Where to find a list of line abbreviations for example +VIN, +VDDC, +VDDIc ect...
  • fab13
    • Dec 2021
    • 109
    • France
    hello everyone. For 1 month I started repairing motherboards except that it is never easy to understand the shortened words on reading the diagrams or to understand its phase lines. Some examples +VDCC , VCC , MLCC , +VA , PW_good , EN , Vin ect.... Currently know them but there are so many abbreviations.
    So my question is is there a list on a site or table that explains how each of the abbreviations works? It would be easier to understand sometimes how a chip works when there is no more information on a datasheet or boardview or diagram of the board
    Thank you very much for your help and will be much appreciated
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Where to find a list of line abbreviations for example +VIN, +VDDC, +VDDIc ect...
    Maybe this can be useful, please do check the software first on a site like www.virustotal.com
    https://www.badcaps.net/forum/showthread.php?t=102704
      • 21620
      There`s a text list here https://www.badcaps.net/forum/showthread.php?t=58105
      • fab13
        • Dec 2021
        • 109
        • France
        Wow really thanks this will be useful in time
        Thanks for your time =D
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
        • otaku_nut
          Vizio E701i-A3 fixed but now has red vertical line
          by otaku_nut
          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
          08-19-2025, 06:11 PM
        • TrueSword88
          Kogan - KALED65XU9220STB - Blue Vertical Line
          by TrueSword88
          Hi all.
          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
          The line just happens to coincide with the end of COF and start of the next COF (attached).
          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
          Hoping to fix...
          05-05-2023, 04:28 PM
        • FALKLAN
          Running Line Voltage and Integrating LED Pods - Automotive
          by FALKLAN
          Howdy everyone! I hope all is well where ever you are!
          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
          02-05-2025, 12:30 AM
        • mindoverflow
          ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
          by mindoverflow
          hello,
          there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
          I changed pads and thermal paste.
          I run mats test but it is reporting 0 errors.
          I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
          After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
          02-09-2022, 03:22 PM
