Microwave Front Panel Repair - MayTag MMV4203DW00
  • caphair
    • Nov 2011
    • 1249
    Yesterday the display started showing --SE--
    Looked it up and from the MayTag site it says this means there's a short on the touch panel.
    Opened it up and measured a short across diode D109. Removed it, diode tested fine out of circuit. Following its path there's a zener diode and a capacitor C110. Removed capacitor, tested fine out of circuit. Zener diode measures good in diode mode (not sure if this is an accurate test for zeners). With both C110 and D109 removed I can still measure a short across the empty holes.
    Followed + side of the capacitor C110 and it goes to the top (in picture) of the display and there's a burnt mark. Would this be what's shorted? Don't have any experiences with how these displays work. Wasn't aware they themselves could go bad. Is it a vacuum fluorescent display (VFD)? It's a hassle to remove to confirm short is gone
    Re: Microwave Front Panel Repair - MayTag MMV4203DW00
    When you said shorts, what is the exact resistance reading?
    How about the straight pictures of the top and bottom of the board and the location of the so called shorts?
    • caphair
      • Nov 2011
      • 1249
      4.7ohms. Here are some more pics
      • R_J
        • 9607
        Check this site out and read post by Kean http://appliancejunk.com/forums/index.php?topic=12215.0
        It seems to be a problem with the touch pad/ribbon cable not the control panel
        I will take a guess at the 4.7 ohms resistance and bet its for the display heater. The display/micro etc. is working, if it was not you would not see the error on the vfd.
        • caphair
          • Nov 2011
          • 1249
          Awesome thanks! That fixed it. Had to separate the ribbon cable where it folds onto itself with some electrical tape just as the post you linked to says.
          Yeah I figured the 4.7ohms was for the heater. Wasn't sure how they worked but got a lesson out of it. Thanks again.
          Do you know how this fix was discovered? I bet many people have ordered replacement boards only to encounter same issue again
          • asr
            Finding replacement diode iPad Pro 3rd gen A1701
            by asr
            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
            07-09-2024, 06:24 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
          • Baste
            MBR3045CT and SR3045LCT Schottky diode testing help.
            by Baste
            Hello experts,
            Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
            Aneng ST182 Meter.
            Diode mode.
            MBR3045CT:
            Diode mode
            Pin 2-1 - 0.150v
            Pin 2-3 - 0.150v ...
            10-21-2025, 06:14 AM
          • NicRac
            monowheel repair,Is the diode the problem?
            by NicRac
            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
            First of all, I am new here. Therefore I will shortly introduce myself.
            I am Nico and currently I study Physics.
            In my freetime I like to build and repair stuff. Especially big battery's.
            A few years ago I got myself an electric unicycle, monowheel or however you call that.
            The battery bms was broken so I replaced and resolder that. Nothing big.
            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
            07-26-2024, 06:13 AM
          • dennis_elx33
            NO BODY MARKING Diode
            by dennis_elx33
            Hello Everyone,
            I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
            While compared to the reading of another diode from the next channel it won't read at reverse bias.
            Now the problem is; it does not have any body marking.
            So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
            What do you think is this diode?
            Can you please suggest what part number can i use to replace this faulty diode instead?
            Hoping that you...
            06-14-2024, 12:36 AM
