Maytag MAV6200AWW washer suddenly not responsive
  • Curious808
    • May 2022
    • 39
    Old machine, but was working fine. Was partially filled when water supply had to be turned off. When water went back on, it resumed filling. Someone accidentally knocked the lid and it slammed down. Machine stopped. Now nothing works. Opened up the control console on top, and could see the cycle start switch that's pushed in by a pin on the lid when the lid is closed seems to be moving in and out OK. Pressing the different water level buttons, can hear a click. The big knob for setting cycle and push-pulling for on or off does nothing.
    Any ideas of how to check further? Is it likely a goner, easier to replace than repair? Thanks!
  • ron350
    • Feb 2014
    • 296
    Could the lid switch have broken when the lid slammed down.
    Whirlpool WP22003804 Switch-Lid (AP6024324) - AppliancePartsPros.com
    https://www.appliancepartspros.com/w...ap6006310.html
      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
      by sam_sam_sam
      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
      04-09-2023, 08:04 PM
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      08-28-2025, 01:09 PM
    • edugimeno
      Stagg sms12p audio amp has water damage
      by edugimeno
      Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
      I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
      There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
      There is only one signal wire connecting the first boards...
      05-24-2025, 06:00 AM
    • Joe24
      Maytag Whirlpool Kenmore clothes dryer data bus
      by Joe24
      Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
      Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
      I've been over the board looking for...
      01-13-2025, 06:50 PM
    • RetroComputingGrotto
      Water Damaged Toshiba 48L1435DB
      by RetroComputingGrotto
      I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
      The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
      10-07-2024, 08:23 AM
