Electrolux Washingmachine ewf167320 will not heat water
  • Hagis2k
    • Jul 2006
    • 66
    Hi folks i been trying to help my mom a bit since her washing machine
    gave in a bit.
    What i have done so far:
    1. Checked resistance on the heating element, roughly 27 ohms so that equals to the 1950W or what it was. O/C to ground too.
    2. Also checked the ntc was close to 6.8kOhm
    3. Tested some programs all are halted as soon as it starts to heat the water and it displays "Err" in the display, realized that it works on centrifuge program only then it works (as it is not heating the water).
    4. (Today) i disconnected the heater and tried the 30min short washing program that went just fine, then i disconnected the earth to the element and reconnected
    the wires to the element thinking it might be leaking to earth and tried again. Sure machine stopped at 27min left to do the same.
    Some people said change heating element, but i want to use a megger on it to check if it leaks at higher voltages. I talked to the service company here in my town they said they only changed circuitboards on them which is kind of expensive lol not worth to pay $300 fo it.
    So my next plan is to take the circuitboard out and exam all solderjoints and see what happens.
    Anyone here that been troubleshooting about the same issue?
    (PNC) 91490483401 / Modell EWF167320W
  • petehall347
    • Jan 2015
    • 4427
    Re: Electrolux Washingmachine ewf167320 will not heat water
    does the element receive power ?
    is the thermostat working ?
    any error codes ?
    check triacs and relays .
      • 31063
      pull the element out and see if the casing has split.
      i was caught years ago by an element that metered good, pulled out and it was split and the windings had rusted.
      • Hagis2k
        • Jul 2006
        • 66
        Yes i forgot to say the element recieves power as it should.
        Shall remove it asap and see how it looks.
        I even took the pcb out of the machine did not really find any bad solderjoints but i re-did a few anyway do anyone know if the machine can sense if the element draws to much current?
          • 31063
          unlikely because the current will be higher when it's cold.
          do you have anything that can read leakage current?
          • petehall347
            • Jan 2015
            • 4427
            if power gets to heater it should heat up
              master hoarder
              • May 2008
              • 12175
              Perhaps check the relay or TRIAC that drives the heating element. It's possible that the control board may have a sense circuit to see if that relay/TRIAC has turned ON or stuck ON. Or if the relay/TRIAC are bad, maybe the drive circuit pulls too much current from the IC and causes it to shut down / error out.
              I'd fill the washer with water and then power it on manually with wires. See if there is any current leakage and how much. If none, I think you may want to look again at the control board.
              • llonen
                • Sep 2014
                • 495
                • hampshire
                Just replace the heater element and all will be good once again, you most likely have a high resistance earth leak on the heater element, you should be able to confirm this with a megger or high pot test of the heater input to the metal casing.
                • EasyGoing1
                  The best way to drive a heating element?
                  by EasyGoing1
                  I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                  What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                  This is the general setup that I have now.
                  This is what the...
                  01-25-2023, 11:29 AM
                • CuriousJohn
                  Burco boiler power problem
                  by CuriousJohn
                  Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                  Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                  This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                  12-22-2024, 10:25 AM
                  20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                  I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                  At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                  Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                  04-09-2023, 08:04 PM
                • bohaboha
                  Queen coffee CQ MN-2 Heating element
                  by bohaboha
                  How to test this queen coffee maker heating element...
                  07-18-2022, 09:01 PM
                • notallbad
                  Indesit IDC75 condenser dryer not stopping
                  by notallbad
                  I have an indesit IDC75 condenser tumble dryer and everything appears to be working ok
                  press start button and it starts spinning
                  does it reverse tumble at periodic intervals
                  heats up ok (heat switch toggles between high and low heat and working ok)
                  timer switch rotates as time passes by
                  However, there is one issue, it does not switch off when the timer goes back to "0', or 'off' if you like. Just keeps going. It will only stop if the door is opened, then closing the door requires the 'start' button to be pressed again to get it started.
                  I...
                  01-11-2023, 02:56 PM
