Electrolux EWT904 (Simpson brand) - Top Loader Washing Machine
  • Wodger
    • Oct 2023
    • 23
    • Philippines
    Hi Everyone,
    I'm looking for a circuit diagram layout for the power board on this machine, so I can attempt to troubleshoot, As per the sicker on the back:
    SIMPSON/Electrolux
    W2104A-V06
    I've repaired and replaced this board once but now I have 2 dead powerboards. Usually the capacitors blow on this design, but recently I found no problems with the capacitors and finally found the offline switcher (LNK306PN) had burned. On replacement, one board worked for a while but now is dead again (no beep when powered up from wall supply), and the other older board didn't work even when the offline switcher that looked damaged was replaced.
    Thanks for your time.
    Pete
  • CapLeaker
    Leaking Member
    • 8196
    Post some high resolution, straight shot pictures front and back of the board. Let’s see what we are dealing with here.
    • Wodger
      • Oct 2023
      • 23
      • Philippines
      Good day,
      Thanks for responding. Attached are pictures of the board. I'm without power at the moment for another 6 hours and lighting and board design doesn't lend well to pictures (circuitboard is encased in a clear rubberized silicone material which makes repair of this board a headache). I have done top and bottom and then front and both sides.
      From my investigation, the ptc resistor on the ac incoming line gets really hot to touch within 20 seconds of power applied.
      The machine was functioning normally during a cycle then after draining was about to spin when the supply went dead. Found the 2nd inline 4.7uf cap furthest from ac-in bulged, but replaced both - no change.
      Thanks,
      Pete
      • CapLeaker
        Leaking Member
        • 8196
        revisit the switcher bottom make sure it isn't dead and clean in between the pins. Joining the top 2 pins on each side is ok. Caps can look brand new, but yet be bad. Maybe wanna check all of them. If you get power from the switcher, but nothing on the motor drive, check out the SCR's, check the blue caps and make sure the resistors are within tolerance. There is another device between the SCRs and the little cap. What is that?
        • Wodger
          • Oct 2023
          • 23
          • Philippines
          Cheers for the advice - I will get back on this probably tomorrow night if I get energy (troubleshooting a Kia that is now refusing to start). Regarding your question what device is there, I assume your looking at the arrowed area on attached pic? - Diodes - I will of course make sure they are working properly.
          I will advise of my findings.
          Pete
          • CapLeaker
            Leaking Member
            • 8196
            I did some mark ups for you. I can clearly see one SCR on a heat sink. Also something needs to drive the gate of the SCR. Caps near a heat sink are always suspect too. Check the diodes, the resistor. To get the best reading take it out of circuit or lift one leg.
            • Wodger
              • Oct 2023
              • 23
              • Philippines
              Hi mate,
              Thanks for that😊I was just about to head out to do the jobs for the day. Attached is a closeup picture looking from the right side of your markup picture showing the part number of the question marked part. Hopefully, I have energy later to look at this as the laundry is building up.😂
              Pete
              • CapLeaker
                Leaking Member
                • 8196
                Originally posted by Wodger
                Hi mate,
                Pete
                That 7905 is a negative 5v regulator (-5V) also worth checking out.
                • Wodger
                  • Oct 2023
                  • 23
                  • Philippines
                  So I unsoldered the parts you circled plus the switcher (it made it so much easier to remove the silicone gunk from the board). And cleaned the board up as best as I could.
                  I tested the small smd resistors and capacitors on the back to the ac line 2 for continuity on either side and all but a couple sounded on connected side only (the remaining ones didn't sound at all) - I also tested the chunky smd diode and that appears working normally (first time I have seen a 2nd band on a diode casing - I'm not deep electronics specialist - trained in marine engineering).
                  Short stop for refreshments then will check removed parts.
                  Pete
                  • Wodger
                    • Oct 2023
                    • 23
                    • Philippines
                    Pete
                    So after removing the remaining 0.1uf capacitor / varistor / PTC on the ac line, found the PTC actually has "leaked" so I'm pretty confident that's dead, the yellow 0.1uf capacitor also appears dead giving open circuit on terminals, also dead is 470uf and 100uf electrolytic capacitors which don't appear to charge and remain shorted (going by analog multimeter). The varistors are a puzzle, I should have some sort of reading, but I get nothing from any of them.
                    The rest of the parts appear fine (checked SCR's, the 5V regulator, diodes, the voltage switcher and resistor).
                    I'm waiting on an answer for replacement parts (varistor and PTC are proving to be hard to find where I am located)
                    Pete
                    • CapLeaker
                      Leaking Member
                      • 8196
                      Pete
                      Open circuit reading on the square 0.1uF cap is normal, Other than that, you are well on your way. Hopefully you didn't miss anything, so better double check.
                      • Wodger
                        • Oct 2023
                        • 23
                        • Philippines
                        Thats good to know, one less purchase. the varistors though, from what I've seen online, I should have some sort of reading with a multimeter, but I have nothing, not even a short.
                        Regarding the board, everything on the hot side has been removed and checked save for the 2 inductors (I'll check on them first thing tomorrow).
                        Pete
                        • CapLeaker
                          Leaking Member
                          • 8196
                          The Varistor or MOV shour read open. If it has a reading its degraded already. The MOV can only take a finite amount of hits, each time degrading it more.
                          • Soulzink
                            Samsug washing machine. Power supply DC41-00189a board issue
                            by Soulzink
                            I am trying to fix a samsung washinmachine power supply main board.
                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                            The power supply board reference is the following: DC41-00189a
                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                            04-19-2025, 06:26 AM
                          • mojos911
                            ASko washing machine User interface Display
                            by mojos911
                            I got a Asko washing machine that has had the flat ribbin cable sustain damage from some corrosion. I have tried to repair it but the ribbon cant sustain the repair and keep breaking. I was trying to source a new LED display but I cant figure out how to try and source one. the information on the back of the display is 13669-LED-A-A173-161007-RoHs. Its also a negative display witha 17v supply for the LED back light and the connectors are 26 pin x 2. What do i have to provide to try and source one of these?...
                            02-02-2025, 05:03 AM
                          • mojos911
                            Fisher and Paykel 10 kg top-load washing machine LED identification
                            by mojos911
                            I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
                            If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
                            01-17-2025, 06:54 PM
                          • stomanata
                            No spin on washing machine AEG L6FBA674
                            by stomanata
                            This washing machine has power module emc18aecn1 and programmer ewx14931 914913208.
                            It stop after electric shock.
                            When i choose only spin it show 12min remaining. After 1min it start drain pump, after
                            second it start relay (measured 12v ot relay`s coil) that deliver 230V to power module.
                            This is also ~1second and then pump and relay stop. After ~2min this repeat - pump,
                            after it relay and both stop.
                            There is no error.
                            Can somebody help me to try to fix it?
                            08-11-2024, 10:39 AM
                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 03:28 PM
