cleaning dielectric from a blown cap and identifying caps
  • cgray1497
    how would you go about cleaning dielectric from a blown ceramic capacitor?
    the dielectric is white.
    also i'm having some trouble identifying the capacitance. they are blue ceramic hi voltage capacitors that say:
    472M
    250V ~ x1y1
    400V~C
    and
    102M
    250V ~ x1y1
    400V~C
    I read on a different post that the letter is sometimes used to indicate the tolerance? for instance
    27J 3kV would be a 27pF with 5% tolerance
    • 31277
    Re: cleaning dielectric from a blown cap and identifying caps
    1st line is capacitance,
    1st 2 digits are numbers, 3rd is multiplyer.
    472 = 47 + (2 x 0)
    4700
    4.7nf
    2nd line is working voltage and safety rating - in this case "x1"
    *always use the same safety type*
    3rd line i would ignore, i think it's just peak rating.
    • Wizard
      • Mar 2008
      • 2296
      Actually, electrolyte.
      Cheers, Wizard
      • Radio Fox
        • Jan 2010
        • 281
        Originally posted by cgray1497
        ...I read on a different post that the letter is sometimes used to indicate the tolerance? for instance
        Usually:-
        J=+/-5%
        K=+/-10%
        M=+/-20%
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • Radio Fox
          • Jan 2010
          • 281
          Cheers, Wizard
          Ceramic capacitors don't contain electrolyte.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            without a pic i will guess it was tacked with rtv.peel it off.
