Finding appropriate datasheet or equivalent MOSFET
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    I'm trying to find an equivalant MOSFET of the following:
    https://www.ruten.com.tw/item/show?21532307398856
    I'm not able to find a datasheet for this A2719 MOSFET, and I'm not sure if this is equivalent http://www.datasheetcatalog.com/data...PA2719GR.shtml
    Can you pleas confirm that A2719 M mosfet is actually UPA2719GR?
    Thank you!
  • redwire
    • Dec 2010
    • 3912
    Re: Finding appropriate datasheet or equivalent MOSFET
    It seems to be NEC uPA2719 P-ch -30V 20.9mohm (-4.5VGS) 2W, ESD gate diode
    Newer parts have better (lower) on resistance but hard to find with them with an ESD protection gate-zener diode. Alpha&Omega do not have much for P-ch and none have a ESD gate zener diode.
    Later parts like Renesas uPA2736-2738 (no zener), NEC uPA2718 are improved
    Not sure if the original has thermal pad Power SO-8 or not.
    • tofik
      MOSFET equivalent K8A60DA
      by tofik
      Hello guys,
      I have a shorted MOSFET K8A60DA with the following characteristics:
      Type Designator: TK8A60DA
      Marking Code: K8A60DA
      Type of Transistor: MOSFET
      Type of Control Channel: N -Channel
      Maximum Power Dissipation (Pd): 45 W
      Maximum Drain-Source Voltage |Vds|: 600 V
      Maximum Gate-Source Voltage |Vgs|: 30 V
      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
      Maximum Drain Current |Id|: 7.5 A
      Maximum Junction Temperature (Tj): 150 °C
      Total Gate Charge (Qg): 20 nC
      Rise Time (tr): 25 nS
      Drain-Source
      07-19-2023, 05:18 AM
    • dreico33
      AON7403 Mosfet Equivalent
      by dreico33
      Hellow guys,
      I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
      Thank you very much.
      11-16-2024, 09:28 AM
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • calipso99
      4C10B Mosfet datasheet (?)
      by calipso99
      Hi, cant find a datasheet for a 4C10B mosfet, where could i find one? the only datasheet ive seen so far are for the 4C10N mosfet.
      11-11-2023, 08:00 AM
    • mohamed mm
      looking for equivalent mosfet for (IR3598MTRPBF)
      by mohamed mm
      I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
      it's for motherboard ram voltage.
      I hope someone can help me.
      Thank you.
      11-01-2023, 07:28 AM
