What is that guys? Any idea?
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    http://imgur.com/a/TV9MNGp
    • 30915
    Re: What is that guys? Any idea?
    it's a suppressor.
    a film capacitor and resistor in series.
    • spiros.p
      • Dec 2020
      • 89
      • Greece
      aa ha thanks.
      • MikoMiko
        MacBook Pro A2251 - 820-01949-A not charging
        by MikoMiko
        Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
        03-24-2025, 11:09 AM
        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
        FF Series (Very Fast Acting), 0603 Size
        Features
        ● Very fast acting at 200% overload current levels
        ● Low DCR
        ● High inrush current withstanding capability
        ● Fiberglass enforced epoxy fuse body
        ● Copper termination with nickel and tin plating
        ● Halogen free, RoHS compliance and lead-free
        Applications
        ● Notebook computers and tablets
        ● Digital cameras
        ● Memory cards
        ● Toys
        ● Bluetooth earphones
        ● Portable electronic devices​...
        10-07-2024, 05:50 AM
      • zmeutul
        hi guys i need bios for 6-77-NP50PNJY-D02B-3C
        by zmeutul
        hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
        09-26-2024, 01:55 PM
      • Dannyx
        HP Spectre X360 (Quanta Y0D) Not Charging, No Power
        by Dannyx
        Good day folks. It's been a while since I've worked on a laptop, but this one belongs to a very important person - my boss ! - so I'd be great if I could get this one going, but the signs are not good so far. I found the schematic AND boardview right here on our forum - big shout-out to SMDFlea for providing them !
        The laptop doesn't do anything: totally dead. No lights, no power, no fan-spin. I took the cover off and noticed someone had been inside before, as two caps are missing (PC20 and PC29) which are just power-input filter caps, so it SHOULD work without those too.
        01-05-2022, 01:44 PM
      • platinumsteel
        HP 14-dq2088wm 11th Gen Missing 3V/5V Standby Voltage
        by platinumsteel
        Hi guys have a HP 14 Labtop. DA0PAHMB8F0 .There is no White LED on the DC Jack .It got a drop of water damage right next to the 3V IC ( Silergy SY8386BRHC) and corroded a resistor and a pad which belongs to the Enable for the IC. I cleaned the area and re-soldered the resistor. Nothing Changed. I don't know what the value for the resistor should be.It measures about 80.0K No schematics available for this model. A good friend on here mon2 helped me identify the IC markings and gave good advice on making sure to measure the input voltages and enables and checking for short.
        There is no short...
        11-12-2024, 05:49 AM
