help repair Scorpion SC-6989 12v cordless impact driver
  • flat-earther
    • Dec 2022
    • 124
    • palestine
    Hi I got this Scorpion High Quality Products model SC-6989 12v impact driver and the problem is it only runs on full speed and LED light doesn't light up.
    I got the tool with two dead batteries and I already using the good 18650 cells from the two made one working battery.
    Initially when I got it I once hooked up a good 12v battery to it and it powered up and LED worked but now depressing the trigger only makes it run on full speed or nothing so there's no variable speed, but to be honest I'm not sure if this tool has a variable speed trigger. Also LED doesn't light up anymore.
    On the PCB I measured 0.3ohm on a component that I circled in red in my photograph, is that a capacitor? Does that reading mean something? It doesn't have markings on it. The component was glued down and I bent it up.
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: help repair Scorpion SC-6989 12v cordless impact driver
    L1 is a choke (inductor), and it should show on the multimeter.
      • 31134
      see if the mosfet LR8726 is shorted.
      and test the led with your meter in diode-mode
      • flat-earther
        • Dec 2022
        • 124
        • palestine
        thanks for your replies.
        I tested the mosfet LR8726 with one multimeter lead on the larger left metal part of it and the other alternately on each of the 3 smaller pins on it's other side, see photos where first measurement reads 0.3ohm, second 0ohm, third 84.8ohm. What do the measurements mean?
        I tested the LED in diode mode and it reads 1.453 and reversing leads gives no reading. What do the measurements mean?
          • 31134
          the diode test meters low, but the test usually makes it light up.
          the mosfet is shorted - probably.
          you need to remove it and test again.
          the tab is connected to the middle pin - thats why you got 0 ohms, but the outer pair shouldnt look like that!
          • flat-earther
            • Dec 2022
            • 124
            • palestine
            Thanks stj,
            The LR8726 mosfet was the problem indeed, I wasn't ready to remove it before since I only had a soldering iron but now I have hot tweezers so I removed it and soldered a new one and now the LED lights up and the variable speed trigger works.
            I also resoldered the 3 thin black, blue and red wires that go from the trigger to the control board since the wires fatigue snapped from the control board from bending them.
            The LED and trigger behavior wasn't reliable though so I opened the trigger to clean the sliding contact which didn't help then I opened it further and saw the rocking switch contacts looked worn so I ground them clean with a small rubber abrasive bit, also accidentally bent the sliding switch copper contacts a bit but I think it's better since now it applies more pressure on the board it slides on (that actually may have been what was needed since when I moved the 3 thin black, blue and red wires right near the switch, the LED flickered on and off), after that it's all working properly now.
            • osrex
              LED DRIVER KEEPS DYING
              by osrex
              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
              i have no datasheet at all for the LED lights, all i have is its length.
              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
              05-05-2025, 03:36 PM
            • charif
              Audio Driver for Thomson P14C4BK128
              by charif
              Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
              I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
              The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
              Here are the details:
              • Model: Thomson P14C4BK128
              • Operating System: Windows 10 64-bit
              If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
              Thanks in advance for your help!
              04-30-2025, 05:41 PM
            • bohaboha
              how to install gl usb2.0 uvc camera device driver on windows 10
              by bohaboha
              Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
              but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
              any help?
              01-26-2025, 08:33 PM
            • Daveleone
              UN55D6900 BN44-00428B partial led driver circuit failure
              by Daveleone
              Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
              I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
              07-23-2021, 06:31 PM
            • harp
              help with graphics driver for eMachine G725
              by harp
              I am trying to find graphics driver for old laptop eMachine G725, for winxp 32bit... from data on internet, https://gadgetaz.com/Laptop/eMachines_G725--1942 it will have Intel GMA 4500MHD graphics, so I downloaded a few of them but nothing work, error say: this computer does not meet the minimum requirements for installing the software. So, please somebody help me to find bare minimum graphics driver to see non deformed screen anymore...
              07-02-2025, 01:26 AM
