Kenmore 790.74133311 gas range control board 316630005
  • CapLeaker
    Leaking Member
    • 8340
    Got a Kenmore Kenmore 790.74133311gas range with a control board 316630005 which has a blown PWM. Anybody has an idea what that chip is?
  • CapLeaker
    Leaking Member
    • 8340
    Maybe a VIPER26L 7DIP?
    • R_J
      • 9607
      Looks like VIPER16L
      • CapLeaker
        Leaking Member
        • 8340
        Originally posted by R_J
        Looks like VIPER16L
        Perfect R_J! That's just with what I came up to as well, since I can see part of the 1 on the 16L on my picture.
          • Jul 2011
          • 6070
          Were you able to get it working again
          • CapLeaker
            Leaking Member
            • 8340
            Crap, forgot about it to update! Yes! Board works A1!
              • Jul 2011
              • 6070
              Did you put a heat sink on top of Viper chip to keep it cooler
              • CapLeaker
                Leaking Member
                • 8340
                Nope. Old Viper out, new Viper in, cleanup, install and Bob is my uncle. I think it died due some lightning event.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Yanleb
                  LG 60PK550 Logic Control Board EBR63450301
                  by Yanleb
                  Hi all, I just want to share the repair of my 60PK550-UA TV set.
                  The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                  But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                  All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                  C57: 3.30V
                  C61:...
                  07-20-2023, 12:38 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • redoxy
                  Control Board Replacement for 2K display
                  by redoxy
                  I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
                  The display is Samsung LTM270DL07.
                  I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
                  I am looking for inputs on what board could potentially be used for my display.
                  Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
                  Also attached is a technical...
                  03-14-2023, 08:52 PM
                • bryanX
                  Control board for treadmill Horizon Omega II
                  by bryanX
                  Hi guys!
                  Firstly, I will apologize if my topic is in the wrong section, please move it if necessary.
                  I want to repair one treadmill from the brand Horizon the model is Omega II. Practically, the motor power control board has suffered one damage.One mosfet has blown and I suppose by doing that, the short circuit has damaged a couple of diodes, one zener diode and two transistors. I hope that is all. I will find out when I will put them all back on board. I have dismantled and cleaned the rotor of the DC motor, tested it, and it seems to be working properly. I suppose it was water...
                  03-05-2024, 01:11 PM
