Cisco 877 router - doorstop?
  • pedro
    • 199
    • AUSTRALIA
    A customer presented this out-of-warranty router as a "can you have a look at this ... ?". Symptoms: when power applied, all LEDs blink in unison about twice a second, no other functionality. History: had worked great until a thunderstorm, was on a APC UPS at the time.
    We opened it up and - apart from lots of nice Nichicon caps - there were two evil CapXon 6800/6.3V with characteristic bulging. ESR measured 1.4 and 1.5 ohms, so replaced them with Panasonic FM's. (All Nichicons were close enough to ESR spec.) No change in behaviour.
    The board has a 5A fuse on the 5V input, which is intact. Stuck the CRO on the 5V rail and found it wasn't getting up. It would get to about 2.7V and then collapse, repeating as per the LEDs. This router is supplied from a dual voltage brick, rated 5.2V @ 4.4A and 12V @ 650mA. Independently loaded up the brick and it was smooth as, no signs of distress. The inference is that the board is overloading the SMPS brick.
    So somewhere on this board is effectively a dead short. But with schematics of Cisco gear being unobtainium sheltered behind NDA's in their service depots, it's doubtful I can progress this.
    (I have ensured that the owner knows which is his left shoulder, so he knows where this eventually goes.)
    Have attached a couple of pics of the power area of the board. Any comments?
    Friends don't let friends buy Samsung ....
  • Radio Fox
    • Jan 2010
    • 281
    Re: Cisco 877 router - doorstop?
    Have you actually buzzed out the 5V line to confirm that you have a dead short?
    If there is, then the first component I would look at is D12. I suspect it is a transient voltage suppresor connected across the 5V line.
    I have seen a couple of computer monitors which use external PSU's, where the suppresor has gone s/c.
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
    • pedro
      • 199
      • AUSTRALIA
      {When I said dead short I referred to a fault sufficient to overload the 4.4A output of the brick.}
      D12 is before the switch, the fault is after it.
      I had briefly suspected D11 (up near the Pana FM's) until I traced out the tracks. It is the (schottky?) after L10 driven off the switcher U37(LTC3414). There's no other likely suspects that I can identify as potential rail shunts except a zillion bypass caps ...
      The 12V input rail going into the 5V reg U18 (left rear of FM's) is echoing what the rest of the identifiable rail is doing - it rises to 10V and collapses. U18's output is a clean 5V when the input is high enough to allow, and its output feed the 3.3V reg which shows a similar waveform. There is no heat detectable at U18 or the 3.3V reg U32 (right rear of FM's).
      Doing a thermal check, nothing topside gets hot after several minutes running BUT the pcb under U28 (ST chip marked TS616 EB603 afaict) gets decidedly uncomfortable to touch. This device is in the midst of the TDK and UMEC transformers.
      • pedro
        • 199
        • AUSTRALIA
        TS616 is a dual wideband op amp with high output current:
        https://cdn.badcaps-static.com/pdfs/...549de35714.pdf
        • smason
          • 1652
          What if you fed it with a different power supply, like a bench supply that you could current limit, without it shutting down? You could get measurements more easily, and perhaps find a hot component.
          Or go for broke, give it full current and watch for magic smoke
          • pedro
            • 199
            • AUSTRALIA
            Fair thought. Unfortunately my bench supply with current limit is single output, and I'd need to feed the +5 and +12 to the DUT. So one rail wouldn't be "smoke-free" ...
            Make that "expensive magic smoke". Nah, I'd rather return it to the client without any added damage.
            Incidentally, the heat under the TS616 is because of the exposed thermal pad chip package.
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
            • double_DD
              Why does my ISP router hate my "homemade" power supply??
              by double_DD
              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
              07-12-2025, 03:09 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • lefetylorant
              Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
              by lefetylorant
              Hello Everyone,
              Long story short, I got this unit for very cheap.
              I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
              I've performed some measurements:
              - 20V rail perfectly...
              09-14-2023, 05:05 AM
            • bimole
              Weird behavior on 3.3V rail of a CORSAIR CX600
              by bimole
              A colleague gave me an apparently ill CORSAIR CX600.
              He told me that he heard a banging noise, and smelt the magic smoke.
              After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
              I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
              It's another story on the 3.3V rail...
              I have some devices to test deeply PSUs (scope, AC source, electronic load)...
              02-13-2025, 04:49 AM
