Hi I got this Scorpion High Quality Products model SC-6989 12v impact driver and the problem is it only runs on full speed and LED light doesn't light up.
I got the tool with two dead batteries and I already using the good 18650 cells from the two made one working battery.
Initially when I got it I once hooked up a good 12v battery to it and it powered up and LED worked but now depressing the trigger only makes it run on full speed or nothing so there's no variable speed, but to be honest I'm not sure if this tool has a variable speed trigger. Also LED doesn't light up anymore.
On the PCB I measured 0.3ohm on a component that I circled in red in my photograph, is that a capacitor? Does that reading mean something? It doesn't have markings on it. The component was glued down and I bent it up.
