How could I find a FET with specific specs?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I need a FET or a transistor ... don't care really, I'm going to use it to source current to three LEDs at three different levels of brightness (meaning I'm going to drive the transistor at three different voltage levels). It needs to be able to handle 850 milliamps and be fully saturated at around 3.3 volts ...
    Is there a way to search for a FET or a transistor based on parameters like this?
    Thank you,
    Mike
    sigpic
    • 30953
    Re: How could I find a FET with specific specs?
    well fets need variable voltage, and transistors need variable current.
    most fets dont like being part-on(linear mode) and get hot.
    you dont say your led drive voltage, but i think you need to use darlington transistors.
    maybe a ztx602
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8682
      No transistor likes being part on (linear mode), they all get hot whether BJT or FET.
      All depends on how the heat can and is being dissipated.
      If you want (nearly) linear voltage (or current) to current translation, you have to use a BJT. MOSFETs are not linear to Vgs and... (broken record...) YOU NEED NEGATIVE FEEDBACK to get a linear response using a MOSFET. You can see people *do* use MOSFETs for audio amplifier final stages, and you do see they have negative feedback in order to get this to work.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Originally posted by stj
        well fets need variable voltage, and transistors need you dont say your led drive voltage, but i think you need to use darlington transistors.
        maybe a ztx602
        This is a screenshot from a website where I put in the parameters and this is what it kicked out. I was presuming that I would build the circuit like this ... I just need to drive it...
        sigpic
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8682
          But where's the transistorized portion, that's a huge part of the circuit missing!
          Do also keep in mind that BJTs have a saturation voltage that may drop the voltage below 3.2 volts, and you may need to use MOSFETs with op amps, possibly with charge pumps, to get the gate drive high enough to fully turn on.
            • 30953
            or use pwm.
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              maybe a ztx602
              ... so ... looking at the datasheet for that transistor ... am I reading this right? Would this not fully saturate long before it hits 3.3 Volts?
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                or use pwm.
                PWM from a microcontroller would not have nearly enough current for this application, which is why I need to drive those LEDs through a transistor of some kind. I am going to use PWM to drive the transistor, however. An ATTINY85 to be exact.
                sigpic
                  • 30953
                  i meant pwm and a fet
                  as for saturation, like i said - your driving it with variable current - not voltage.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    I'm not sure I understand what you're saying exactly.
                    Take for instance, this schematic, and the transistor is the ztx602...
                    Based on what I see in the datasheet, once the pin at the base of the transistor hits 1.7 volts, those LEDs will be on as bright as they ever could be in this circuit, meaning that my options for "medium" and "low" light intensity will have to be achieved by telling the attiny pin to drive the transistor at two different voltage levels below 1.7. Correct? Which gives me a lot less headroom for resolution, which is fine, as long as the transistor will do what I'm needing it to do. But I don't know how to drive a transistor with current because to me, current happens when you apply voltage to a circuit but it's not an option, in this case, to say "Im going to drive this transistor with x number of milliamps" because in an Arduino, I can only adjust voltage levels on pins.
                    sigpic
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8682
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4939
                        • New Zealand
                        That circuit takes the small current available from the micro-controller pin, and amplifies it with the transistor to drive the LEDs.
                        This will turn them on full.
                        But PWM turns them on and off quickly, and varies the duration for which they are on vs off. By doing so it can control the brightness as we perceive it with our eyes due to persistence of vision. So there is no need to control the current linearly.
                        With a more advanced micro-controller, you can output an analog signal using the onboard DAC, then amplify that with a transistor to control the LEDs but then you will need a transistor with a heatsink so it does not overheat. PWM is more efficient as the transistor is either on or off.
                        The only other option is to have multiple transistors switching in different resistor values for your different brightness levels but this increases the cost and complexity greatly.
                        -David VanHorn
                          You are doing Emitter follower (Common Collector), so the Base Voltage with ref to ground will way higher than 1.7V Vbe junction. if you look at your circuit you will have Vbe, Vled, Vrs. The output Voltage on the Emitter will be = Vbase drive - Vbe.
                          You should have the Transistor or the MOSFET on the low side of the circuit and then PWM the MOSFET to control the current through the LED and you also need the current monitor feedback to maintain constant current through the LEDs.
                          Your circuit is the Voltage source not current source, so if you have fixed Voltage feeding the LED, but since LED Vf will vary with temperature so the current through the LED will change which will cause the LED brightness to change, that is why you need to use constant current source to drive the LED so if the LED Vf varies the circuit will try to maintain constant current through the LED thus maintaining the steady brightness.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8682
                            Correct, need a common emitter or common source for mosfets. So that means low side, or use a p channel/pnp transistor. OP can use n channel/npn on the high side if they make a driver for them, which may complicate the circuit considerably.
                            I'm facepalming because we're seeing the same problems that needs to be solved as the magnetic stirrer problem. Nothing learned... Insisting the final driver must be driven by an analog signal...
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              I'm here to learn, not dictate. I only post what I know...
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                OK, so in terms of learning, I have no idea what "on the low side of the circuit" means at all ... also, "current monitor feedback" - no idea what that is either.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  And HEY - I got that pill to spin did I not? Gotta give me some credit... :-)
                                  sigpic
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8682
                                    Since electricity can be interrupted anywhere in the circuit, there's a choice to be made. Low side control means controlling the "low" or ground/negative side of the device that needs to be turned on/off. High side = "high" or power/positive side of the device. Choice needs to be made, devices need to then follow suit.
                                    If you chose devices before side then circuit topologies are more limited due to device physics.
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      OK, then when budm says, "You should have the Transistor or the MOSFET on the low side of the circuit" how does that change this schematic? What would be different?
                                      sigpic
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8682
                                        Well, clearly now you don't have a low side control of the load. What you do have is 'high side' where the transistor switch element is controlling the positive rail to your device as it blocks the electrons after it flows through your load(LED) (or described by classical electrical flow, current is blocked before it goes through the load).
                                        I have to leave it up as an exercise to the reader to convert this to a 'low' side control.
                                        Thank you for putting the correct polarity/channel semiconductor in the schematic. Very important when dealing with the drive needed to turn on low/high side semiconductor switches.
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • nunofcc
                                          Logitech G29 Help request to find smd transistor reference.
                                          by nunofcc
                                          Good night,
                                          I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
                                          Thank you for your help....
                                          10-04-2020, 01:59 PM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                                          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                                          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                                          07-07-2024, 02:34 PM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
