Help substituting avalanche diode
  • Bibdid
    • Jun 2019
    • 10
    repairs on an old CRT tv from the 80s that blew a flyback have led me to this diode which is reading near 0 in both directions. The diode is marked as an R2KY avalanche diode but is no longer manufactured.
    I am fairly new to the world of electronics, could anyone help me source a suitable modern-day equivalent diode?
    The datasheet of the diode can be found from
    https://datasheetspdf.com/pdf/220430...ctorInc/R2KY/1
    many thanks : )
    • 30941
    Re: Help substituting avalanche diode
    do you have a schematic to show where it was used?
    • R_J
      • Jun 2012
      • 9518
      You can get one from here: https://www.ebay.co.uk/itm/R2KY-ZENE...-/192164981448
        • 30941
        NIKKO??? good luck.
        that guy is down the road - he is hardly open and often exagerates stock.
        but you may get lucky.
        • Bibdid
          • Jun 2019
          • 10
          unfortunately not. The tv is a Mitsubishi ct 2043B although it seems to be really obscure.
          The diode is connected to a voltage regulator. I will have a look at making a schematic in the next few days : )
          • Bibdid
            • Jun 2019
            • 10
            Originally posted by R_J
            Thanks, although I am a little worried that he states the part is 160v 1a as I'm sure the part should be 120v 2A?
            I may give it a go though.
            • petehall347
              • Jan 2015
              • 4424
              what is the board number ? will be something like vestel------- or maybe Haier -----
              there is a schematic but asks to sign up . http://freebodydiagram.archivioprimo...our-television
              • R_J
                • Jun 2012
                • 9518
                I believe it is just for over voltage protection on the +112 volt line to the horz. output section. I would replace the low voltage/capacity electrolytics in the primary, If they are bad the power supply might not regulate properly, it could also be bad caps on that B+ 112v line, If the caps go open the voltage can go up. You should be able to use the NTE570
                Check the schematic for the CT-2153
                • Bibdid
                  • Jun 2019
                  • 10
                  That looks promising but the site seems to be very shady. Relinks me to scam sites.
                  I have attached some board model/serial numbers although it seems very obscure.
                  • Bibdid
                    • Jun 2019
                    • 10
                    Thanks for the help. I measured the capacitance and esr of a few capacitors around that area and they are way out of spec. Is it possible that these caps took out the flyback? I know this tv has had a very hard life and the flyback exploded somewhat violently, with resin being thrown out a fair distance onto the board.
                    As for the schematic, is there any reason you recommend the CT-2153 over others, just out of curiosity?
                    • petehall347
                      • Jan 2015
                      • 4424
                      . cant make sense out of the board numbers yet .. maybe there are more numbers or a sticker
                      • petehall347
                        • Jan 2015
                        • 4424
                        this looks like it ...
                        • R_J
                          • Jun 2012
                          • 9518
                          It is possible that the power supply started to output a higher voltage causing the flyback to operate at a higher voltage and break down, but it could be the flyback was just at its end of life. I picked that schematic because I could not find the actual one for your tv so I found a Mitsubishi tv that had a similar circuit.
                          The Hitachi chassis is totally different
                            • 30941
                            not hard to find.
                            it's D907
                            • redwire
                              • Dec 2010
                              • 3900
                              I would use P5KE120A TVS diode as a replacement.
                                • Jul 2011
                                • 6024
                                Is there anything special about this type diode
                                • redwire
                                  • Dec 2010
                                  • 3900
                                  It's got a misleading name "avalanche diode" and nominal 120V (130-155V) rating. So it's a zener (=avalanche mode) but the wide range of reverse voltage spec. and high surge capability 2A 100usec mean it's really a TVS diode.
                                  In the TV circuit, I can't find the schematic again but it seems to be an overvoltage clamp for when the power supply puts out too much voltage.
                                  If the STR fails or something else happens the rail can go too high and the TVS diode clams to protect something but it will cook and short if that stays true for a long time. I see main power like 115VDC go up too high due to a bad regulator and it damages other parts, flyback too if the x-ray protection does not trip.
                                  • asr
                                    Finding replacement diode iPad Pro 3rd gen A1701
                                    by asr
                                    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                    07-09-2024, 06:24 PM
                                  • unimatrix93
                                    TV backlight zener diode
                                    by unimatrix93
                                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                    The led strips has 9 6V leds.
                                    02-10-2025, 12:13 PM
                                  • NicRac
                                    monowheel repair,Is the diode the problem?
                                    by NicRac
                                    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                    First of all, I am new here. Therefore I will shortly introduce myself.
                                    I am Nico and currently I study Physics.
                                    In my freetime I like to build and repair stuff. Especially big battery's.
                                    A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                    The battery bms was broken so I replaced and resolder that. Nothing big.
                                    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                    07-26-2024, 06:13 AM
                                  • dennis_elx33
                                    NO BODY MARKING Diode
                                    by dennis_elx33
                                    Hello Everyone,
                                    I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                                    While compared to the reading of another diode from the next channel it won't read at reverse bias.
                                    Now the problem is; it does not have any body marking.
                                    So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                                    What do you think is this diode?
                                    Can you please suggest what part number can i use to replace this faulty diode instead?
                                    Hoping that you...
                                    06-14-2024, 12:36 AM
                                  • eccerr0r
                                    Electric lawnmower...purpose of diode...
                                    by eccerr0r
                                    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                                    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                                    08-27-2022, 12:54 PM
