candy tumble dryer (evoc 981 at-s) Component 738
  • Petros_Z
    • Oct 2022
    • 8
    • Greece
    Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
    It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
    Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and manage to measure 5.6Kohms on each of them. I had the same measurement no matter how I put the probes. I am not sure if I did a diode test.
    Anyway, have anyone see a component that looks like a smd resistor and has 738 marking on it? What I could be? I don't think that 738 is the value of the resistor because 738 = 7.3Gomhs witch I think is too much for smd.
    Sorry for my bad English. If you need photos I will try to do my best.
  • truclacicr
    • Apr 2019
    • 343
    • australia
    Photos would be good.
    • Petros_Z
      • Oct 2022
      • 8
      • Greece
      Here you are.
      Update. I managed to destroy another one 738!!
      I have replaced the two broken 738 with 5.6kohm resistors. All of them are marked with red circle.
      Please don't judge the mess on the board. I had only a 40w solder iron with a fat tip. The rest are remains of paper towel.
      If more photos are needed I will try again.​
      • R_J
        • 9588
        Thats not 738 it is likely 73B which is a 5.62kΩ 1% EIA-96 Series Resistors
        • Petros_Z
          • Oct 2022
          • 8
          • Greece
          LoL
          I must be blind…
          I think 562 I used as replacements will be good enough.
          If yes, then I have to find out why I have a drop voltage (witch I think is not right) on ntcs.
          Thanks!
          • notallbad
            Heat pump tumble dryer regas
            by notallbad
            Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
            The dryer currently in question runs on R134a.
            The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
            I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
            07-16-2023, 01:27 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • spleenharvester
            Beko Tumble Dryer DTLCE80021W cutting out/tripping RCD
            by spleenharvester
            This dryer is several years old and has previously had a new motor cap. Currently it's behaving erratically - sometimes it finishes the cycle fine, other times it cuts out after a random period of time (just stops with no LEDs as if it has finished normally), and occasionally it trips the RCD. There's always steam coming off the clothes at the time it cuts out.
            Going to pull it apart tomorrow, before I lob a new heating element at it is there anything else worth checking? It's £70 for a new heating element and the whole machine only cost £180 to begin with...
            Cheers
            12-16-2024, 03:36 PM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
