Is it possible for transformer substitution?
  • R_J
    • 9633
    Re: Is it possible for transformer substitution?
    Originally posted by stj
    but it looks very bodged - so who knows - and look at the same switch handling mains and secondary - thats insane!
    The switch is only connected to the primary, not the secondary
      • 31305
      it looks like the led connects
      • R_J
        • 9633
        The blue lead from the positive terminal connects to one lead of the led, the other lead of the led likely has a resistor inside the insulated tube that connects to the negative terminal. the three blank terminals on the other half of the switch don't connect to anything.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          Rukycon!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            BTW a so-called Dim Bulb Tester is the most excellent test unit to see if the transformer is still any good.
            Connect a 60W incandescent lamp in series with the primary (or in parallel with the burnt fuse) and see if it lights up when you plug it in (with no load on the output). If it doesn't glow, the transformer may still be good. If it doesn't glow and then you short the output of the PSU (the red and black terminals) and then it starts glowing, then your transformer may still be very operational.
            If it lights brightly with no load on the output of the PSU, do not pass go, do not collect $200, transformer probably belongs in the bin.
            • mikey5791
              • 521
              • Malaysia
              #26
              Is there any danger of accidentally eletrocuted from a wet finger touching the same switch handling mains and secondary? Kindly advice any better way to modify this setting.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                You should always exercise caution regardless, but as R_J said, the switch is half-used and only on the primary side.
                  • 31305
                  is dodgy as fuck using that type of switch with mains, the clearance between the contacts and metal frame is way too small
                  • mikey5791
                    • 521
                    • Malaysia
                    #29
                    Dear all,
                    With helpful assistance and kind tips with schematic and lots of patience, i finally unsolder the donor transformer from the burned pcb and moved it to the kent unit. Put in an incandescent light bulb in place of the 3A glass fuse, and switched on the main. The light bulb doesn't glow, no smoke or spark and i set the front switch to 12v. The led indicator lights on, and measuring the output gives a reading of 16.2vdc.
                    Wow, thanks so much guys. Finally you made me a happy guy today. This forum has been a great source for helping those in need in getting things fixed and therefore reduce waste in the landfill.
                    Bravo!
                      • 31305
                      i love the ghetto mains connections!
                      specially the clip designed for papers
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8716
                        Next you need to mod it so that it actually regulates voltage down to a common value... like this supposedly commercial but may well be homemade PSU: https://www.badcaps.net/forum/showthread.php?t=110815
                        • ohren
                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                          by ohren
                          Hello!
                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                          Measured voltages with no load:
                          After rectifier diodes
                          12V: 6.17 V
                          5V: 5.67 V
                          Secondary transformer pins AC measurement (really don't know if this says anything)
                          12V: 2-2.5 V
                          5V: 1.04 V
                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                          03-18-2023, 10:33 AM
                        • dennis_elx33
                          3PHASE STEP-DOWN Transformer in Check
                          by dennis_elx33
                          Hello All,
                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                          Problem statement: Power tripped Off
                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                          Action Done:
                          1) Replaced the faulty parts with good spare.
                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                          12-02-2024, 06:52 AM
                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 04:40 PM
                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 12:00 PM
                          ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 11:50 AM
