nand bad block with an RT809H, didn't boot
  • lotas
    • Jan 2016
    • 4526
    • Russia
    Re: nand bad block with an RT809H, didn't boot
    The algorithm must be known to the processor itself, this algorithm is used to communicate with Nand memory. If you find someone else's Dump, then the MAC and S / N will be different, but sometimes in new devices the firmware (dump) is tied to the hardware, when turned on, the processor reads from nand (Keys, a unique code) and if it does not match, the device will not turn on.
    • Formaster
      • Jul 2021
      • 68
      • Switzerland
      Do you think I can make a correct dump with flashcat? And write it back to the brand new nand. In lucky case is not SN/MAC stricted or boot glitch maybe jump into root.
      • lotas
        • Jan 2016
        • 4526
        • Russia
        Well, if you haven't killed your native dump with the RT809 programmer, then you can try, the main thing is that the bootloader, MAC, S / N ... survive.
        • Formaster
          • Jul 2021
          • 68
          • Switzerland
          Think that flashcat mach1 also can't handle it. Any other recommended programmer?
          Maybe you right Lotas, i found a custom parameters on Xgecu util.
          If take the Xgecu t48 model which cheaper, may use the adapters from the RT809H? or also for t56...
          • CapLeaker
            Leaking Member
            • 8064
            Some adapters are not interchangeable. I’ve got the TL866 II and the RT809H. Some routers have an emergency / recovery mode. I’d play around with that. I remember years ago recovering bricked routers by uploading the firmware without an programmer, using UART and FTP instead. I never took the flash off the board Γ nd using a programmer as it is just too much work plus needing a dump.
            • CapLeaker
              Leaking Member
              • 8064
              Apparently this ftp method works for Zyxel too… it’s a different router, but the idea is the same.
              Or another way to recover NBG6616:
              1. Install Tftpd32
              2. In the Windows network adapter, manually set the IP address as 192.168.1.33, netmask 255.255.255.0
              3. Download firmware from ftp://ftp2.zyxel.com/NBG6616/firmware/
              4. Copy firmware file into the tftp directory and name it "ras.bin"
              5. Push HW WPS button, and then boot on NBG6616 (You will see file transfer in Tftpd32, and then release button)
              6. Wait for around 3~5 minutes, after the image has been flashed all LEDs will blink fast
              7. Reboot NBG6616, recovery done
              • Formaster
                • Jul 2021
                • 68
                • Switzerland
                #27
                Thank you CapLeaker! I already tried this method's before bricked the fw, saidly all service ports was filtered, while it was an ISP version of the router.
                Now won't boot up. Thinking to make a dump from a working one official Zyxel, but the chance are big that is S/N restricted. Maybe can do it someone who are good in reverse engeneering.
                • CapLeaker
                  Leaking Member
                  • 8064
                  I don't think that they are S/N restricted. Look around if there is another service port somehow on the board. If FTP doesn't work, try the UART. There's gotta be a way to recover that darn thing somehow.
                  I also wonder if they just had changed the FTP service port to something else.
                  • Formaster
                    • Jul 2021
                    • 68
                    • Switzerland
                    #29
                    Checked all the avaible ports with NMAP before bricked. Every service ports, ssh, telnet, ftp was firewall filtered. The problem is now via uart clear nothing life signal. Bootloader dont stay up.
                    I found this row in HEX: pictures below, hex and uart log
                    but this is maybe only for stricted gpon connection. I ordered an xgecu t48, hope doing well with my tsop48 adapter and take another zyxel router to dump correctly the nand.
                    • lotas
                      • Jan 2016
                      • 4526
                      • Russia
                      #30
                      The T48 has its own adapter for Nand TSOP48.
                      https://aliexpress.ru/item/100500448...00029314019156
                      https://aliexpress.ru/item/100500459...00029782074979
                      • CapLeaker
                        Leaking Member
                        • 8064
                        Well, I guess that it may now be the only way to recover this thing by getting a working dump.
                        However there has to be a way to flash this with an empty chip somehow. Just out of curiosity, upload a high resolution picture of the board.
                        • CapLeaker
                          Leaking Member
                          • 8064
                          I googled for "zyxel ax7501-b0 firmware download" and short and sweet found:
                          There is now firmware version 5.15(ABPC.1)C0 for AX7501-BO available to download as a V5.17(ABPC.1)C0.zip file.
                          Sweet thing is: Unpacked, it's a .bin file 66.25MB. Since you're flashing a NAND, you need U-Boot. Looks like on your pics it didn't boot at all? If this is the case you have to restore U-Boot on the NAND.
                          https://support.zyxel.eu/hc/en-us/ar...ry-for-DNSpooq
                          first thing on the list.
                          • Formaster
                            • Jul 2021
                            • 68
                            • Switzerland
                            #33
                            Some pictures atttached. Found this firmware too and I also see that uboot is missing to boot, but no idea how can be restrored. Specially from the original dump.
                            • CapLeaker
                              Leaking Member
                              • 8064
                              Everything is done through the TTL. I am not sure if the officially firmware (66MB one) contains a full flash or not. Can’t hurt to flash it like it is and see what happens. After all you don’t know what the ISP flash contained. There should be a few ways flashing this router, via TTL and some serial terminal program (probably slow) and via FTP.
                              At this state I don’t think the router knows anything much as it looks to boot from something. But as long as the TTL works the router can be saved with the correct file(s) loaded up to it.
                              • Formaster
                                • Jul 2021
                                • 68
                                • Switzerland
                                #35
                                Already tested the official fw, no luck. My theory is too, if got the boot, than the device saved. Because I can't reverse engeneer this broken fw and also can't build the u-boot from zero for this Broadcom 6858 cpu, still waiting for the Xgecu programmer, than take a similar router to dump correct the nand. Hope with some luck.
                                • CapLeaker
                                  Leaking Member
                                  • 8064
                                  There is a way to send uboot via serial terminal. Maybe try that.
                                  • privato89
                                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                    by privato89
                                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                    Let's begin:
                                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                    03-26-2024, 06:37 AM
                                  • hinisa
                                    Xiaomi router freezes at boot after re-capping
                                    by hinisa
                                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                    07-08-2023, 05:58 AM
                                  • Luke Anders
                                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                    by Luke Anders
                                    A few details about the laptop itself:
                                    Name: Lenovo Legion 5
                                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                    BIOS Version: GKCN60WW
                                    EC Version: GKEC65WW
                                    Serial Number: PF39AQ7Z
                                    Board Model: NM-D562 Rev 3.0
                                    RAM: 16GB Installed, DDR4 (brand new)
                                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                    I bought this laptop recently from eBay as a faulty device....
                                    10-12-2024, 05:13 AM
                                  • menshawy
                                    MEC5050 Boot Block Disable needed
                                    by menshawy
                                    hi
                                    please help to know how can i unlock Boot Block in MEC5050
                                    M.B LA-7731P
                                    THANKS...
                                    04-04-2023, 10:12 AM
                                  • tikanot
                                    ACER NITRO 5 AN515-42 boot and block
                                    by tikanot
                                    hello i have an ACER NITRO 5 AN515-42 and he boot and block at boot no error or bluescreen. I have flash the ec, flash the bios and change bios chip and same mistake. I don't where to search the mistake.
                                    05-10-2022, 08:15 AM
