backlight tester malfunction
  • stinger
    • Jan 2014
    • 57
    • usa
    I purchased a DLV-300 LED Backlight Tester a short time ago and tried it on a couple of led strips and it seemed to work fine. It would start at 300v and when testing the led's, it would adjust to the voltage needed to light them.
    I then went to use it while diagnosing problems with a tv set I have and at first the tester worked properly and lit up the first led strip and then lit up half of the second strip. But when I proceeded to find which leds were bad I noticed the tester wasn't working right. It only reads 17v then slowly goes up to 20v max. Does anyone have experience with these testers or have have any ideas what could have happened to it?
  • redwire
    • 3910
    Re: backlight tester malfunction
    I sounds like the HV boost converter has stopped working.
    If you can post clear pictures of the inside and both sides of the PCB, can figure it out.
    • stinger
      • Jan 2014
      • 57
      • usa
      I will take some pics tomorrow, thanks
      • cheeky2
        • Dec 2012
        • 337
        The high voltage is normally present when you don't have any leads connected to any leds. Once you have leds connected then the voltage drops down low and gradually ramps up to a level where the leds will turn on and gradually get brighter. I suspect nothing is wrong wih it but your expectations of how it works?
        Led's strips can be paralled giving you a lower voltage than you expect. I suggest you take pictures of your led's testing as I would suspect misoperation. Who knows I maybe wrong?
        • R_J
          • 9544
          I don't think you read the whole post, He said it WAS working and supplying 300v when testing the strips and NOW only shows 17v~20v
          I suspect the unit has a poor solder connection inside and that has stopped it from working, but he has not provided any pictures, so we can't help him until he does.
          • cheeky2
            • Dec 2012
            • 337
            You should only get a 300V output when either the leds are open circuit or there is no continuity with the leds ie a brake in the connector. I know of no other leds that will give you this output from a led tester with good leds inside the TV. It would require over 100 3v leds or over 50 6v leds. I know of no TV with this ammount of leds so that's why I came to the conclusion I did. My led backlight tester operates only at 320V when open circuit or reversed leads. It should never start off at 320V with leds connected for obvious reasons.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              switch it off and back on ..it fixed mine once .
              • R_J
                • 9544
                So what do you do? connect the tester to the led string THEN turn it on? The testers I have used, "display" a high voltage, then as soon as the string is connected the "voltage display" drops to the voltage to deliver about 30ma of current to turn on the string. and displays the output voltage.
                Here is the quote from the original post
                Then the tester developed a problem
                He likely has a problem with the boost circuit inside the tester.
                • redwire
                  • 3910
                  It seems 325VDC is available with open-load, which normally would damage an LED if connected backwards? It starts at low current and slowly ramps it up.
                  https://youtu.be/IuHZBE2NP7c?t=274
                  He takes it apart, and backwards on a little 0603 it reads ~145V. Hmmm.
                  • R_J
                    • 9544
                    When the leads were backwards there was very little current flowing so the voltage dropped to 145v, when it was the right way around, the voltage dropped to 2.7v because there was current flowing (30ma?) Nobody measured the voltage at the test leads.
                    • stinger
                      • Jan 2014
                      • 57
                      • usa
                      I'm sorry, Due to family med emergency I have been unable to get back here. To confirm, when I received the tester it would power up to 300v with test leads open and adjust accordingly when load was applied. Now it powers up to 17-20v max when turned on with no load at test probes. I took pics of circuit board and will post them.
                      • stinger
                        • Jan 2014
                        • 57
                        • usa
                        Pictures are not too clear.
                        • stinger
                          • Jan 2014
                          • 57
                          • usa
                          Hope these are clearer
                          • R_J
                            • 9544
                            I would check the mosfet? near the red output plug, then check the diodes in that area. Also check for any poor solder connections.
                            If you only had the tester for a short time, contact the supplier and tell them, maybe they will replace it for you.
                            • stinger
                              • Jan 2014
                              • 57
                              • usa
                              The mosfet seems to be bad(open) and one diode seems shorted, but I will unsolder it and check out of circuit. I will order and replace those parts. Thank you. The supplier wasn't too cooperative even though the tester is only about a month old and only used twice.
                              • R_J
                                • 9544
                                If the diode checks shorted, It could be all that is wrong, the mosfet might be ok. Can you show which diode is shorted?
                                • stinger
                                  • Jan 2014
                                  • 57
                                  • usa
                                  It is the one with yellow arrow pointing to it, next to D3. There is no value marked on it.
                                  • R_J
                                    • 9544
                                    I can see that there IS a marking on that component, but I can't make it out in your picture, Could be a 1 amp schottky diode OR something else, What is the board designation? You can clean the top of the component with alcohol to see the number better.
                                    • stinger
                                      • Jan 2014
                                      • 57
                                      • usa
                                      I looked closer with loupes and see it says US1M. All 4 in that area are the same.
                                      • R_J
                                        • 9544
                                        1.0A 1000v SURFACE MOUNT ULTRA-FAST RECTIFIER
                                        • tmhobadcap
                                          TCL 65S403 Backlight LED Question
                                          by tmhobadcap
                                          I got the TV from a friend. He claims that no image but sound from the TV.
                                          I confirmed that when shine a flashlight on to the screen, I can see the image. And this should be backlight problem.
                                          I open up the TV and found a few leds failed. And now I am ordering a new set of backlight strips for it.
                                          But there is something that I do not understand when checking the leds. I do not have an led tester. I only use a bench power supply. I first set the voltage to 3V and current to 10mA. I could not light up the led until I increase the voltage to 12V. I understand most...
                                          05-25-2025, 11:03 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • DoOm86
                                          philips 55pft5500/12 Backlight issue. What am I doing wrong?
                                          by DoOm86
                                          TV philips 55'' no backlight (image ok).
                                          I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
                                          What am I missing?
                                          And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
                                          04-16-2024, 03:47 PM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
