No spin on washing machine AEG L6FBA674
  • stomanata
    • Apr 2016
    • 82
    This washing machine has power module emc18aecn1 and programmer ewx14931 914913208.
    It stop after electric shock.
    When i choose only spin it show 12min remaining. After 1min it start drain pump, after
    second it start relay (measured 12v ot relay`s coil) that deliver 230V to power module.
    This is also ~1second and then pump and relay stop. After ~2min this repeat - pump,
    after it relay and both stop.
    There is no error.
    Can somebody help me to try to fix it?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Did you check the motor? Been known for the no spin cycle problem the brushes getting stuck or worn out and or the magnet is bad / broken that sits on the shaft.
    • petehall347
      • Jan 2015
      • 4448
      there is normally a service mode to test each thing .
      check pressure sensor pipe . also check the pump filter and if the pump is free to turn .
      what do you mean by electric shock. ?
      • stomanata
        • Apr 2016
        • 82
        Thanks for reply.
        Motor is welling yxt320-2e(l) - so it is without brushes. May be i can just
        check resistance between every wire.
        Washing machine was working excellent and stop after
        electric shock - this is overvoltage or undervoltage for short time.
        In most cases this is overvoltage and this is danger for electronics.
        • stomanata
          • Apr 2016
          • 82
          Anybody to know how can i reset this machine?
          I check a lot of clips in Youtube but all of them has
          different look - display and buttons. It is Lavamat 6000 prosense
          • petehall347
            • Jan 2015
            • 4448
            see if this helps .
            https://www.youtube.com/watch?v=V2OqiQFVnkc
            • stomanata
              • Apr 2016
              • 82
              Thank you. I saw clip like this, but today i prefer to test even that display
              is different than my.
              It goes in some kind of service mode and show me E57.
              As i read this is problem in inverter. Error meaning is "too high current at motor"
              Try again to press both buttons to clear code, but no luck - it stay at E57
              • petehall347
                • Jan 2015
                • 4448
                is the drum free to turn ?
                • stomanata
                  • Apr 2016
                  • 82
                  Yes. Washing machine was in very good condition until electric shock (overvoltage).
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8351
                    Try selecting a wash program and see if the drum turns. If not give the motor some help by spinning the drum with your hand. If it keeps spinning after you helped it, it's the motor control board. You could be in for a motor, a motor control board, or both. Also look at the Electrolux service manual. Probably not the same, but should give you an idea.
                    Last edited by CapLeaker; 08-12-2024, 08:03 PM. Reason: Added service manual from Electrolux
                    • stomanata
                      • Apr 2016
                      • 82
                      No luck with helping the drum. Now i have only E57 - may be motor current over 15A (as read over internet).
                      I delete it, it display E00, but again no start.
                      Motor is Welling YXT320-2E(L) and it has only 4 wire socket. This 4 wires came from inverter. 1 wire is connected
                      to motor ground and other 3 wires (3-phases) goes to the motor. Even i did not see tacho.
                      Between 3 wires i have 7.2-8ohm resistance, and no resistance to ground.
                      So may be it is inverter problem/fault...
                      • R_J
                        • Jun 2012
                        • 9623
                        The fault is likely with the motor driver ic on the inverter board, this will be a 3-phase motor driver, from other pictures it looks like the ic would need to be removed from the circuit board to see any numbers, it may be that the vcc voltages for the other ic's on that board may be missing.
                        • stomanata
                          • Apr 2016
                          • 82
                          Thanks. Do you mean biggest IC - may be that produce 3 phases?
                          On top board i have choke, bridge, capacitor and 1 small IC. So there i have 310V= and 16V=.
                          On other PCB there is 1 big IC and other. I try to check all smd transistor and they are OK.
                          May be when i see biggest IC number i can find option to test it...
                          • stomanata
                            • Apr 2016
                            • 82
                            biggest IC is GIF5CH60TS-X. Over internet most sites offer GIF5CH60TS-L.
                            Do you know can i check it if i apply only 230V~ on inverter, without programmer
                            and to measure some voltages or other?
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8351
                              Here is the spec sheet of the driver IC. Read it and pay attention to the fault management, The output to the motor starts here and the over current problem is between this IC and the motor itself. Also notice that there is a NTC involved, Probe around and maybe you A find a short or B its going into some sort of protection mode for one reason or other.
                              • stomanata
                                • Apr 2016
                                • 82
                                Thank you.
                                I desolder gif5ch60ts-x and start to measure and found
                                short circiut between #20 and #23. I hope that this is
                                whole problem.
                                #18, #19 and #20 on PCB are grounded and #23 I
                                third phase output to motor.
                                Btw over internet I found gif5ch60ts-L instead gif5ch60ts-x.
                                In datasheet is not labaled what is the meaning of every
                                letter, but I hope that they are the same.​
                                • redwire
                                  • Dec 2010
                                  • 3912
                                  It's good you found something wrong, the shorted IGBT.
                                  "L" is long leads. Difference between STGIF5CH60TS-X and STGIF5CH60TS-L, that I find is the length of the pins:
                                  SDIP2F-26L type L package 14mm (C2)
                                  SDIP2F-26L type X package 11.70mm (C2)
                                  I guess extra 2.3mm leaves more room for IC to sit up high and more room for heatsink and screws.
                                  • stomanata
                                    • Apr 2016
                                    • 82
                                    Thank you. It is not problem. Over PCB there is PVC plate and this IC goest into it. So extra length will be
                                    on opposite side of PCB and i can cut them.
                                    I`ll purchase from somewhere, because there is no bulgarian firm that offer it.
                                    Hope that this will be the only problem for whole washing machine.
                                    • Soulzink
                                      Samsug washing machine. Power supply DC41-00189a board issue
                                      by Soulzink
                                      I am trying to fix a samsung washinmachine power supply main board.
                                      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                      The power supply board reference is the following: DC41-00189a
                                      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                      04-19-2025, 06:26 AM
                                    • stomanata
                                      Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
                                      by stomanata
                                      on my previous post with help from this forum i found short circuit GIF5CH60TS-X
                                      I replace it but again give me error for current over 16A.
                                      I measure again and found short circuit between #15 and #16 (Cin and GND).
                                      On PCB i remove R121 to check in which direction is short circuit. But this pin goed
                                      to big copper piece on back side.
                                      So i try to measure over every resistor and capacitor
                                      But i can`t find any short circuit,
                                      On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
                                      1. Through CSF (i don`t know...
                                      09-15-2024, 02:06 AM
                                      Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                                      This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-07-2024, 02:20 AM
                                      Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                      This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 09:30 PM
                                      Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                      This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
