Re: 12v 1uo941243c Relay repairable?
Your blown fuse and 3 error codes point to the ECU or it's wiring.
On some cars there is camshaft sensor and a crankshaft sensor and they give you the same exact error code for both at least this is the case with the car that I have so do not over look this when I get this code I change both of them
One note some times it can be the wiring harness plug that can give you a bad headache if it has a bad connection in the plug as well and it can be hard to detect and determine if this is your issue or not
On note about a fuse that blows as soon as you apply power to it you need to find out what is causing this issue use the incandescent light bulb ( or a test light ) instead of the fuse to see if it is a direct short or not you will need a wiring diagram for this car to be able to know all of what is on this circuit
I have a pickup truck that has an issue when you leave the truck sitting for a couple of weeks and go to start it the battery is completely dead no power what so ever I going to have to figure out what the issue is but two things come to mind first one is the radio and the second one is the alternator bad diodes in it and Ford alternator are the worst for this issue I have had this issue several times in the past
A few years ago I had issues with the charging system on this truck and it was one of the pins in the wiring harness to the alternator that was near the battery that was the issue that time I had to bypass this pin connection in the wiring harness and put a inline fuse on it
But this is where a wiring diagram comes in very handy to help you figure out what could be the problem in a given circuit you can troubleshoot it with out a wiring diagram but it takes a lot longer to do
Here is a case in point I once worked on a car that all of the dashboard lights were on the charging system was not working at all and it turns out to be a wire that goes from the alternator to the dashboard underneath the radiator and had burned it self apart due to a short circuit on the heater for the choke on the carburetor but I was lucky enough that it had a wiring diagram that was available on line helped a lot for this issue
I hope this helps you with your problems with your carLast edited by sam_sam_sam; 09-27-2022, 02:19 PM.Leave a comment:
Hello again I have not made any progress because there is a fuse that destroys all the time it is no: 29 on the fuse plate and I do not know to which relay it belongs the schematic on post 47 that you posted differs a little from my plate. can you
or do you have the schematic of the fuse plate?Leave a comment:
P0725 rpm sensor also known as crank sensor . this will prevent engine starting .
don't worry about transmission codes yetLeave a comment:
your comment confirms to me that this sensor is causing krank no start for the car and we are still talking about codes: P0725,P1780 and P1850 all are linked to gearbox and speed? i will test, clean and hope it will startplenty of electronics involved . if you look at live data on your scan tool it should have rpm .. or maybe not depending on the scan tool . also if you have an an oscilloscope you can check the waveform directly from the sensor . will tell you a story about this .i was called out to a job the experts couldn't fix i hooked up my bench oscilloscope and the car started up .after that it started every time .not saying this will work for you but you can see if sensor is working ok before checking the wiring ,Leave a comment:
not just the sensor - clean the flywheel or whatever it is sensing.
i know on some old cars if you got lots of mud on the toothed wheel it couldnt sense itLeave a comment:
i have cleared three four times the codes but they keep coming back and the car still cranks but does not start maybe i should try to find this sensor and clean and test to see what it gives . petehall347 i appreciate and thank you for your support and wonder if i can pm you because i think we are off electronics topic on this threadP0725 rpm sensor circuit . P07255 not found please check code .
thinking the crank sensor wire breaks right next to sensor .also failing battery will cause problems starting
P1780 not found
P1850 not found
autodata hasn't got transmission codes .
clear all codes and see what comes backLeave a comment:
P1780 not found
P1850 not found
clear all codes and see what comes backLast edited by petehall347; 09-25-2022, 01:49 PM.Leave a comment:
what codes are coming up on your scan tool ?Leave a comment:
hoping this works i didn't check if it converted properly .Attached FilesLeave a comment:
i have it but can only save as xps and it looks like this website cant deal with it .. will have to learn how i can change it . ah will put on stick and plug into linux pc .. autodata is on my windows work laptop .Leave a comment:
Thank you very much, will it fit my car? because as you see on my plate i have some relays more exactly 4 which contains 2 integrated dual relays like number 455,389 which are clear but then 175 and the one which is between 100 and 409 this makes it difficult and follow your pictures but the pictures themselves they are ok. do you have possibly schematic to fuel pump on your autodata?Leave a comment:
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by CrystaleyesFirst off,
Happy New Year everyone!
Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages.... -
Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
Thanks in advance!... - Loading...
