Help identifying sot23-5 ic
  • cheeky2
    • Dec 2012
    • 337
    I have an Autek IFIX919 diagnostic kit that an ic has failed on the 5v input line from the usb port. The ic is labelled up as A17O2 or A1702
    The pin designation from this are as follows:
    Pins
    1 = Not sure
    2 = GND
    3 = 3.3V output line
    4 = 5V input from the usb port
    5 = suspect a feedback line
    I have looked up for the smd code but cannot find anything suitable.
    It could be LDO voltage regulator 3.3V
    Basically the gnd and 5V has a short across it of around 26ohms.
    The ic is marked up as U4 which has been highlighted in a red box.
    I have been looking at the output and the pcb I have traced goes to an 3.3V line.
    Any help would be appreciated in identifying would be great.
  • R_J
    • 9579
    Re: Help identifying sot23-5 ic
    It might be a M3406.
    • cheeky2
      • Dec 2012
      • 337
      Fantastic I am looking at the ic now and it certainly looks promising. I am going to draw the circuit out and work out the suitability of it and check the resistors networks out to see what the output voltage is going to be.
      I must say I have been looking through loads of 3.3V regulators but the pinouts didn't match anything like it at all. Yet so far this looks extremely promising.
      I will let you know how I get on with it.
      I appreciate you spending the time helping me out
      Take care
      Regards Anthony
      • flcs2020
        Banned
        • Mar 2021
        • 4
        • china
        I search on some place by part of your marking code "A17"
        got below's detail for SOT23-5
        Smd Code Part No. Manufacturer Package
        A17 CLC406AJM5 Nsc SOT-23-5
        A17 XC6114A238MR Tor SOT-25
        A17 RP110N171B Ric SOT-23-5
        A17 XC6365A172MR Tor SOT-25
        A17 XC6367A172MR Tor SOT-25
        • cheeky2
          • Dec 2012
          • 337
          I am fairly convinced that R_J ic is the correct one as the values of the resistors in circuit give you 3.3V and the ic enable pin 1 is also connected up via a 10k resistor.
          By tomorrow I should be able to confirm this as I have found a slightly lower current ic 600ma that is available in UK whilst the other 800ma ic's are ordered from China. The specs and pinouts are the same as I have checked the datasheets. I will fit the ic tomorrow and should hopefully have it up and running again.
          So watch this space for the results....
          • R_J
            • 9579
            I think flc2020 is just taking that info from one of the smd code books or one of the online sites.
            • cheeky2
              • Dec 2012
              • 337
              Indeed
              Anyway good news just had success in replacing the ic and now the kit is fully functional.
              Just a quick question how did you go about finding the ic? Was this through experience or was there another method of working this out. I ask as it would help me in future to quickly find items that have only markings on the ics. Obviously I looked online for the part but without the success you have had.
              I am always looking to learn new skills and techniques.
              My friend who I am repairing this for will highly delighted with the results.
              Thanks R_J for your time and effort involved as it is certainly appreciated
              • R_J
                • 9579
                Good to here it is fixed.
                I usually start with the case type and start looking for the marking code, It can be hit and miss with these smd components, sometimes they use the same markings for different components. A lot is also from experience, I have seen some of these parts before and know what is the part code and what is the date code.
                There are smd code books on line that can help with some parts but not all. and sometimes the manufacturer has there own custom number which can be a custom part of a common part with their number.
                • cheeky2
                  • Dec 2012
                  • 337
                  Yes I looked through the pdf code books online without finding any relevant matches. Then started looking for voltage regulators with 3.3V of that packages. Experience counts, generally I can find most of them but occasionally I come across the odd one which stumps me.
                  Take care.
                  Regards Anthony
                  • cubytus
                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                    by cubytus
                    Hi to all,
                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                    01-10-2024, 01:26 AM
                  • otaku_nut
                    Vizio E701i-A3 fixed but now has red vertical line
                    by otaku_nut
                    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                    08-19-2025, 06:11 PM
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
                  • FALKLAN
                    Running Line Voltage and Integrating LED Pods - Automotive
                    by FALKLAN
                    Howdy everyone! I hope all is well where ever you are!
                    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                    02-05-2025, 12:30 AM
                  • mindoverflow
                    ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                    by mindoverflow
                    hello,
                    there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                    I changed pads and thermal paste.
                    I run mats test but it is reporting 0 errors.
                    I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                    After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                    02-09-2022, 03:22 PM
