Weak ultrasonic cleaner machine.
  • Wizard
    • Mar 2008
    • 2296
    Checked all the components. This is simple circuit only one transistor and several diodes, four capacitors and number of flame-proof resistors. I did use capacitance meter to check actual value of these capacitors (three caps is polyester and one ceramic disc, none have electrolytic).
    When working properly the liquid surface should be jiggling vigorously which it did intermittently, all I get is very faint shimmer (most of time). Twice time I had had unit's liquid surface jiggling with vigor and I put test objects to test and after withdraw it, just barely a shimmer. And other time was jiggling merrily then it suddenly flattened out to a faint shimmer. Dang.
    Measured 30-33KHz with my fluke multimeter (it can measure up to 100KHz and had no problem seeing 15.7KHz before on CRT tv as well as 31-33KHz CRTs.) , should be 55KHz oscillation riding on 30hz bursts (which is correct on scope but oscillation is not at 55KHz) because of one diode supplying AC pulses to the oscillator circuit. I even moved the wire on the transducer with new spot of silver bearing solder, just in case.
    I even exchanged ceramic disc that measured 360pF (should be 330pF (code 331) with no difference.
    Then what now? Transducer shot? This one is solidly bonded to the pot's bottom. Note I always kept liquid filled in the pot while testing runs and probing it's innards.
    Background: when unit came in dead, all it had was open 1 Ohm 1W resistor, not even overheated at all, fuse intact. That feeds 115VAC thru this resistor to the one diode (forward-biased) feeding half the sine waveform to rest of the circuit.
    Please talk.
    Cheers, Wizard
  • PlainBill
    • Feb 2009
    • 7034
    Re: Weak ultrasonic cleaner machine.
    Please talk.
    Cheers, Wizard
    Ultrasonic cleaners. That takes me back to the dawn of my involvement in electronics. I suspect the circuit is designed to oscillate at the resonant frequency of the transducer. Way back when I was told it was a no-no to let anything touch the bottom of the pot, it could damage the transducer. Items to be cleaned were to be suspended in a basket. The symptoms you describe sure match what I saw.
    PlainBill
    • Wizard
      • Mar 2008
      • 2296
      I did suspend the items as test not touching the bottom.
      Go on.
      Cheers, Wizard
      • PlainBill
        • Feb 2009
        • 7034
        Go on.
        Cheers, Wizard
        Well, 40 years ago the verdict was 'unrepairable'. I have no idea what (if anything) has changed in this area.
        PlainBill
        • Wizard
          • Mar 2008
          • 2296
          I'll wait for other replies too.
          Cheers, Wizard
          • Toasty
            • Jul 2007
            • 4171
            Sounds like the transducer has a hairline fracture. Same as a piezo speaker or mic that takes a good whack somewhere.
            http://www.ecrater.com/product.php?pid=2073673
            Hot or cold solution make any difference? Freeze spray or hair dryer? Tapping on it?
            Toast
            EDIT: Duh! Forgot. Measure capacitance of element when working right and not.
            veritas odium parit
              • 31138
              seconded - check the ceramic isnt cracked.
              and if it's looking o.k. resolder the wires to it at both ends.
              i'v seen solder crystalise once - really strange thenomenon.
              it looks almost normal but hardly conducts - till you reflow it or scrape the surface with something!
              • Wizard
                • Mar 2008
                • 2296
                Capacitance check on the transducer? Interesting throught, and I happen to have capacitance meter.
                Cheers, Wizard
                • Toasty
                  • Jul 2007
                  • 4171
                  Any luck there Wizard?
                  veritas odium parit
                  • Wizard
                    • Mar 2008
                    • 2296
                    Transducer is the problem, since it is bonded to the tub, not replaceable. Scoped and got good waveforms.
                    Cheers, Wizard
                    • itsthatidiotagain
                      CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
                      by itsthatidiotagain
                      CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
                      There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
                      I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
                      A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
                      06-23-2025, 03:22 AM
                    • tricky74
                      Chinese no brand ultrasonic cleaner
                      by tricky74
                      I bought an ultrasonic cleaner from ebay and after a couple of years it blew one of the driver boards fuse and a couple of diodes. I replaced the parts and it worked for a while then died again. Since then I have thrown out the board and just use one. The unit had 2 drivers and the good one drives 1 transducer only. The fried board was driving 2 transducers. The unit works on 1 transducer but is weak in power. I am tempted to connect the 2 transducers that were driven by the dead board. And leave the single disconnected. Not sure if it there is a fault in them and will just kill the driver. As...
                      07-01-2022, 06:20 PM
                    • diif
                      Ultrasonic cleaner but a bit faulty.
                      by diif
                      After a not very cool noise and the display dimming my ultrasonic cleaner powered off. The display and fan work, just nothing happens when I press the ultrasonic button.
                      I think it's at least the triac that is at fault (on the small PCB), showing 57 ohms between pin 1 and 3 and possibly one of the relays (marked in red), I was hoping someone might advise. Thank you....
                      09-01-2020, 07:04 PM
                    • AlexVG
                      Replacing the WiFi module on a vacuum cleaner iROBOT i7
                      by AlexVG
                      I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                      I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                      (This board does not respond, only the LEDs light up in a circle.
                      The liquid damage is catastrophic and restoration is impractical).
                      (I bought this board to get the WiFi module and camera).
                      The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                      If...
                      10-22-2024, 07:20 AM
                    • Tyroonis
                      Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
                      by Tyroonis
                      I have a robot vacuum cleaner here.
                      An Eufy Robovac L70 Hybrid.
                      A chip has burst due to a short circuit.
                      The following is legible on the chip:
                      Mpsm44
                      m2612
                      883138
                      I'm not sure if there is another number after m2612, as that's exactly where the hole is.
                      Can anyone help me identify what this component is?
                      Unfortunately, I couldn't find anything.
                      I also don't have any plans or board views of the...
                      08-14-2025, 02:32 PM
