Newbie Question Schematics reference resistance measurements
  • Lisa_k
    • Jun 2022
    • 5
    • england
    Hi There
    I am new to learning how to read schematics and have seen a few videos on the subject where people have spoken about how manuals have given reference resistance values but never really elaborated on how to check them.
    I'm sorry if this has been asked before, I've made a search, perhaps I am using incorrect terms
    I have a sony service manual with reference measurements, would I be right in thinking a measurement from pin 14 and pin 25 would get 1.4k?
    • Jul 2011
    • 6039
    Re: Newbie Question Schematics reference resistance measurements
    For me to give you a better answer you need to show the hole page and show what note #2 says
    Because I do not want to assume anything because I have not seen all of the page
    No it not something that is widely known if you have just started learning how to troubleshooting from a circuit diagram
    But usually there is something in the notes somewhere in this manual if the manual is worth a crap should tell you this at least the ones I have run across but you will have to maybe go through the manual to find this information
    Sometimes they will tell you that certain switches might have to be in the ON or OFF position or whatever that position might be if it is a selector switch with more than two positions
    Sometimes you will see where it will tell which way the meter leads needs to be to get the results that they are telling you
    But generally speaking the reference is ground but not always
    • Lisa_k
      • Jun 2022
      • 5
      • england
      Thank you for your reply it was most helpful.
      From what I gather with what you have suggested and with what I have in the manual (page 5 section 2) the resistance is measured with respect to ground under no load.
      I could be mistaken but note 2 is in relation to the sine wave that is output
      I can share the service manual if that is alright to do so?
      If not there are a few copies of it online under the name of Sony-PS-DJ9000-Service-Manual.pdf
      In any case I have attached the notes for the schematic diagram
      Thanks again
      • jons
        • Feb 2014
        • 59
        • Latvia
        Those are dc voltage not resistance readings.
          • Jul 2011
          • 6039
          Voltage reading are the norm but I have seen in some manuals with resistance reading as well that is why it is important to find the page that you posted to know what you are measuring
          This is a very important thing to keep in mind when you are comparing your measurements and comparing your results
          “ Voltages are taken with a VOM (Input impedance 10 Ms2).
          Voltage variations may be noted due to normal production tolerances.”
          I have not seen “Ms2” so I not sure exactly what this is someone else needs to chime in to what this means
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            In service manuals it's typical to print expected voltages near wires with an arrow or using a different color font. There is no standard for this so expecting to learn from examples, you really need a lot of examples, as well as read the rest of the manual (usually printed on the same page but not always) that describes what the voltages are and what conditions are needed to get that voltage on a working device.
            Also yes voltages may be off a bit but still be okay. To know requires a bit of experience.
            Ms2 means MΩ except someone cheesed the font.
            • Lisa_k
              • Jun 2022
              • 5
              • england
              Thank you to everyone that has helped. I think you are all right. I was hopefull that it wasn't voltage, as measuring voltage whilst the unit is on is quite intimidating.
              Here is the schematic
              I will measure for volts, but would any ground do?
              • R_J
                • 9535
                Be careful around the A/C input, but after the transformer the voltage is a lot lower (25v & 12v), It looks like any ground would do, Page 7 shows a good ground point (eyelet marked E)
                You could provide the problem with the turntable, then we could help you better.
                • Lisa_k
                  • Jun 2022
                  • 5
                  • england
                  hi there,
                  I've avoided any AC transformers or any huge caps and tried to keep near the IC's
                  The turntable itself works great, although I noticed that the platter jutts forward when powered on and that the strobe drifts forwards with quartz lock enabled.
                  I can make it very stable with the pitch fader however.
                  A few strange measurements on IC2 (ic9242) apc and afc were way off. I noticed the resistors are spec'd at 150k but my DMM reads under 60k
                  I also noticed the dc motor driver ic01 (Ta7259p) has lower +vin then spec'd (1.1 instead of 2.2)
                  As I was tracing along the board i noticed lots of ceramic caps that look like they have been hacked on, it was at this moment i realised I was out of my league on this one. I think i will leave it be as its mostly working correctly.
                  but a massive thanks to everyone that has reached out I got over my fear of taking a voltage when powered on which was a huge win with all your help
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    Originally posted by Lisa_k
                    hi there,
                    For future reference, remember to desolder and lift one leg of resistors in order to get an accurate measurement, as often they are in parallel with other resistors or components which will affect your readings.
                    • cind12
                      GTX 1080 TI Gigabyte Aorus low resistance on vmem
                      by cind12
                      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                      Resistance on 12V 4K ohms (Power present when on)
                      Resistance on 12V PEX 4K ohms...
                      12-08-2023, 09:09 AM
                    • bpjl
                      Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
                      by bpjl
                      I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
                      I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
                      During the inspection, I noticed a burned (charred on one side) double diode PD817.
                      Voltage drops during PD817 measurements:
                      - PIN1-PIN3 forward biased = 0.137V...
                      01-27-2025, 03:01 PM
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • DJbapt59
                      Asus Vivobook x421a
                      by DJbapt59
                      I recently picked up a laptop that was about to be thrown away to try to repair it. I've tested quite a few things, but I don't know where to look anymore. Could you please help me?
                      Brand: Asus Vivobook
                      Motherboard reference: x421da, Rev 2
                      Context:
                      The person who gave it to me mentioned it might have been exposed to water, but they weren't sure. After opening it up, I couldn't find any signs of water damage or oxidation on the motherboard.
                      The first thing I did was to connect the PC to a power supply: 19V stable and...
                      01-24-2025, 05:34 PM
                    • thecookie17
                      Macbook Pro A1708 20V 0A, PPBUS_G3H 13v
                      by thecookie17
                      I'm a newbie regarding all this board repair stuff, and have never done it before, but I thought I might give it a try before throwing my logic board out or selling it. Thus I'm apologizing in advance for any stupid questions.
                      When I first plugged in the meter it showed 20V and 0.01A current draw, however now I have no current draw whatsoever.
                      I measured PPBUS_G3H with 13V, so that seems to be present.
                      https://repair.wiki/w/MacBook_Pro_A1..._shorts_repair
                      I tried everything listed on that page, but everything...
                      02-10-2025, 07:41 AM
