Kind of a different question...
  • EasyGoing1
    replied
    Re: Kind of a different question...
    Originally posted by stj
    your meter is not showing it right - i'v seen that with flukes before, i think they filter out high frequency stuff.
    60 Hz is ... high frequency?
    replied
    Did you set to AC Micro Amp scale?
    replied
  • EasyGoing1
    replied
    now test the current .
    im getting ZERO for amperage
  • petehall347
    replied
  • EasyGoing1
    replied
    Originally posted by budm
    Use your AC Volt meter to measure the Voltage between AC outlet ground and the metal part of the Macbook.
    Plug the Macbook power supply into the GFCI outlet then use your AC Amp meter between outlet ground and the metal part of the Macbook to see how much current you are seeing.
    This is how much Apple Euphoria I'm getting from my laptop right now... that's from the ground port on the wall socket and the part of the laptop where I often rest my palm.
    replied
    replied
    apple: "that's not electricity your feeling, it's euphoria from the joy of owning apple"
  • petehall347
    replied
    might be worth asking apple what to do ..or maybe first ask if you should be feeling electricity on the metal parts .
  • TechGeek
    replied
    As in infinite resistance or 0 resistance?
  • EasyGoing1
    replied
    Originally posted by TechGeek
    Can confirm that the metal stud is grounded. Connect a grounded Apple charger cable to it and your problem should be solved.
    I'm not so sure about that. This PSU is from a 2019 MBP and when I did a continuity check between the metal stub and the chassis of the laptop, I got nothin.
  • TechGeek
    replied
  • EasyGoing1
    replied
    Originally posted by eccerr0r
    The magic smoke leaked out of this one ... https://www.badcaps.net/forum/showthread.php?t=94756 seems that round button is connected somewhere.
    You might be right ... unless this wire is coming from the transformer ...
  • EasyGoing1
    replied
    maybe you can just replace the 2pin socket with a cloverleaf style
    That's a good idea ... I'll have to see what I'm dealing with once I get the PSU apart. The default configuration of the PSU is an adapter with just two prongs sticking out... no power cable at all... and the PSU is so big and heavy, plugging it into a power strip that way is useless.
    replied
    no, they are just using the backing to secure a thermal fuse.
  • eccerr0r
    replied
  • eccerr0r
    replied
    if it's a true ground pin why doesn't #%&*$ offer a 3 prong head for that charger?
    But even if they do, where's that Y capacitor? Is it in the head?
    replied
  • EasyGoing1
    replied
    the metal in the socket bit is probably just for strength.
    meter the resistance between that stud and the macbook body with the charger connected.
    Big goose egg ... but I can still connect a wire to it on the inside of the PSU and use it as my point of entry.
    replied
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
