Battery problems
  • Hondaman
    • Sep 2008
    • 1092
    Battery problems
    I have a couple of sealed (AGM) batteries in UPS units. When the batteries fail the self tests (one is an APC UPS and one Conext), replace the batteries. Very simple.
    I also have one in another application. It demands lots of power for starting, then the alternator replenishes it within a few minutes of riding (Yamaha V-Star Classic 650).
    Will I get any notice when this thing fails? A week or so ago, a fellow with an AGM got stranded at the VFW hall after a charity poker run (I think it was a new, 2008-09 Indian, not an old 1998-99 model).
    If mine fails,would taking it out and warming it up in my hands do anything? Should I get a replacement lined up now (original = 7 years old)?
    Electrically, what's happening? When the AGM battery reaches EOL, do the chemicals decay the same or different than an old-school lead-acid battery? Any thoughts?
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Battery problems
    Filled lead acid and SLA are pretty much the same except SLAs use a soaked (sulfuric acid) glass mat between the plates instead of the case being filled with sulfuric acid and the plates hung in there. Because of this SLAs are also known as starved lead acid batteries.
    These glass mats act like a sponge holding the acid on them which is why these batteries are known as non-spill able. They are then sandwiched between the plates.
    Over time lead acid batteries develop sulfation on the plates. Lead sulfation is a natural component of the discharge process. When the battery is recharged most of it is converted back. Over many charge and discharge cycles this sulfation layer grows larger on the plates and blocks the acids contact with the lead reducing the batteries capacity. This process is accelerated dramatically if you let the battery fully discharge and leave it that way.
    That's why all SLAs in storage should be recharged regularly or trickle charged constantly.
    However even if you leave the battery fully charged the sulfation process still occurs. Also independent of these factors a lead acid batteries lifespan is also reduced by ambient temperature hotter temps = shorter life.
    While an SLA may still function beyond the average lifespan it's capacity (the amperage it can put out) will have dropped significantly.
    • Krankshaft
      • Jan 2007
      • 2328
      The best way to test your battery to see if it needs to be replaced is to use a load tester.
      It's simply a resistive element in a box connected to a volt gauge. When the load (the resistor) is connected to the battery it draws a certain amount of current determined by the resistor. During this process the battery voltage will drop if that voltage drop which you read on the gauge is in line with the batteries capacity rating at that current then the battery is ok.
      In other words if the battery can provide a certain amount of current (usually the max current from the starter) and the voltage drop is within parameters it's ok.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        The parts store I deal with has a computerized load tester. Its great in that it doesn't kill the battery during the test. It measures such things as internal resistance, current and voltage...ect. There should be a lable on the top of the battery listing CCA and voltage. These specs are punched into the tester befor the test. In just 30 seconds the tester will tell you if the battery is over the hill. I think the rule is when a batery CCA declines by 20% or is it 30% its time for a new battery. Good luck! I'm on year five with my big redtop in the car. It was stored for a year dead flat and since has been run flat four or five times by us because of various charging system and leaving the lights on failures. Its still working but it just may pass away this coming winter.
        "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
        Mark Twain
        "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
        John Paul Jones
        There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
        Rod Serling
        • Krankshaft
          • Jan 2007
          • 2328
          Those electronic testers use whats called a conductance test and don't actually put a load on the battery. As sulfation builds up since it's a good insulator conductance between the plates goes down. The tester checks this against the CCA you enter into it and issues a pass / fail.
          I'm still skeptical about their reliability especially in borderline situations.
            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
            by sam_sam_sam
            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
            12-31-2023, 06:04 AM
          • flat-earther
            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
            by flat-earther
            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
            I have opened the camera and I think there is enough room to add something inside to accomplish this:
            The camera is powered by a 3.7V nominal single cell lithium ion battery.
            So I need to connect another battery in...
            06-08-2025, 02:00 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
          • trepachka
            iPad Air A1475 Boot loops after replacing battery
            by trepachka
            This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
            The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
            I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
            11-08-2024, 03:17 PM
