Re: About Solar Chargers...
Well, I got the panel hooked up to the car kind of willie-nilly for the time being but the back of the car gets tons of direct sunlight for most of the day. I was really surprised when I put my ammeter on it and saw it was charging the battery at .94 amps ... almost a full amp! That's quite amazing for a solar panel of that size.
Thanks for the tip on that purchase, It's going to work out well.
After going through my switch panel (just a project box with 3 automotive switches and the volt meter on the front) it powers a 12v LED motion sensor light on the front of the shed, and an automotive LED flood light attached to the ceiling for interior lighting.
correct.Last edited by dmill89; 12-24-2021, 04:00 PM.Leave a comment:
Correct, the left most ports are for the solar panel, the center ports for the battery, and the right most ports for the load (not used if you're using it to charge an automotive battery, in my case that is where the cable going to my "control panel" for the lights is hooked up).
What's the USB port for? Charging a USB device?Last edited by EasyGoing1; 12-24-2021, 12:30 PM.Leave a comment:
So I got the same setup you have using the link you posted ... I got the 20 watt panel with the charge controller... the instructions are total crap, so I wanted to post this photo and make sure that I'm reading all this properly...
So Im going to connect the solar panel to the SC ports, and the battery, I'm going to connect to the center ports but I'm going to connect the hot lead through a normally closed relay where the relay is actuated when the ignition key is in the on position. This should guarantee that the system is not connected when the alternator is running. And that last set of ports I'm going to just remove those wires since I wont be using them for any lighting of any kind... does that resonate with how you have yours hooked up in terms of properly identifying the ports?
It depends on how good the panel is (which granted a cheap solar charger probably isn't going to have a great panel), I don't charge any car batteries with solar chargers, but I do have a solar system in my shed for lighting consisting of a 20w panel, a 12ah 12v lead-acid battery, and a charge controller, and this panel will still produce around 30-50% of its rated wattage on a cloudy day.
So Im going to connect the solar panel to the SC ports, and the battery, I'm going to connect to the center ports but I'm going to connect the hot lead through a normally closed relay where the relay is actuated when the ignition key is in the on position. This should guarantee that the system is not connected when the alternator is running. And that last set of ports I'm going to just remove those wires since I wont be using them for any lighting of any kind... does that resonate with how you have yours hooked up in terms of properly identifying the ports?Leave a comment:
I was thinking of using something like this and connect it to a wire that is energized when the ignition is turned on so that it would disconnect the charger while the car is running.Leave a comment:
I think there would certainly be enough light during the day to keep a panel like that sufficiently energized. I would think that even 5 watts for a few hours a day would be sufficient to keep the battery topped off. I live in southern California and the path of the sun is such that it shines heavily on the rear of the car, though the covered parking does offer some shade, that back end of the car I THINK gets plenty of light but ill have to check that to be sure. maybe going with the 20-watt panel would be enough to at least guarantee 5 watts for a good portion of the day.Last edited by EasyGoing1; 12-22-2021, 12:16 PM.Leave a comment:
Do you have direct sunlight for a good portion of the day? Shadows of any kind really kills cell performance. Clouds are not as bad as buildings occluding sunlight even if it "seems" just as bright.Leave a comment:
I'm wondering if there would be something I need to do so that when I'm using the car, would there be anything that should be done to protect the charging circuit? Because while the car is running, the alternator would be feeding voltage into the outputs of that charge monitor unit.Last edited by EasyGoing1; 12-22-2021, 11:53 AM.Leave a comment:
Funny you mention that, I was thinking about installing a circuit in the car with a magnetic reed switch such that I would have to place a magnet somewhere before the car would even start. Haven't thought that through yet though, but it would be a great deterrent and this isn't the best area where crime is concerned though it has improved a lot over the years.Leave a comment:
This was not a particularly expensive setup (specifically it is this: https://www.amazon.com/dp/B0956QFKVY...roduct_details), though probably still a little higher quality panel than the average "suction cup to the roof" or "throw on the dash" charger.
you could just start the car every few days to a week for a while.
cheap car alarms on ali-express - the pager type often have remote-start function.Leave a comment:
Do not count on indirect sunlight. Must be in full sun.
Sigh. Need to get started on my grid tie project for my solar panels - but that's where I found that indirect and cloud occluded light is almost useless light... Cirrus clouds also do a huge number on productivity too... In this case you may well need to overbuy solar cells to make up for the poor lighting.
Oh and another benefit of disconnecting batteries: it bewilders and/or annoys thieves, especially if you do it in a way such that they need to bring something else to the table to start the car...Last edited by eccerr0r; 12-22-2021, 02:35 AM.Leave a comment:
might be as simple as moving a fuse to get the lighter socket live with key off .i know some mercedes are like that .
as for the charger it should be fine on its own .. if you used a controller that in itself may use any useful power to run it .Leave a comment:
Check out this gizmo ... only $18 and it looks like it will make sure the battery stays properly charged...Leave a comment:
A car battery wastes about 4mA just sitting there, due to impurities in the electrolyte. Solar chargers can use many mA as well. The car draws up to 100mA average for the remote RX, canister purge cycle and all that stuff the ECU does when the key is off.
Lots of outrage over Subaru ECU's pigging out and killing a battery in a couple weeks or less.
If you only can charge a few hours per sunny day, you'll find you need a fair bit of power to make up for all this load.
I''m using a mains-powered charge maintainer, it puts out about 14.6V 2A for a top up (equalization) charge then shifts down to float charge 13.8V at a few hundred mA, overnight down to 100mA.Leave a comment:
Some of the higher-end solar chargers claim to have "intelligent" charge circuitry so they should at least in theory work just like a plug-in "smart" charger and stop charging once the target voltage is reached. The cheaper ones don't claim this and are likely just a constant "float" charge with no intelligence, though since most of these chargers are 10W or less this isn't likely to be an issue on the average 50-60 Ah car battery, smaller batteries (like motorcycle or power equipment) may have issues with this though.
The Cigarette lighter chargers will only work if the lighter jack is always "hot" (even with the ignition off), and even then I'm not sure how well they'd work with modern can-bus equipped vehicles. If the lighter jacks in the vehicle aren't "hot" with the ignition off (or if back feeding the lighter doesn't play "nice" with the can-bus) the charger would need to be wired directly to the battery.
On my Mustang which doesn't get driven much in the winter I have an SAE quick disconnect (similar to this one: https://www.amazon.com/Battery-Tende...ps%2C55&sr=8-3) wired into the battery (I just use a plug-in battery maintainer since it is parked in a garage with plenty of electric outlets) which will work with most battery maintainers (both plug-in and solar) and allows quick connection without messing with alligator clips and risking shorts.
Definitely depends on the size of the battery versus wattage of the panel, but I'd say that a "dumb" 10W into a 50Ah battery you will need to water the battery and it could eventually cause damage if you never use the battery. At 10W it's about C/60, which is not horrible but still will cause eventual dry out. If it were a sealed AGM battery with proper recombination, then you won't have to worry about electrolyte loss.
Ideally you don't go way too much over about 3x the parasitic draw of the battery (for most cars it's 1W or so tops) if you can't regulate the voltage. But a simple shunt or series regulator will be sufficient to deal with water loss, but do keep in mind it's temperature dependent.
oh btw, a $0 way to maintain your battery if you don't care about ECU settings and less than say 3 months of non-use: just disconnect the battery. If it discharges without it being connected, you need a new battery anyway...Leave a comment:
by Petr0xHi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...05-24-2024, 01:00 PM -
Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)Need some help please with a few components on this small board so that I can troubleshoot the circuit.
The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
J2 - to DC Output
J3 is Battery cell connector
however I am struggling to identify if:
Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....2 Photos -
by eccerr0rWell, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
So now what to do with these small panels?
I could sell them...
Or I could shim them.... -
by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on... -
LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in orderby sam_sam_samI bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
Pictures will come later when I have the lighting fixture gutted and have the battery... - Loading...
