:27 PM
                      • Sam Scarbo
                        Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
                        by Sam Scarbo
                        I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
                        After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
                        I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
                        07-21-2024, 05:24 PM
