Battery Hacks
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Battery Hacks
    9v battery hack
    http://www.youtube.com/watch?v=tr5ZB1eFhwc
    12 Volt Battery Hack
    http://www.youtube.com/watch?v=QxS38_u7Mnw
    hmmmm
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Battery Hacks
    thats how i get aaaa cells for my streamlite penlite.
    and i have used the a23 trick as well to get cells for cheap laser pointers.the video showng a shitload of aa cells in a 6v is fake.those have 4 f cells or in cheap ones 4 d cells and a spacer.
    • trebo
      • 514
      • Wales, UK
      Re: Battery Hacks
      Originally posted by willawake
      I roared after finding this after watching your links
      http://www.youtube.com/watch?v=s_8n2Qgguto&NR=1
      • skystormfarms
        Banned
        • Mar 2011
        • 160
        Re: Battery Hacks
        o ya i have a you tube channel SKYSTORMFARMS channel i am going to make some vids like that
        • Krankshaft
          • Jan 2007
          • 2328
          Re: Battery Hacks
          Yeah I remember posting about the A23 battery hack awhile back.
          9v batteries don't have AAAs in them they are actually quadruple As or AAAA batteries. When fully charged they should measure around 1.5 volts.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
            by ferah831208
            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
            03-18-2025, 01:18 AM
