Bosch serie 6 E:60 -9 and drum not spinning
  • JakubM
    • Nov 2024
    • 3
    • Slovakia
    Hello everyone, I'm troubleshooting our malfunctioning Bosch serie 6 washing machine and can't find many answers online (or ones that I can make sense of). At first it started showing error E:60 -9 and would not start a program. After several restarts it's no longer showing the error codes, but when I start any program (drum cleaning for example) it fills the water in but the drum doesn't start spinning. I couldn't find any physical obstruction, but turning the drum by hand I feel resistance. I tried opening it up, trying to inspect the motor brushes. This model either has a different motor that I saw in videos, or doesn't use brushes. BUT I noticed the drum resistance stops when I unplug this blue connector from the motor (see photo).
    Is there a way for me - an average non-technician without any specialized tools to fix this? Or do I just bite the bullet and call a technician? Thank you for your time and insight!
  • CapLeaker
    Leaking Member
    • 8196
    That error has something to do with either the motor, the wiring or the motor driver board. You need a DMM and tools... and be able to take the driver board out.
    I think the problem is the motor driver board and there is a large STK something in there, which probably is faulty. If this is the case you need a soldering station too.
    • JakubM
      • Nov 2024
      • 3
      • Slovakia
      Thanks CapLeaker! That doesn't sound like something I'd be able to do on my own. At least not without some detailed guide - any chance something like that exists? Or how to look for ways of diagnosing/fixing it?
      • CapLeaker
        Leaking Member
        • 8196
        If it is the motor control board, you should be able to buy the whole board and swap it out. However to confirm my suspicion, you need to take that motor control board out and do some measurements on the motor driver IC itself. If that is bad, replace the board or replace the motor drive IC yourself or a friend that knows how to handle electronics on the old board.
        Plus there is always YouTube that can show you on how to take the washer apart. Tricky thing is getting it back together. Take pictures each step when you are talking it part, so you know where the wires and plugs, screws etc went.
        Sounds daunting, but only half as bad once you see one being taken apart plus you taking picture along the way…
        You do need basic tools and a multimeter, there is no getting around this requirement.
        Here is a picture of what a motor control board looks like. This NOT your control board, just something for you to look at. Underneath that heatsink is that STK with some numbers and the tons of little legs. That is the IC to test.
        • S1KR24
          • Aug 2025
          • Hi
            I'm in Australia and have a similar problem to yours. Did you resolve it?
            My machine seems to fill and drain but is not spinning. There is resistance when trying to turn the drum by hand. If I run a spin cycle it drains, immediately jumps from 10min to 2min, makes some noises then eventually alarms for the end of the cycle.
            It did not produce any error codes until I tried the "test mode", when it came up with "E60-09". Which Google says is a comms issue with a connectivity board, but my machine WAU28490AU/2 does not have connectivity.
          • I had planned to replace the carbon brushes, until I found that it is a brushless motor. It has a 10y parts only warranty on the motor, but the service fee for a technician to diagnose that is $200 for callout & 30min labour, then $120/hr after that. Then presumably to install the new motor will incur the same costs. The motor itself is $261 directly from Bosch, so I thought it might be worth a try first.
            I'm just about to open it up and check it out with a multimeter.
            Please let me know how you went with your machine.
            Cheers
          • DanielCoffey
            Bosch GRA53 36V Lawnmower - no motor
            by DanielCoffey
            Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
            I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
            The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
            08-06-2023, 12:40 PM
          • lcdcaps1
            Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
            by lcdcaps1
            Hi
            I have a Panasonic SAPM-31 mini hifi and the tape deck motor keeps spinning all the time
            If I just connect the ribbon cable to PCB That is connected to the motor, it spins continuously
            If I change the input it still spins
            I have put it all back together with all the belts in place and still
            I can play, forward and rewind but the motor never stops when I press stop
            This never used to happen so I am not sure if a transistor has failed or a diode
            I will really appreciate the help from this forum
            Thanks all
            04-11-2022, 01:53 PM
          • juergenb
            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
            by juergenb
            i am asking for some Help.
            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
            So i got a few of these from Banggood.
            I swapped the motor and now i have a new fault condition.
            In a working Frother you would press the start button, it will light red and work for a few minutes.
            If you press longer it will light blue and just mixup the milk.
            With the new Motor it just starts...
            03-23-2021, 11:24 AM
          • sbt123
            charnwood w821 mini wood lathe motor problem
            by sbt123
            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
            10-27-2024, 03:43 AM
          • Petr0x
            Bosch 12V and 18V chargers modification
            by Petr0x
            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
            05-24-2024, 01:00 PM
