I was messing around with a TIP-120 NPN transistor, and I wired it up just like this
But at NodeA, with respect to ground, I'm only seeing around 4.3 to 4.5 volts, and I'm wondering why? Shouldn't I be seeing a lot more voltage than that?
And when I have it connected like this, I'm seeing 12 Volts at NodeB with respect to ground where I would expect to see none, but I do see zero volts across the resistor until I turn it on, where I then only see 10 volts. And the weird thing about this second config, is that when I measure the current going through the resistor, I'm only seeing around 4ma, which is about what I would expect, but in spite of that, the transistor heats up right now to where within a few seconds its far too hot to touch - that is when I apply 5 volts to the base.
So when I have it like this, there is only 4ma going through the resistor, but the transistor gets extremely hot within seconds.
OK, so in that configuration, I'm seeing 2.7 amps going through the base node ... I think it needs a resistor.
