charging Li Ion Batteries via USB on MoBo/Laptop
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys.
    I got myself so obsessed with fast charging reading that in long term it can a lot shorten battery life/capacity.
    So I thought why not to charge via USB headers on MoBo or laptop.
    Yeah it's painful slow,but in order to preserve battery capacity/health in long term is that a better solution?
    After all it charges with less current (1-2 Amps).
    I noticed when using genuine charger with my S5e battery now lasts me shorter then before,and I did only 18 charge cycles.
    I used fast charging all the time,but I have a bad habit when not using tablet I swtiched it off most of the time it's off,and maybe those devices like more when they are ON then OFF for the health of the battery?
    Maybe there is an issue.
    I have OCD so I overthink this too much,sorry.
    Can anyone explain me if I'm correct or wrong?
    • Jul 2011
    • 6070
    Re: charging Li Ion Batteries via USB on MoBo/Laptop
    Over charging batteries depends on the charger as long as the batteries do not because warm it should not be an issue however wherever the batteries are made is a very big issue
    Chinese made batteries are hit and miss in quality (more often they are a miss )
    Korean made are also hit and miss in quality ( about 50/50 is a miss )
    Japan made batteries are the best as in quality ( most of the time you get what you pay for )
    These are solely my options and are to be taken as such
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • orientalsniper
      LA-L246P Not Charging Batteries
      by orientalsniper
      Hello all, I've tried multiple batteries, replaced the charging IC (ISL95522AHRZ) and updated the BIOS.
      It detects the power adapter (90W), so the DC IN jack is okay.
      It shows "IDLE" instead of "Charging", battery health shows "Excellent" on the BIOS.
      09-15-2025, 02:29 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • Wang Tingting
      Acer Nitro 5 AN515-57-536Q not charging
      by Wang Tingting
      I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
      report is also good for battery.
      Following https://www.badcaps.net/forum/troubl...arging-circuit,
      • DCIN/VCC: 19.1
      • ACIN/ACDET: 3v
      • REGN/VDD: 6v
      • CMSRC : 19v
      • ACOK: 3.3v
      • ACDRV: it is 19v, not 25V(when charging, the ACDRV
      09-10-2025, 01:46 PM
