What is that guys? Any idea?
by sam_sam_samI just seen this item is this a good idea if why and if not why not
Here is the website link to it
https://www.ebay.com/itm/40599879518....c101465.m3507 -
by MikoMikoHello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
TF-FUSE Thin Film Surface Mount Fuses
FF Series (Very Fast Acting), 0603 Size
Features
● Very fast acting at 200% overload current levels
● Low DCR
● High inrush current withstanding capability
● Fiberglass enforced epoxy fuse body
● Copper termination with nickel and tin plating
● Halogen free, RoHS compliance and lead-free
Applications
● Notebook computers and tablets
● Digital cameras
● Memory cards
● Toys
● Bluetooth earphones
● Portable electronic devices...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:50 AM -
by zmeutulhey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
Channel: BIOS Requests ONLY!
by DannyxGood day folks. It's been a while since I've worked on a laptop, but this one belongs to a very important person - my boss ! - so I'd be great if I could get this one going, but the signs are not good so far. I found the schematic AND boardview right here on our forum - big shout-out to SMDFlea for providing them !
The laptop doesn't do anything: totally dead. No lights, no power, no fan-spin. I took the cover off and noticed someone had been inside before, as two caps are missing (PC20 and PC29) which are just power-input filter caps, so it SHOULD work without those too.
... - Loading...
