choosing new battery bms
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    i have an e bike battery pack in need of a new bms .the old one went up in smoke . its a yamaha one .
    was wondering if a say a cheapo 30 amp one would do it ? and would it be possible to use the original working charger as it has 4 connections .
    can post pics later if needed .
    • Jul 2011
    • 6070
    Re: choosing new battery bms
    Please post some pictures of this BSM balancing protection board that you have maybe there might be one that would work correctly you might be able use some of what you have with some modifications
    ( using your charger to a new BMS balancing protection board )
    I would probably recommend a 100 amp one for more headroom if I were doing this repair and upgrade it for more amperage capabilities
    If you would post what voltage and what type lithium ion batteries that are being used I would help you find one
    I have watched some of his videos in the past and he has some good ideas about this topic
    https://www.youtube.com/watch?v=rT-1gvkFj60
    Here is another video which is very interesting
    https://www.youtube.com/watch?v=b2sBhDxmPmA&t=0s
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      agree that probably need higher amperage, at 30A without knowing more details probably doesn't have enough capacity for motor starts (though the motor control board may soften this spike...) 30A sounds like less than 1HP which is probably ok for quarter HP motors depending on voltage.
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        its a 10s battery pack .the old bms pcb is a total wreck . i will get details of the bike off the owner . as i don't have it here .
        will post pics later .
        • petehall347
          • Jan 2015
          • 4448
          • United Kingdom
          some pics
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            30A probably would work IMHO for most cases at 10S but only if the motor was rated for around 1HP or less.
            As for the original charger, who knows what the extra wires are for...need to do research...
            Looks like the batteries took a bit of a bite there... ooh that doesnt look good...
              • Jul 2011
              • 6070
              I would highly recommend that you carefully check each cell for voltage and amperage output I have a feeling that you might have battery issues as well
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                yep i had found a shorted fet and blown double thermal fuse but wanted to see the other side of the board and it decided to self destruct whilst removing solder from the tabs . yes i realise now i should have disconnected the main +- first .even so it still could have done that . guessing it was a bit of solder shoerted it .. scared the shit out of me as i had to pick it up and take outdoors whilst fire was shooting out of it . wish i had a vid of it but didnt have time for that .
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  the pack seems fine all balanced for voltage .
                    • Jul 2011
                    • 6070
                    If you are going to look at a BMS balancing protection board you need to desolder ( or cut the tabs to the board if you can safely ) the batteries from the board before you start trying to look at it or troubleshooting it
                    I hold my breath every time I work on these type of board and batteries because I know shit can go very wrong in a hurry
                    So did fry the the batteries as well “ whilst removing solder from the tabs. ” this might mean that it pressure release from the internal pressure of the batteries and they might not be very good anymore ( because it happened to me once and the voltage was still there but the battery would leak fluid from the positive side of the battery
                    What is the voltage on the plus and negative terminals of the battery pack
                    Because I am confused about the configuration of this pack because correct me if I am wrong but I counted 36 batteries and if this count is correct then it could not be 10s
                    • petehall347
                      • Jan 2015
                      • 4448
                      • United Kingdom
                      its 36v ..
                      bike is a haibike ..yamaha motor ..from what i can find the most it will be is 500w . most are 250w . will know for sure when i hear back from the owner .
                      • petehall347
                        • Jan 2015
                        • 4448
                        • United Kingdom
                        ok its a 250w motor .. ebay ad says 30a is good for less than 1000 w . no idea if that figure is inflated somehow like they do .
                        oh the battery is 400wh .
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          this is the bms i am looking at ..what do you folks think ?
                          https://www.ebay.co.uk/itm/10S-36V-3...IAAOSwAK5gCU4p
                            • Jul 2011
                            • 6070
                            I would think so but I would consider putting a fast acting fuse for maximum current including inrush current just in case of failure of the BMS balancing protection board or put individual fuses on each cells
                            There are videos on you tube that shows how some people are doing this concept
                            Or get a 50 amp BSM protection balancing protection board for add safety
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              I think 30A @ 36V is enough margin for 250W even with inrush, but I think the "throttle" control should deal with inrush for you actually.
                              Kind of funny people would play with 10S3P packs and not with a quart of gasoline ...
                              (I think the quart of gasoline is still contains more energy than 10S3P pack?)
                              • petehall347
                                • Jan 2015
                                • 4448
                                • United Kingdom
                                bms arrived today and its pretty small . will fit it anyway and see what the charger thinks of it .
                                • petehall347
                                  • Jan 2015
                                  • 4448
                                  • United Kingdom
                                  as suspected with new bms wired in it doesnt charge ..i have another battery pack here that is a copy one . i was trying to find the same bms as fitted to that one but cant find one . i have pics of the wiring . will post below .
                                  black blue green red go to the charger port .
                                    • Jul 2011
                                    • 6070
                                    Is this the type of charger that requires voltage from the battery to activate the charging circuit
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      it looks that way .
                                      even if i get it charging i dont know what to do about the data wire that goes to the electronics from the battery .
                                        • Jul 2011
                                        • 6070
                                        it looks that way .
                                        If it has this it would not be useful unless you disable this part of the circuit
                                        Can you find output side of the power supply to bypass this part of the circuit
                                        Or just get a switching power supply that can limit current and voltage and be done with it
                                        Some of these chargers use a temperature sensor device for monitoring the temperature unless it also monitoring the voltage and current algorithms some way if it this type you do not have a very good chance of getting this to work correctly
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
