About Solar Chargers...
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Those solar cell car battery maintainer devices ... look like they would be a good idea to use when you have a car parked without being driven for several weeks at a time ... is there any chance that those devices could cause any damage to a car battery? Or are they weak enough that it is nothing to be concerned about? And the other question is, do they actually help keep a battery charged? Looks like they plug into the cigarette lighter plug but not sure how that can charge the battery?
    sigpic
  • dmill89
    • Dec 2011
    • 2534
    Re: About Solar Chargers...
    Some of the higher-end solar chargers claim to have "intelligent" charge circuitry so they should at least in theory work just like a plug-in "smart" charger and stop charging once the target voltage is reached. The cheaper ones don't claim this and are likely just a constant "float" charge with no intelligence, though since most of these chargers are 10W or less this isn't likely to be an issue on the average 50-60 Ah car battery, smaller batteries (like motorcycle or power equipment) may have issues with this though.
    The Cigarette lighter chargers will only work if the lighter jack is always "hot" (even with the ignition off), and even then I'm not sure how well they'd work with modern can-bus equipped vehicles. If the lighter jacks in the vehicle aren't "hot" with the ignition off (or if back feeding the lighter doesn't play "nice" with the can-bus) the charger would need to be wired directly to the battery.
    On my Mustang which doesn't get driven much in the winter I have an SAE quick disconnect (similar to this one: https://www.amazon.com/Battery-Tende...ps%2C55&sr=8-3) wired into the battery (I just use a plug-in battery maintainer since it is parked in a garage with plenty of electric outlets) which will work with most battery maintainers (both plug-in and solar) and allows quick connection without messing with alligator clips and risking shorts.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      That's a good point I had totally forgotten that my plugs turn off with the ignition... so some kind of direct connection will have to be made. I went out to use my car for the first time in at least a month and the battery was dead... so I should do something to prevent that from happening. It was the cheaper chargers that I was more interested in that apply seemingly such a small amount of current, it doesn't seem like it could hurt the batter but I wonder if it will help either or if its just a waste of money.
      sigpic
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Definitely depends on the size of the battery versus wattage of the panel, but I'd say that a "dumb" 10W into a 50Ah battery you will need to water the battery and it could eventually cause damage if you never use the battery. At 10W it's about C/60, which is not horrible but still will cause eventual dry out. If it were a sealed AGM battery with proper recombination, then you won't have to worry about electrolyte loss.
        Ideally you don't go way too much over about 3x the parasitic draw of the battery (for most cars it's 1W or so tops) if you can't regulate the voltage. But a simple shunt or series regulator will be sufficient to deal with water loss, but do keep in mind it's temperature dependent.
        oh btw, a $0 way to maintain your battery if you don't care about ECU settings and less than say 3 months of non-use: just disconnect the battery. If it discharges without it being connected, you need a new battery anyway...
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          this battery is maintenance-free... it claims you can even mount it upside down and it has a 10-year warranty. no water to deal with...
          sigpic
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            what about a simple circuit that cuts off charging when the battery reaches peak voltage?
            sigpic
            • redwire
              • 3912
              A car battery wastes about 4mA just sitting there, due to impurities in the electrolyte. Solar chargers can use many mA as well. The car draws up to 100mA average for the remote RX, canister purge cycle and all that stuff the ECU does when the key is off.
              Lots of outrage over Subaru ECU's pigging out and killing a battery in a couple weeks or less.
              If you only can charge a few hours per sunny day, you'll find you need a fair bit of power to make up for all this load.
              I''m using a mains-powered charge maintainer, it puts out about 14.6V 2A for a top up (equalization) charge then shifts down to float charge 13.8V at a few hundred mA, overnight down to 100mA.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                Sadly, my 350z has to be parked in an outdoor covered parking stall at this apartment complex. Access to power is not an option but a disconnect seems like it might help ... though i would think the battery would still drain over time just perhaps not as quickly..?
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Well in my situation, I am parked outside in a covered stall with no electrical outlets available ... and the only spot for a solar panel would be in the back through the hatchback window and i MIGHT get decent sunlight on that spot for about 6 to 8 hours a day at the most and even that light will be indirect to some degree at certain points in the day.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Check out this gizmo ... only $18 and it looks like it will make sure the battery stays properly charged...
                    sigpic
                    • petehall347
                      • Jan 2015
                      • 4439
                      • United Kingdom
                      might be as simple as moving a fuse to get the lighter socket live with key off .i know some mercedes are like that .
                      as for the charger it should be fine on its own .. if you used a controller that in itself may use any useful power to run it .
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Do not count on indirect sunlight. Must be in full sun.
                        Sigh. Need to get started on my grid tie project for my solar panels - but that's where I found that indirect and cloud occluded light is almost useless light... Cirrus clouds also do a huge number on productivity too... In this case you may well need to overbuy solar cells to make up for the poor lighting.
                        Oh and another benefit of disconnecting batteries: it bewilders and/or annoys thieves, especially if you do it in a way such that they need to bring something else to the table to start the car...
                          • 31191
                          you could just start the car every few days to a week for a while.
                          cheap car alarms on ali-express - the pager type often have remote-start function.
                          • dmill89
                            • Dec 2011
                            • 2534
                            Note the SAE disconnect plug I have is just to plug in a charger not to disconnect power to the car. A disconnect for the car itself will drop parasitic losses, but you'll also loose any saved settings and dynamic ECU maps (also the emissions monitors will be reset, so if you live some place with emissions testing, make sure to go on a few "drive cycles" so all the monitors can run before taking it in for testing).
                            It depends on how good the panel is (which granted a cheap solar charger probably isn't going to have a great panel), I don't charge any car batteries with solar chargers, but I do have a solar system in my shed for lighting consisting of a 20w panel, a 12ah 12v lead-acid battery, and a charge controller, and this panel will still produce around 30-50% of its rated wattage on a cloudy day.
                            This was not a particularly expensive setup (specifically it is this: https://www.amazon.com/dp/B0956QFKVY...roduct_details), though probably still a little higher quality panel than the average "suction cup to the roof" or "throw on the dash" charger.
                            That is similar to the charge controller on my shed (though a bit more advanced with the LCD display and RS232 port), don't count on them meeting the advertised current specs (but a "10A" charge controller should be able to handle the 1A-2A of a small solar panel just fine), but otherwise it seems to work pretty well.
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              Funny you mention that, I was thinking about installing a circuit in the car with a magnetic reed switch such that I would have to place a magnet somewhere before the car would even start. Haven't thought that through yet though, but it would be a great deterrent and this isn't the best area where crime is concerned though it has improved a lot over the years.
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                For $45 that's an impressive report. I'd be willing to spend that to keep my battery charged for sure. Looks like they offer a 10 watt version with a smaller panel for $39.
                                I'm wondering if there would be something I need to do so that when I'm using the car, would there be anything that should be done to protect the charging circuit? Because while the car is running, the alternator would be feeding voltage into the outputs of that charge monitor unit.
                                sigpic
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Do you have direct sunlight for a good portion of the day? Shadows of any kind really kills cell performance. Clouds are not as bad as buildings occluding sunlight even if it "seems" just as bright.
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    I think there would certainly be enough light during the day to keep a panel like that sufficiently energized. I would think that even 5 watts for a few hours a day would be sufficient to keep the battery topped off. I live in southern California and the path of the sun is such that it shines heavily on the rear of the car, though the covered parking does offer some shade, that back end of the car I THINK gets plenty of light but ill have to check that to be sure. maybe going with the 20-watt panel would be enough to at least guarantee 5 watts for a good portion of the day.
                                    sigpic
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      I was thinking of using something like this and connect it to a wire that is energized when the ignition is turned on so that it would disconnect the charger while the car is running.
                                      sigpic
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        So I got the same setup you have using the link you posted ... I got the 20 watt panel with the charge controller... the instructions are total crap, so I wanted to post this photo and make sure that I'm reading all this properly...
                                        So Im going to connect the solar panel to the SC ports, and the battery, I'm going to connect to the center ports but I'm going to connect the hot lead through a normally closed relay where the relay is actuated when the ignition key is in the on position. This should guarantee that the system is not connected when the alternator is running. And that last set of ports I'm going to just remove those wires since I wont be using them for any lighting of any kind... does that resonate with how you have yours hooked up in terms of properly identifying the ports?
                                        sigpic
                                        • Petr0x
                                          Bosch 12V and 18V chargers modification
                                          by Petr0x
                                          Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                          You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                          Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                          05-24-2024, 01:00 PM
                                        • Techie_hobby1
                                          Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
                                          by Techie_hobby1
                                          Need some help please with a few components on this small board so that I can troubleshoot the circuit.
                                          The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
                                          J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
                                          J2 - to DC Output
                                          J3 is Battery cell connector
                                          however I am struggling to identify if:
                                          Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
                                          07-24-2025, 12:43 PM
                                          MPPT 60AMP Solar Charge Controller 12V 24V 36V 48V DC Battery Regulator Testing results on 12 volts
                                          by sam_sam_sam
                                          I bought one recently but this is the first weekend that I did not have work Saturday morning or the sun did not want to cooperate with me but today it is coordinating with me and I run a very simple test on a 12 volt battery pack and it stop charging ar 14.4 volts
                                          Here is the website link where I bought it from
                                          https://www.ebay.com/itm/395434828814
                                          I ran this test with a new 12 volt solar panel that has a no load voltage of 19.0 and an output current of 9.1 amps
                                          I do not remember the starting voltage but the charging amps was 1.4 amps
                                          09-14-2025, 11:49 AM
                                        • Cama
                                          Solar Inverter - SMH-II - 2 missing capacitors
                                          by Cama
                                          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                          My model is : EASUN SMH-II 7 KW
                                          Mother Board : P/N 18947-002401250250
                                          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                          Thank you...
                                          09-12-2025, 02:50 AM
                                        • eccerr0r
                                          Sell or Shim Solar panels?
                                          by eccerr0r
                                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                                          So now what to do with these small panels?
                                          I could sell them...
                                          Or I could shim them....
                                          03-29-2025, 01:07 AM
