Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
    • Jul 2011
    • 6070
    Re: Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusi
    Well I have one more M18 HD12.0 battery pack that I tested and of course it was way out of balance and the amp hour between were very uneven as well discharged battery group cells to roughly 3.1something
    This battery pack is taking the longest to charge as well but I have all 4 fuel gauge lights on which is good sign this battery probably not the oldest one either so at least I think so because I bought two at same time and the other one much later on
    But it weird that all three of them had the same exact issue so what this tell me is that the BMS protection board is not best one in the world but it does let you know that they are unbalanced when you can not get all four fuel gauge lights to light
    I have several Ryobi battery packs that are doing the same exact thing only three out of the four LEDs light up which is probably the same exact issue but I need to make a jig for doing this type of testing
    What is telling me is that as these batteries age they might also become unbalanced as well but I have bought new batteries to replace them and use the old ones in another application and I will regroup them when I do this for better preforms out of them
    I have to wait a month or more for the BMS protection boards the tabbing and the plastic battery cell holders to arrive so I can put them together in the original battery enclosure for Milwaukee
    And use the Chinese made enclosure for the batteries that have been regrouped for better preforms hopefully this will be the case
      • Jul 2011
      • 6070
      Well I torcher tested one of the unbalanced battery packs and it preformed very well and the running time was back almost normal and it is charging normal as well all four fuel gauge lights come on and it is charging for a long while in this state which is normal for this size battery pack
        • Jul 2011
        • 6070
        I ordered from this seller “Shop3686085 Store”
        https://www.aliexpress.com/item/3256...xx__1662589135
        The items have been shipped now wait for about a month for it to get here so we will see how this works out with these new batteries that I just bought and been testing
        The new batteries that I tested so far are no more than 500 milliamperes hours different which is good however the charging time are not exactly the same this might not be a problem when you have 3 batteries in parallel but I am going to try to make the battery pack as balanced as much as possible for best results
        How I know this is because I started all the batteries basically at the same time but the charging time varies at least a few minutes between battery cells as you can see in the picture of the results for this set of four batteries that have been tested so far
          • 31259
          that charger looks a bit limited in the "width" department.
          whats the largest batteries it can take?
          your link is broken btw
            • Jul 2011
            • 6070
            This is one thing I do not like about AliExpress it is very difficult to reference anything from there website
            The widest and longest battery you can put in there is a 21700 battery type 4 at the same exact time
            The reason I bought this battery testing machine was that it could take the 21700 battery type
            You can charge 4 batteries at the same exact time however if you use 26000 to 32700 you can only do two of them at the same exact time with two smaller diameter batteries according to manual
            I have not tried this yet but I will become I have some 26650 batteries to test as well
            Here is a picture of what is supposed to come in this repair kit
            Battery Hookup now offers the 21700 battery however you have buy 100 of them at a time for $300.00
            Unfortunately they did not have any when I was looking for them or would have bought them from Battery Hookup instead of where I bought them from I paid $1.35 more for each one but I did get a free gift for my first order so it not exactly $1.35 and also got battery case holder that I did not have either so buying them from where I bought them from was still worth the money
            https://batteryhookup.com/products/1...j-2170-4100mah
            This picture is from the AliExpress website page with the picture cropped so it only shows what is in the repair kit
              • 31259
              no, thats just noob error.
              same happens with ebay, amazon etc.
              the shit in your addressbar is not just the item but also all the tracking crap.
              with ali you just need to copy from the "https" to the end of the "html" after the item number.
              like this:
              https://www.aliexpress.com/item/1005003614837992.html
                • Jul 2011
                • 6070
                Try this
                https://www.aliexpress.com/item/3256804189572441.html
                  • 31259
                  perfect link.
                  why does the board have a copper heatsink?
                    • Jul 2011
                    • 6070
                    When I get the new ones I will carefully remove the heat sink and see what is under it I was wondering the same thing
                      • Jul 2011
                      • 6070
                      I posted the results on the new SkyRc battery tester that I had bought
                        • Jul 2011
                        • 6070
                        Update on one of the Milwaukee rebuild battery packs the BMS protection board failure this time it just flashing one fuel gauge light no output voltage and the battery voltage is 20.64 so now I bought a couple of battery packs that have the issue with battery packs that only 3 fuel gauge light and will not charge correctly anymore
                        I was using the high torque impact gun on a project on my son semi truck when it started flashing only one fuel gauge light but no output voltage put it back on the charger and it work again for a few minutes and then the same thing happens again put it on the charger again but nothing this time around completely dead only one fuel gauge light blinking
                        This battery pack has been acting weird a couple of times before not like this it just would trip out easily but kept working until now
                          • Jul 2011
                          • 6070
                          I bought two M18 @ 12 amp hour batteries from EBay that have the same exact issue with the three battery packs that I originally had before I put new batteries in them for The cost of the two battery packs from EBay was $170.00 includes shipping and taxes
                          Between the the two battery packs I should have enough battery cells to make a good battery pack and one not so good battery pack or just use those battery cells in something else
                          The two that I bought from EBay the battery voltage was anywhere from 3.4 to 4.0 volts the battery has plenty of power to run the impact gun with a load on it so this is good sign that unless it has issues that I do not know about they should be alright
                          Yes the description that the EBay seller had on these battery packs was as follows
                          Only three out of the four fuel gauge LEDs light up and the tool works you just can not fully charge the battery packs
                          On one battery pack I have discharge all the battery cells to 3 volts and put it on the Milwaukee battery charger and the other battery pack I am in the process of discharging all of the battery cells to 3 volts and see if the BMS board has any issues that I should know about
                            • Jul 2011
                            • 6070
                            Update
                            on these battery pack cells I have put new battery cells in three different battery packs and they all work like they did new I have one more battery pack that I have new cells for that I have left at 3.something after being load tested
                            Update
                            on the two battery packs that I bought from EBay I put new battery cells in both of them after leaving the new battery cells fully charged for at least two months or more and still have full charge voltage and four fuel gauge lights
                            Another battery pack that I still have to put new battery cells in this one has one battery cell bank is at 3.1 and the rest of them are 4.07
                            So I will have 4 reconditioned battery packs and one new one that 12 amp hour pack each
                            I am looking for a couple more battery packs that are having unbalanced battery cells in the pack because I have a lot of barley used 21700 batteries that I want to try them in and see how well they preform
                            There is an update on the taking used unbalanced battery cells 21700 power tool the amp hours are all over the place even if are they not showing signs of self discharging so you really have to test them several times when they have sat for a month or two and retest them again for the best results
                            I am going have to use the battery testing machine that has the best graphics that shows the results over time where you can move the results line and see the exact roll of voltage of each battery cell use the best ones for the best results out of the battery pack
                            I have not decided on what to do with the battery cells that have a higher self discharging issue meaning that the battery voltage goes down close to 3.0 volts or a little bit lower than that
                            I will have to see what kind of amp hours they have after sitting for a couple of months and see if it is worth the time and effort doing this type of project if they are half decent I might build a solar powered LED light fixture that uses these battery cells
                              • 31259
                              dont put lithiums outdoors,
                              if you charge them while they are cold they can go boom,
                              if they get too hot they lose charge/capacity.
                              i just bin cells that self discharge.
                              i mostly use lithiums for lights so self discharge is not tollerable in emergency gear.
                              • CapLeaker
                                Leaking Member
                                • 8340
                                Sam: for how long do you charge these M18 12AH batteries for? Just like to see how they did get so unbalanced?
                                Here we go: I’ve got new 18V Bosch tools with a fancy charger that accepts a Bluetooth module and pairs with the phone. It’s got fancy features that include charge batteries to only 80% or 50% storage mode etc.
                                So I put the charger on 80% long battery lifespan mode and used one of my older 4Ah batteries. It took about 2 weeks of everyday use for the cells to become so unbalanced, that charging would be completed within 7 minutes, and I couldn’t make the day through without recharging in between.. This battery was dead way faster than the others. So I put the charger back to normal mode and charged that unbalanced battery overnight. Works perfectly again like all the others. My fancy Bosch charger did balance the battery pack. I am wondering if you are giving the charger enough time to balance the battery pack or maybe are Milwaukee chargers straight up garbage? Don’t know. Meanwhile I did also purchase 8Ah and 12 Ah Bosch batteries. As I am starting projects I may take a specific battery pack / charger again to do some testing.
                                  • Jul 2011
                                  • 6070
                                  The Milwaukee battery chargers do not have this feature but that is not the only issue with the battery cells the one that are unbalanced are also self discharging even with out the BMS protection board hooked up to the battery cells
                                  Yea you can try to rebalance the battery cells with a battery testing machine but it the battery cells get unbalanced again because of the self discharging battery cells there is no hope for them in the configuration that they are in the original battery pack also even the ones that do not discharge severely by themselves the amp hour results are as follows the new battery cells are 4.5 amp hours the battery cells that are in a self discharging cell pack are like 3.something but each battery cell the battery amp hours are all over the place and to make matters worse voltage curves are sometimes do not look good either
                                  I have been testing some battery cells that were in the unbalanced battery packs and the results are not very promising yet I do not even think I have enough good battery cells to make a good used battery cells
                                  When you have a battery pack that the battery cells are unbalanced rebalanced them and then let them sit for a month or two and do not use them and see if they are still fully charged or not if they are not fully charged anymore the battery pack cells have become unreliable and you have drastically reduced amp hour capacity
                                  I hope this helps you with your questions
                                  One note the battery packs that I originally bought new I have used them very hard in the power tool and more often than not I do not put them back on the battery charger until I have either no more power or one maybe two LED lights on the fuel gauge of course this is not the way to get the most lifespan for a battery pack
                                  When you have a 12 amp hour battery pack that the fuel gauge is blinking one LED light this means that the battery cells are severely discharged it might take 4 hours or more with a 4 amp hour battery charger
                                  But even the RYOBI battery packs have the same exact issue with the battery pack cells becoming unbalanced and I have had to fix a couple of them already I four more of the 1.5 amp hour ones with the fuel gauge on them are the only ones that I fix for myself but where I work at now they have some 1.5 amp hour battery packs that have become very unbalanced or the battery cells are completely dead and are bad that I have fixed with new 1.5 amp hour battery cells
                                  One note about the battery packs that are 1.5 to 3 amp hour do not be tempted to use higher amp hour battery cells in them because the heat sink is not big enough to remove the heat that is generated by using the power tools on them
                                  One note the Milwaukee and Ryobi battery BMS boards do not have balancing feature I wish they did for how much the battery packs are you would hope that they did have this feature
                                  What is the cost of the new 18V Bosch tools with the new features that you were talking about
                                  • CapLeaker
                                    Leaking Member
                                    • 8340
                                    Can you identify if the bad "unbalanced" batteries are repeatedly in certain spots within their battery stack? I wonder if the problem is the actual cell or if it has something to do with the battery balancing circuit putting on a constant draw on selected battery group. On the older packs it is not that each single battery is getting balanced, rather the group is split in 2. A 4Ah battery would have 1 group with 2 balancing circuits. An 8 Ah pack would have 2 groups, 4 balancing circuits and so forth. It seems that these single batteries are getting unbalanced where the load resistor for balancing is connected, because the resistor is putting on a constant drain.
                                    My old battery packs only have 3 LED's and the Hitachi has no battery display as charge status indicator. I only charge them when they are dead (tool shuts off) or displaying one bar. The new battery packs have like 6 LED's. I've got Hitachi, Bosch, Dewalt and Milwaukee tools. But only got the big batteries for the Bosch.
                                    The big batteries 8Ah and 12Ah and the charger are Bosch Profactor. I have some Profactor tools too. Only thing is that the 12AH battery pack needs a small mod to fit in the other regular Bosch tools (cut of a piece of plastic on the battery). Prices are sometimes real good on Amazon and for me the cheapest place to get. I watch until something goes on sale and buy it. For the last 6 months I've been collecting new tools and buy a new tool to replace an old one or something I never had before every month because I am doing repairs / re purposing rooms (built me a shop (mancave) in the basement and a reno at home. Can't afford to hire a contractor. Of course it will be slow, but I am o.k. with that and at the end I've got new tools that I own for other projects down the road and saved me tons of money doing so.
                                      • Jul 2011
                                      • 6070
                                      There is no certain place in the battery pack it varies but generally it is in middle of the battery pack not normally on the end battery cells on the outside cell but I seen them also have issues but mostly the inner battery cells are the most common issue ( or a quality issue when they are being manufactured ) or keeping them in the car or truck probably dose not help anything either
                                      I have a feeling that when you let a this type of battery get really low and you do not charge it right away and you leave it in discharge state over a period of years it does something to the battery I am not sure exactly what it does but this is what I have noticed with the battery packs that I have
                                      Good luck with your project that you are doing
                                      • CapLeaker
                                        Leaking Member
                                        • 8340
                                        One thing is correct in you assumption… Do not leave empty batteries uncharged or attempting to charge a hot battery pack. I charge mine right away. As soon as I notice battery degradation, I charge them over night. At the moment think that you’re not giving enough time leaving the battery on the charger for the battery to finish balancing. Balancing takes hours and is not completed when the charger is done it’s charging cycle. Anyway… so far this works for me and never had any problems on any of my 15 LI-Ion battery packs for tools, various brands. I am new to Milwaukee and only got one tool with a 2Ah battery for that. Mostly I’ve got Bosch followed by Dewalt. Heck, my 15 year old batteries for the Hitachi are still working fine. They don’t have the capacity they had, but still they work fine.
                                          • Jul 2011
                                          • 6070
                                          I have left the battery on the battery charger for days and this does not make a difference as far as the battery cells being unbalanced remember that I have had them for over three or four years by now and I use them very hard ( meaning that the battery packs is very warm to the touch) when I use them most of the time do not very often charge them when I have finished using them if they have more than 2 LED lights that are on the fuel gauge also it does not help that I keep some of them in my car at least most of times covered with a sweater so they do not get direct sunlight
                                          I know I not very kind to my battery operated tools and I am very surprised that they last as long as they do
                                          • brispuss
                                            Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                            by brispuss
                                            Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                            Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                            I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                            12-28-2022, 02:58 AM
                                          • razenxd
                                            How can I charge that battery pack?
                                            by razenxd
                                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                            Now, I have noticed a few things.
                                            The "dead" battery, while connected to charger and NOT Charging will...
                                            12-05-2024, 06:11 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
