First motherboard repair, which device?
  • Bladiblad
    • Dec 2022
    • 6
    • Hungary
    I've learned many things through own research. However, repairing motherboards with only basic electronics knowledge has been more challenging than I thought. I've given up many times but I am on the verge of another attempt and I need your advice.
    I have two devices here and I wonder which one would be best for a newbie
    • MacBook Air motherboard (part no.: 820-000165) orange light on charger, no pwr, no fan
    • Or an iPhone 6S no power, not even with new battery
    (Other device tips are also welcome but these two I have at hand)
    • 31267
    Re: First motherboard repair, which device?
    fone is probably the charge/power chip - i think it's TriStar on those.
    for the macbook, luis rossmann has a big pdf about fixing those that lists all the faults/symptoms
    • Bladiblad
      • Dec 2022
      • 6
      • Hungary
      Right! The TriStar chip is quite challenging to solder right?
        • 31267
        everthing in apple products is challenging, they are build to be thrown away!
        • lazenes
          ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
          by lazenes
          The device is not charging with the 19V 180W DC charger. If the battery is full, the laptop powers on normally. I can charge it via USB Type-C, but it’s very slow. I checked the schematics but couldn’t find a solution. I even replaced the BQ24800 battery charging IC, but the issue remains the same. I suspect a MOSFET or a fuse that I might be overlooking is preventing it from charging with the adapter. Has anyone experienced a similar fault before or has any advice?...
          09-18-2025, 01:48 PM
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
