Hotpoint FFA47X Fridge Freezer
    • 31253
    Re: Hotpoint FFA47X Fridge Freezer
    acs108-8sn
    (datasheet page 11)
    the 8 is the maximum voltage - higher is better.
    the sn is the package shape
    and
    acs120-7sb
    again, 7 is the max voltage and sb is the package shape
    i'v never seen these before, so i cant answer the last question.
    they are interesting though, cpu controlled mains switching with no extra parts - i can make some interesting stuff with these!
    • clearchris
      • Dec 2013
      • 687
      Ok, if your compressor isnt kicking on, I start with this test.
      Unplug the fridge for an hour or so. This allows the compressor to cool off from a possibly overheat condition. Plug it in, and listen. If the compressor tries to turn on but fails, sometimes a few times in succession, the start cap on the compressor is bad. Otherwise, its something else, but in my experience, over 50% of compressor failures are due to the start cap failing.
      Edit: btw, if you unplug the fridge, leave unplugged for at least 5 mins. The gas pressures need to equalize so you arent attempting to start the compressor when the gas is already at a high pressure.
      • Rhothgar
        • May 2015
        • 109
        #83
        Thanks stj.
        I'll get some ordered in. Bet I can't buy singles though.
        It is now because when I used a jumper wire across the defrost gutter resistor terminals, it blew the main board.
        What I can't understand though is if a wire is in there simply to heat up and keep ice at bay using a certain resistance, why would another wire blow the PCB? It conducts!
        I have obviously have a lot to learn and some things I will never understand.
        Does everyone on here get the feeling I shouldn't mess with electrics?
        My missus is moaning now that I am trying to fix it!!!
        • clearchris
          • Dec 2013
          • 687
          Sounds to me like you put some high voltage where it didnt belong. Yes, things conduct, but all things will burn if they are made to take too much current.
          Also, if you jumped across where the heaters plug in, well, that circuit needs a load (the heatoror the current shoots way high and you see what happened. What you did is create a short, a path of low resistance that is not able to carry a higher current without burning.
          Can anyone explain that better?
            • 31253
            Originally posted by Rhothgar
            Thanks stj.
            the heater wire has a high resistance an draws less current than your copper jump.
            if you wanted to see if it was getting power, you should connect a neon with inline resistor to the terminals.
            you can scavange those from old kettles, boiler switches ec.
              • Jul 2011
              • 6070
              When you have a controller board on any type machine the worst thing you can do is apply power other than the power in to the board unless you know what it powering
              Most of the time when you want to see if a part works or not unplug what you want to test
              • Rhothgar
                • May 2015
                • 109
                #87
                Originally posted by stj
                i wonder why it has a reed-switch?
                I have a manual for another Hotpoint with a similar-ish layout in front of me. Just 'reeding' through it. Excuse the pun!
                It is located such that a magnet in the fridge door closes the reed switch when closed.
                  • 31253
                  so the cpu controls the internal lights?
                  or does it just give a short boost to make up for the door being open?
                  • Rhothgar
                    • May 2015
                    • 109
                    #89
                    I'll pass on that as I have no idea.
                    Maybe the reed switch is there to communicate with the EEPROM when the door has been open for 2 minutes and to set the beeper off to alert the user to door being open.
                    • Rhothgar
                      • May 2015
                      • 109
                      #90
                      Finally I have the service manual arriving for this tomorrow.
                      I have sourced the triacs and will be ready to resurrect this hopefully this week before the missus gets back off holiday.
                      Quick question. I took one of the fans out last night and it was too hot to touch. I had switched the unit on earlier in the day as the evaporator is still working and the freezer gets cold.
                      The fan has two wires and is a type F64-10 with MES Swiss made on it.
                      Is it safe to simply connect it to a live and neutral to see if the fan spins and would it matter, for testing purposes, which way the live and neutral are?
                      Presumably it will just run backwards?
                        • 31253
                        have you got any foto's of the fan?
                        does the label state the voltage?
                        • Rhothgar
                          • May 2015
                          • 109
                          #92
                          Sorry. It is 220-240V
                          I do have a photo.
                            • 31253
                            you can hook it to the mains for a test - watch your fingers with mains fans as they have high-torque.
                            • Rhothgar
                              • May 2015
                              • 109
                              #94
                              Noted. But does it matter which way? That is my concern. I cannot afford to buy a replacement if I damage it. Chances are it's burnt out anyway because it felt so hot but...
                                • 31253
                                no polarity, it's an ac fan.
                                it will get hot, look at the design.
                                you have a constantly powered coil on a core that goes around the motor shaft.
                                i imagine it uses the flow from the fan across the coil to stop it melting down.
                                • Rhothgar
                                  • May 2015
                                  • 109
                                  #96
                                  Thanks for clarifying.
                                  Problem is you remember I vapourised the main board? Well. The fan isn't turning.
                                  Once I repair board this week, I can then start diagnosis of other components.
                                  Someone kindly suggest I use a jumper wire for bridging the points on the vapourised copper track.
                                  Will any copper wire do with insulation? Like a multi strand wire say 1.0mm diameter?
                                    • 31253
                                    solid will be better for keeping shape.
                                    • Rhothgar
                                      • May 2015
                                      • 109
                                      #98
                                      Could I use a strand of solder? It's unlikely to reach high enough temp to melt!
                                        • 31253
                                        NO
                                        anyway, how would you solder it?
                                        strip some stranded wire, twist it and tin it
                                        • Rhothgar
                                          • May 2015
                                          • 109
                                          #100
                                          NO
                                          Might try that stj.
                                          I am nipping into local RS Components tomorrow to pick up triacs. What should I be asking for if I want something like this off the shelf?
                                          • CG2
                                            Liebherr Fridge Freezer KGT 3456 not working
                                            by CG2
                                            To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                            01-25-2023, 02:12 PM
                                          • mikey5791
                                            Help repair Panasonic fridge not cooling
                                            by mikey5791
                                            Hi all forum members,
                                            Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                            After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                            07-16-2025, 02:01 AM
                                          • tmcw
                                            Fridge - Gram
                                            by tmcw
                                            Have this fridge, laboratory grade unit, not working fully.
                                            It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
                                            The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
                                            10-10-2023, 05:00 AM
                                          • unimatrix93
                                            Replacement transformer for Samsung fridge
                                            by unimatrix93
                                            Dear forum
                                            My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                            No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                            The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                            My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                            07-14-2025, 02:16 AM
                                          • lapfix
                                            Dell latitude 5320 South peak 13 not power on.
                                            by lapfix
                                            Hello friends
                                            Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
                                            motherboard south peak 13 mb 213252-1
                                            i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
                                            i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
                                            As i undestand from many topic here ,...
                                            04-29-2025, 06:22 AM
