philips ep2231 40 Q1 U7
  • samtron786
    • Aug 2016
    • 170
    • germany
    Which MOSFET do I have here? Is it an N-channel or a P-channel?
    I have two defective ICs, Q1 and U7. What are the names of these components?
    Thank you.​
  • CapLeaker
    Leaking Member
    • 8263
    Q1 I read as marking 3G- = PNP transisor BC857C
    That’s not a mosfet
    • samtron786
      • Aug 2016
      • 170
      • germany
      I've done a lot of Google searching
      there are two either/or options for this IC.
      • samtron786
        • Aug 2016
        • 170
        • germany
        Before
        After turning on the coffee maker, it immediately rinses, and the water flows into the tray. Then the indicator lights for no water, coffee grounds, and the triangle start flashing simultaneously.
        ich frage mich
        was ist das jetzt U7
        • CapLeaker
          Leaking Member
          • 8263
          Dunno. I think you got to take U7 out and see if it behaves like a MOSFET. If it is a MOSFET, it isn’t shorted and you can turn it on and off with your DMM in diode mode, it is o.k. Yours doesn’t look blown, so it should work.
          • lotas
            • Jan 2016
            • 4685
            • Russia
            U7 = CEW = TL431AIDBZR
            • samtron786
              • Aug 2016
              • 170
              • germany
              Thank you very much
              I found something on eBay, I'll order it
              https://www.ebay.com/itm/305688443074
              OK, CapLeaker
              I'll get it out, I'll get back to you
              Thank you very much
              • CapLeaker
                Leaking Member
                • 8263
                I also came up with the CEW may be a TL431, but the other options didn’t provide a cross match. So testing it is. Are you sure this circuit isn’t working?
                • lotas
                  • Jan 2016
                  • 4685
                  • Russia
                  The optocoupler could also be damaged.
                  • samtron786
                    • Aug 2016
                    • 170
                    • germany
                    Hello everyone
                    1. BASE
                    2. EMITTER
                    3. COLLECTOR
                    I have no control with the black cable.
                    With the red cable, the BASE and EMITTER have no control.
                    One number: 707 EMITTER and COLLECTOR.
                    I've removed the part.
                    Thank you very much.
                    • samtron786
                      • Aug 2016
                      • 170
                      • germany
                      I found part 431AR.
                      Is it the same, right?
                      • lotas
                        • Jan 2016
                        • 4685
                        • Russia
                        Originally posted by samtron786
                        I found part 431AR.
                        Yes, it's the same thing (different manufacturers), just look at the pinout, it may be different for them.
                        • samtron786
                          • Aug 2016
                          • 170
                          • germany
                          Hello, I've searched a lot, but how can I search for the REF with m m?
                          Thank you very much
                          • lotas
                            • Jan 2016
                            • 4685
                            • Russia
                            Thank you very much
                            TL431
                            • lotas
                              • Jan 2016
                              • 4685
                              • Russia
                              It is also better to replace the optocoupler IS01 (817), after the breakdown of TL431...
                              • samtron786
                                • Aug 2016
                                • 170
                                • germany
                                Thank you again, I also intend to do this, it is not a problem, but I would like to first Q1 and U7 then optocoupler
                                • lotas
                                  • Jan 2016
                                  • 4685
                                  • Russia
                                  Ok, if your ordered TL431 does not correspond to the standard pinout, then just turn it upside down, carefully lower the leads down and solder it and everything will work.
                                  • Jane
                                    How do you test MOSFET in laptops ?
                                    by Jane
                                    I tried to use this method:
                                    Testing an N-channel MOSFET:
                                    Step 1: Discharge the Gate (turn off the MOSFET)
                                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                    Step 2: Charge the Gate (turn on the MOSFET)
                                    Now, place the red probe on the Gate (G) and the black probe on the
                                    09-27-2024, 03:31 AM
                                  • Nooy
                                    VGA MOSfet permanently shorted and loss of MOSfet pad
                                    by Nooy
                                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                    02-14-2024, 02:26 AM
                                  • AppleLover123
                                    Asus X712EA 3 volts after the first mosfet
                                    by AppleLover123
                                    Hey guys,
                                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                    Now i thought something...
                                    12-15-2024, 07:49 AM
                                  • MicroSMD Lab
                                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                                    by MicroSMD Lab
                                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                    01-10-2024, 06:36 AM
                                  • Scotchmist
                                    Asus GA502D keeps blowing mosfet
                                    by Scotchmist
                                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                    I have removed the mosfet and can run the laptop no problem
                                    The MOSFET is FDPC5018SG
                                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                    08-24-2024, 02:23 PM
