Circuit board starts only when warm air passes over it.
  • silentrunning
    • Dec 2023
    • 20
    • United Kingdom
    I have an air con appliance that doesn't always start when power is applied. I have removed the small control board which is separate from and supplied by a 24v power supply (that works fine) and inspected it for any obvious failed components but can see none. I have discovered that the board will start if I wave a hair dryer over it for a few seconds. The board appears to have no temperature sensors or sensitive components on it. Can anyone suggest what the most likely candidate for a failure mode of this form.
    Many thanks.
    John
  • tehmatix
    • Nov 2012
    • 174
    Try to change crystal oscillator if it is existing one on your board
      • 31040
      post a picture
      electrolytic capacitors are temp sensitive if they are borderline
      • CapLeaker
        Leaking Member
        • 8177
        Upload some some high resolution pictures using the attachment function so we can see what you mean…
        • silentrunning
          • Dec 2023
          • 20
          • United Kingdom
          Picture of PCB attached. Many thanks.
            • 31040
            resolder the blue thing that is on the back of the board - it looks like a temperature sensor
            • silentrunning
              • Dec 2023
              • 20
              • United Kingdom
              Thanks. I'll give that a go. Any idea where I might find information about that little blue thing?
              • redwire
                • 3910
                It's a thermistor, look for any markings or numbers on it. There can be two of them- one for air temperature the thermostat uses, and another to detect an iced up frozen evaporator, it's near that coil.
                • silentrunning
                  • Dec 2023
                  • 20
                  • United Kingdom
                  Yes indeedy I thought it might be so I've been reading up on them.
                  The unit is actually a positive air flow fan that simply blows air into the house so no evaporator or anything like that. Could the ntc be being used for some other purpose, it is connected to one of the pins of the MCU via a tiny capacitor or two with the other end I think going to ground. Having said that given it's location on the back of the board I guess it's ambient temp it's after.
                  Measuring it's resistance I can see that change as I heat it up slightly.
                  I have resoldered it but with no change in behaviour, the unit refuses to come on unless it's been off for less than a minute or warm air is passed over it. Additionally passing warm air only over the thyrmister does not turn it on!
                  • silentrunning
                    • Dec 2023
                    • 20
                    • United Kingdom
                    Oo forgot to say it has no markings on it. It's resistance is about 8k at about 16c
                    • redwire
                      • 3910
                      This is some laboratory unit? A fan controller? What model?
                      It could be the MCU is having issues reading the temperature sensor due to noise on its power. I would check the 3 electrolytic capacitors on the board, they may have gone bad. You can also try just heat each and see if that affects things, instead of heating the entire board. Try heating just select parts to narrow it down. Check the MCU power it looks like a 5V system.
                      • silentrunning
                        • Dec 2023
                        • 20
                        • United Kingdom
                        Here's a link to the unit
                        https://www.nuaire.co.uk/residential...lation-systems
                        I've tried warming just separate component's and areas of the board but with no consistency. I've tried a separate power supply with no change. The MCU is a PIC18F24K20
                        The caps look ok but I'm a newby to electronics.
                          • 31040
                          heat the capacitors and see if it effects the unit
                          • silentrunning
                            • Dec 2023
                            • 20
                            • United Kingdom
                            Done that but to no effect. I can't pin down any one component that when warned brings the unit on.
                            • silentrunning
                              • Dec 2023
                              • 20
                              • United Kingdom
                              And only warm air will do the trick. Air from an unheated fan does nothing
                              • CapLeaker
                                Leaking Member
                                • 8177
                                Then do the opposite. Take a can of air upside down and freeze spray components one by one and see if it quits.
                                Did you heat that orange cap with the brown band too?
                                • silentrunning
                                  • Dec 2023
                                  • 20
                                  • United Kingdom
                                  Yep tried em all but couldn't get any consistent behaviour. Do you think replacing the three big caps is worth a shot?
                                  • CapLeaker
                                    Leaking Member
                                    • 8177
                                    Before I would do that, I would put an oscilloscope on them and measure the ripple. Or take them out and check the ESR
                                    • silentrunning
                                      • Dec 2023
                                      • 20
                                      • United Kingdom
                                      Cool. I've been looking at the pwm fan signal that it generates with an oscilloscope with the possibility of making my own control board if I can't get this one to behave. What should I look out for regarding oscillscope readings for the caps. If I remove them I'll probably just put new ones in?
                                      • silentrunning
                                        • Dec 2023
                                        • 20
                                        • United Kingdom
                                        Not sure if this means anything but when I measure the resistance of the thyrmister I get 7.5k one way but 9k when the leads are reversed ! What's that all about?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • repair-it
                                          Engineering help - how does the charging circuit on this board work?
                                          by repair-it
                                          This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
                                          08-31-2024, 12:32 PM
                                        • Crrose
                                          How to test circuit board battery connection.RS-4i sequential stimulator
                                          by Crrose
                                          Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
                                          03-21-2023, 03:55 PM
