Short theory
+ More Options
Posts
  • TheAnswer305
    • Aug 2021
    • 16
    Short theory
    Hi guys, so i am in the process of repairing a couple motherboards and ive come across something that im not quite understanding. Maybe you guys can help me out.
    So i am checking the motherboard and find i have several areas of caps that have a short to ground, being that both sides give continuity when testing against a ground pad. Now i know this might be okay for some caps but this is a lot of caps doing this so im thinking theres a short. So i injected a small amount of voltage on a larger cap. I sent it in at 3v 1a to be safe and low, i saw some mosfets get hot and the bench shows it pulling 1.1v @ .8 amps. They also light up on the flir so i pulled them off. Now the delivery goes to 3v @ .03 amps so im thinking the short is gone becuase the voltage is flowing and only consuming whatever items are on the line take, however, i still get short to ground on the caps.
    Am i understanding that when the voltage doesnt get dropped it means there is no short, or is it that there isnt a BIG enough short to cause heat.
    In this scenario, how do you locate it?
    • 30978
    Re: Short theory
    next time, dont go over a volt - a lot of cpu's and ram now run at 1.2v or 1.8v
    • TheAnswer305
      • Aug 2021
      • 16
      Re: Short theory
      Thanks. Yes I read this somewhere and started going at 1v. However, given that the bench doesn't limit and show less volts, it means there's NOT a short right? But why do I have continuity on so many caps from ground?
        • 30978
        Re: Short theory
        caps can look shorted while they charge.
        • TheAnswer305
          • Aug 2021
          • 16
          Re: Short theory
          They are showing continuity with ground even without power though.
            • 30978
            Re: Short theory
            wrong, your meter is supplying power.
            thats how it works, it applies a current limited voltage - usually 2-3v and calculates resistance from the volt-drop
            • TheAnswer305
              • Aug 2021
              • 16
              Re: Short theory
              Okay the definitely makes sense, thanks! Would that voltage cause all caps to show continuity on both sides of the caps? from what ive usually seen itll only sound on both sides if a component is giving a short somewhere
              • TheAnswer305
                • Aug 2021
                • 16
                Re: Short theory
                As a follow up, is there degrees of shorts? Can i have a short that wont get hot but is still grounding the power rail? i thought all shorts would end up showing on the flir.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Re: Short theory
                  Are you measuring in resistance mode or continuity ?
                  • TheAnswer305
                    • Aug 2021
                    • 16
                    Re: Short theory
                    Continuity mode, well on this mode it beeps if it goes under 50ohms i think, but it also displays resistance. So it might just be resistance mode with the little continuity beep on my particular meter. I can also check without the beep but readings are basically the same just having the beep is the only difference.
                      • 30978
                      Re: Short theory
                      test, then test with the probes switched.
                      if it's charging caps then you will see a jump in readings for a second
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8696
                        Re: Short theory
                        If this is the short theory, what's the long theory?
                        (ugh this thread's topic name "short theory" bothers me...)
                        • TheAnswer305
                          • Aug 2021
                          • 16
                          Re: Short theory
                          long theory is i cant find a short and dont know how unless i start pulling everything off lol
                          • playit
                            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                            by playit
                            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                            09-02-2023, 02:43 AM
                          • MisterAIL
                            820-00840 / No boot / PP3V3_G3H Short to ground
                            by MisterAIL
                            Firstly sorry for my english, french guy inside.
                            I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                            History is a day, nothing happened when opening the laptop.
                            Nothing special inside, no corrosion, no liquid damage, never opened.
                            First, with the logicboard alone on the desk, mesures are :
                            5v017 and 0.000 amp. nothing else.
                            Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                            10-13-2021, 11:42 AM
                          • triplefour
                            Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                            by triplefour
                            Samsung UN55ES7003
                            made house call.
                            red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                            psu has self test feature.
                            disconnected from mainboard.
                            determined PSU ok BL ok.
                            suspect mainboard.
                            disconnecting tcon has no change on operation.
                            markings on mainboard:
                            BN97-06531P 0151
                            BN94-06123R
                            found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                            for 54$
                            second house call:
                            with replacement mainboard, tv turns on, has sound,...
                            07-13-2022, 03:53 PM
                          • Prott
                            PS5 - long screw damage, via to ground layer short?
                            by Prott
                            Hello dear Badcappers,
                            I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
                            Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
                            07-27-2024, 08:54 AM
                          • DynaxSC
                            Extreme High Current & Low Voltage Short Killer ??
                            by DynaxSC
                            Hi Folks
                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                            After taking off the socket, the shorts dissappear again.
                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                            10-15-2024, 10:13 AM
