Light bulb flicker when turning on after long time off.
  • sew333
    • Apr 2017
    • 81
    • Poland
    Hello. I have question. I dont know if i have faulty wiring,bad installation or its bulb. When i have lights off long time and turn on lightning ( bulb halogen ) , there is a for 2-3 second bulb dimm/flicker and its normal. Happens only when lightning is off long time and i turn on.
    When i turn off lights and turn on again its fine. That flicker/dimm happens only when lights are off long time.
    That happens for example if i have lights off 2-3 hours and turn on.
    Thx
    • 31304
    Re: Light bulb flicker when turning on after long time off.
    if it really is halogen then you have a bad socket, switch or a problem with the wiring.
    maybe a terminal needs tightning.
    • sew333
      • Apr 2017
      • 81
      • Poland
      Why it happens only after lights are off for long time?
      Bulb looking like that here:
      https://www.destinationlighting.com/...17150~zoom.jpg
        • 31304
        that is a PL type flourescent lamp, not halogen.
        so forget everything i said.
        for a flourescent lamp it could indicate the tube is getting old.
        but they always start a bit dim when they are cold anyway.
        one thing i found with those, if your using an adapter that goes into a regular lamp holder then they have a capacitor in them that will fail over time.
        but it's easy to clip them open and replace it.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          Not sure if it's "new" versus "always like this" behavior?
          Those four pin fluorescent tubes all seem to do that for me if you have a traditional/old type auto starter coupled with a magnetic ballast. The two pin PL-13 has the old starter built in, and coupled with a magnetic ballast, and thus it behaves the same way.
          Replacing the starter with an electronic starter will help, though I'd swap the starter and the ballast to an electronic one, I hate those old starters lol...
            • 31304
            the one in the pic is 4pin so probably driven by a high frequency invertor
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              That remains to be ascertained but for sure the neon starter + mag ballast system will flicker before lights on as normal behavior ...
              ... and after using electronic/high frequency inverter ballasts, I hate the flickering. I have one of those linear T8 13W desk lamps that I threw out the old starter and magnetic ballast and replaced them with the guts of an "instant on" electronic ballast CFL whose heater burned out...
              Lights On Flicker Free Bliss.
              • petehall347
                • Jan 2015
                • 4451
                • United Kingdom
                my desklamp just has the on off switch that you hold in for about 6 to ten seconds then let it out and it lights up . no starter . and no flicker .
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Yep, that's the "manual start" fluorescent... which I despise even more than the flickery auto-start. It's good to fire and forget lamps like incandescent, having to hold the button down until it strikes is annoying
                    • Jul 2011
                    • 6070
                    There issues with this type of light bulb and the blast if it the old fashion is the starters if it is electronic version sometimes depending on the version it has a tendency to fry the bulbs if they are in a can type of fixture
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Many CFLs are usually only a bit dim when cold-started, but some are extreme, some look like I'm starting up a metal halide or an HPS!
                      I've seen TCP CFLs start up like an HPS!
                      CFLs usually are somewhat dim at startup, but not as pronounced as 48-inch T12s and 48-inch T8s, where the Phillips Alto II 48-inch T8s often have a wavy pattern when cold, especially my 6K-rated Alto II 48-inch T8s.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                        • 31304
                        only a communist "green eco nut" would create a 4foot T8!!
                        besides, they may be the same length as a T12 or the older big ones, but they obviously have a much smaller surface area.
                        so your overdriving the fuck out of it to get the Lumens and the lifespan will be short.
                        followed by a trip to the landfill to add a bit more phosfor and mercury to the pile!!!
                        i really miss my 5foot 65w "fat" tube i had in my old place.
                          • Jul 2011
                          • 6070
                          These are crap light bulbs 4 foot T8 54 watt you would be lucky if they last a year
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Mine are 32-watt.
                            I also have plenty of 48-inch T12s! (40-watt)
                            IIRC, the 54-watt ones are usually T5s!
                            Arc A770 16 GB
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8716
                              Using the F32T8's in the old magnetic ballasts will probably burn out in that year...
                              Should be using electronic ballasts with the T8's.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                None of my F32T8s are connected to a electro-magnetic ballast. They are all the new type, much like T5s.
                                But I still get that familiar wavy pattern with my 6K-rated ones when cold.
                                Arc A770 16 GB
                                • sew333
                                  • Apr 2017
                                  • 81
                                  • Poland
                                  So why that bulb dimm/flicker shortly for a moment only when lights was off few hours?
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    Post a picture of the bulb and the socket.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Without removing any of the bulbs:
                                      (The cord was scuffed when I bought the fixture, IIRC, LOL)
                                      Arc A770 16 GB
                                        • 31304
                                        a flourescent tube contains a drip of mercury,
                                        when you turn it on from cold it has to heat the mercury to make it vaporise and spread through the tube for the tube to start and light evenly.
                                        thats why sometimes when you turn it on you may see the ends glow - that's the heaters
                                        • OscarAV
                                          HP Pavilion dm4-1065dx long time to get the power led on
                                          by OscarAV
                                          I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
                                          I have made a quick search for my laptop but I have not seen anything similar.
                                          I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
                                          09-23-2024, 05:53 PM
                                          High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
                                          by sam_sam_sam
                                          I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
                                          This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
                                          If it cycling on and off constantly then it is the bulb itself that is the issue
                                          06-03-2023, 05:24 PM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • jagg
                                          Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
                                          by jagg
                                          Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
                                          Here are the bios and the schematics.
                                          Could someone help me verify that the bios is correct? thank you so much !!...
                                          11-22-2023, 03:36 PM
                                        • sew333
                                          Can halogen bulb flicker?
                                          by sew333
                                          Hi. Yesterday i was in bathroom. And halogen bulb flicker for 1 second. Is this possible and why it flicker? Thx
                                          Bulb looking something like that:
                                          06-09-2022, 09:25 AM
