12v 1uo941243c Relay repairable?
  • bohaboha
    replied
    Re: 12v 1uo941243c Relay repairable?
    something very strange: today i pulled off all the relays in the car even the two in the engine side and turned the key to ignition everything lit up on the panel and even the central lock worked open and close is it normal?
  • bohaboha
    replied
    i dont think it can be the ecm blowing fuses as it looks like its providing grounds to the fuel pump etc .
    a blown fuse can stop comms at the obd connector .and can be something silly like lights fuse etc .
    car electrics do strange things like one i worked on and wouldn't start with a blown horn fuse .
    Sorry I no longer have a blown fuse what I have is 3 or 4 fuses that don't get current and all have to do with motor control and ignition and they are nr: 29, 15a/32, 10A/34, 10A and 39. 20A
  • petehall347
    replied
    replied
    did you look in the computer yet?
  • petehall347
    replied
    its likely another blown fuse . is the 12v present at the obd2 connector ?
  • bohaboha
    replied
    any advancement ?
    Hi there came a friend who is a car mechanic but we did not manage to connect he computer to car controls he shall return when it is possible for him. meanwhile so I found this video do you think it can be similar problem that I have? if it is think you can fix the diagram although i think his ECM is similar to my own and i might be able to follow his
    https://www.youtube.com/watch?v=moGszDaCVME
  • bohaboha
    replied
    any advancement ?
    No but a friend mechanic will come tomorrow and look at it let's see if we can solve the mystery. if you can give more advise very appreciated
  • petehall347
    replied
    any advancement ?
  • bohaboha
    replied
    just measure the voltage on the large terminals where k20 relay plugs in . one should be 12v . the other is going to be shorted to chassis if the fuses have been replaced that blew first .
    i did it allredy ut there i gott power from 2 pins and the fuses are replaced here somes pics. the car have an cautomatic gearbox
  • petehall347
    replied
    you need to find and fix the short before blowing more fuses .
  • petehall347
    replied
  • bohaboha
    replied
    Originally posted by diif
    Three 30A ?, the bigger ones are the metal strips.
    you mean that in addition to the 30amp fuses those metal strips are those high amps fuses?
  • bohaboha
    replied
    ok if you cant find the fuse pull k20 and see if its getting power on one of the large terminals in the socket .
    excuse me which socket do you mean ? can i use 2 cement10k ?
  • bohaboha
    replied
    when quoting post numbers please add the link by right clicking on post number and copy link then post it .
    https://www.badcaps.net/forum/showpo...2&postcount=42
  • diif
    replied
    Originally posted by bohaboha
    those are 30 amp and they are ok
  • petehall347
    replied
  • petehall347
    replied
    yes post 41 there is no 50 amp on it
  • bohaboha
    replied
    Post a picture of the relay that you want to know about
    here it is
  • petehall347
    replied
    engine bay 1 .there are 8 fuses together .its one of those .
    left side behind the headlight just to right of battery as yo look at it and behind battery
  • bohaboha
    replied
    cant remember if i posted pics of the fuse boxes . .. just starting up the laptop
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • valvashon
    Repair Success! Middle Atlantic UPS2200R-IP
    by valvashon
    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
    02-06-2024, 12:54 PM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    by sam_sam_sam
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
  • Crystaleyes
    LCD TV Power Supply Board question
    by Crystaleyes
    First off,
    Happy New Year everyone!
    Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
    A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
    01-01-2025, 09:40 AM
  • Nikolai Danylchyk
    Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
    by Nikolai Danylchyk
    Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
    Thanks in advance!...
    05-08-2025, 06:18 AM
