12v 1uo941243c Relay repairable?
  • bohaboha
    replied
    Re: 12v 1uo941243c Relay repairable?
    Originally posted by diif
    That rules out the direct connection to the ECU but I don't think it's a relay causing your fuse to blow and three error codes.
    I think there is a large connector behind the battery check that.
    they do not blow anymore now there is no more power flow and it 3fuses
  • diif
    replied
    Originally posted by bohaboha
    The ECU on this car is located with the wiper motor I took out and it looks almost like new even inside. Don't you guys know how to test these multi pins. relay? Because with all the help that petehall347 has contributed I still have some relays that I don't know their purpose just because supposedly they handle multiple things at the same time
  • bohaboha
    replied
    i wouldn't be messing with all that stuff . instead i would be getting it running then see if anything isnt operating properly .
    did you fix the rpm sensor yet ?
    it's right what you say but when I don't get power to the sensor and ignition coil and also not to the fuses 28,32and 34 which all have ignition to do then I go crazy
  • petehall347
    replied
  • bohaboha
    replied
    Check the connector to the ECU that's behind the battery.
  • diif
    replied
  • bohaboha
    replied
    Originally posted by redwire
    First you would troubleshoot and fix the blowing fuses problem, why are you now suspecting the relays? Look for the short circuits instead of wasting time here.
    thanks but after the fuse was blown I no longer have any power through so I can't find the source and then it would be good to know that those relays are working properly. what I understand from your post the relays have nothing to do with the fuse or am I wrong
  • redwire
    replied
  • bohaboha
    replied
    everything is marked on the wiring diagram . there is also a list of everything you can search the pdf .
    Hi again I was wondering if you or maybe someone else here in the forum who knows how to test a 6pins,7pins,9pins and even twin relay. Have searched everywhere only find how does an 8 pins different relay work or maybe refer to something that can help. some pictures to understand
  • bohaboha
    replied
    Thanks these were not with the others in your last post.I'm trying to put them together so I can understand what it looks like.
    Sorry now i see they are here
  • petehall347
    replied
  • bohaboha
    replied
    f29 powers A52 Ignition amplifier. unplug it to test if short gone .
    its right there on the diagram ,
    that manual is on google ..its a skoda factory one
    https://letmegooglethat.com/?q=skoda...cal+pdf+manual
    Hi I find no F29 or A52 on the Diagram but you said "f29 powers A52 Ignition amplifier. Pull out the plug to test if there is a short circuit.
    It is right there on the diagram, can you point to what you are saying please
  • petehall347
    replied
  • bohaboha
    replied
    there is a workshop service manual for the electrics online .. you will maybe need to make your own breakout box .
    what i do is find the resistance figures for the sensor and remove and inspect the suspect sensor for damage and check resistance .
    do you have any specific link to this workshop service manual? i searched for autodata but they are very expensive even though they have one..very cheap first month. what do you mean by making your own breakout box. the fuse that is no:29 on the fuse box has has to do with petrol engine, engine electronic and ignition according to the manual
  • bohaboha
    replied
    which fuse is blowing ? what did you do just as the fuse blew ?
    fuse that destroys all the time it is no: 29 on the fuse plate and I do not know to which relay it belongs the schematic on post 47 that you posted differs a little from my plate.
  • petehall347
    replied
  • petehall347
    replied
    replied
    Here is how I troubleshoot a short circuit with out a wiring diagram but this takes a long time to do
    You have to gain access to the back of the fuse box and trace down the circuit that has the issue and start taking of the tape off until you get the first connection point and keep going down the wire path until you find out where or what is causing the short
    One option you have to getting a wiring diagram for the car in question is go to the dealership and ask them if they will print out the section that you need I have done this myself in the past and have gotten good results from doing this now you might have to pay a fee for them to do this for you
    What amperage is the fuse in question
    STJ point is also something to look at as well
    “ check inside the ecu
    just in case a cap has leaked - very common in Honda OBD1 era stuff ”
    replied
  • bohaboha
    replied
    On some cars there is camshaft sensor and a crankshaft sensor and they give you the same exact error code for both at least this is the case with the car that I have so do not over look this when I get this code I change both of them
    One note some times it can be the wiring harness plug that can give you a bad headache if it has a bad connection in the plug as well and it can be hard to detect and determine if this is your issue or not
    On note about a fuse that blows as soon as you apply power to it you need to find out what is causing this issue use the incandescent light bulb instead of the fuse to see if it is a direct short or not you will need a wiring diagram for this car to be able to know all of what is on this circuit
    I have a pickup truck that has an issue when you leave the truck sitting for a couple of weeks and go to start it the battery is completely dead no power what so ever I going to have to figure out what the issue is but two things come to mind first one is the radio and the second one is the alternator bad diodes in it and Ford alternator are the worst for this issue I have had this issue several times in the past
    A few years ago I had issues with the charging system on this truck and it was one of the pins in the wiring harness to the alternator that was the issue that time
    that's right camshaft sensor and a crankshaft sensor could be the cause but as you say i need to have wiring diagrams for this car petehall347 has helped me with that hope he continues with it because now i'm stuck with a fuse that blows all the time
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
  • valvashon
    Repair Success! Middle Atlantic UPS2200R-IP
    by valvashon
    Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
    Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
    02-06-2024, 12:54 PM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    by sam_sam_sam
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
  • Crystaleyes
    LCD TV Power Supply Board question
    by Crystaleyes
    First off,
    Happy New Year everyone!
    Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
    A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
    01-01-2025, 09:40 AM
  • Nikolai Danylchyk
    Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
    by Nikolai Danylchyk
    Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
    Thanks in advance!...
    05-08-2025, 06:18 AM
