DVM circuits
  • barry wilkins
    • Aug 2009
    • 172
    DVM circuits
    Unforunately I damaged one of my DVM,s when working on some power supplies
    measuring some high voltages ,because there was some rf on the dc I was measuring.
    It still works but is noisey and it will not measure diodes, I would like to fix it if possible.
    Does any one have any circuits for DVM,s
    thanks
    Barry Wilkins
  • redwire
    • 3912
    Re: DVM circuits
    There's lots of DVM schematics out there, if you have a make/model or pictures of the board it can help figure out the DVM chip used and what parts might be damaged.
    Usually a low cost DVM overloaded (by voltage) will damage its input protection clamp diodes, so you always get a low reading on ohms or diode test, when no leads are connected. Just speaking generally.
    • barry wilkins
      • Aug 2009
      • 172
      Re: DVM circuits
      Hi attached some pictures cant see any makers name on it .Fixed the noise problem by cleaning the switch ,just seems a problem trying to measures diodes ,very low voltage applied to the device .
      There are two op amps ,dual and a quad .
      Could it be a problem with the LM324 ?
      Bought a new one from Amazon that had 1000 V on it ,was rubbish didnt have any sockets fitted for the transistors, so it returned it.
      Got a different one which is better.
      Barry
        • 31138
        Re: DVM circuits
        Barry
        lol
        there is a running joke that any meter with a transistor (HFE) socket on the front is junk aimed at hobbyists.
        • redwire
          • 3912
          Re: DVM circuits
          The PC board is "MX-480D-B" but no hits.
          I don't see the usual two-transistor clamp or a PTC thermistor. Low cost DMM's sometimes have missing protection circuits and they easily die.
          I would (using another multimeter) test the six black diodes. Otherwise, all that remain are the LM324 and the big IC.
          hFE socket is also supported by the ANENG/Dreamtech chips, is in DT830 and even Harbor Freight freebies. I don't mind it.
          • R_J
            • 9579
            Re: DVM circuits
            It is likely a Maxcom MX480 multimeter, or copy. There is a blue PTC1 located close to the board number
            • zx8401
              Phantom Fiddler
              • Aug 2013
              • 49
              Re: DVM circuits
              Looks like a dt890 to me, there are a few versions A B C D E F.
              • barry wilkins
                • Aug 2009
                • 172
                Re: DVM circuits
                Hi thanks to all of you for the info ,I will look at it in a few days .
                Not too bothered about fixing it as I have quite a few other meters
                1 I keep my car 1 in my tool box 1 in my caravan, 3 in my little workshop , a TEK scope and a Hantek scopemeter.
                regards
                Barry
                • barry wilkins
                  • Aug 2009
                  • 172
                  Re: DVM circuits
                  I could see there was something wrong around the TL 062 opamp ,so I removed it and replaced it with an 072 ,replaced the diodes and capcitors at the same time. A bit more investigation found R 36 was O/C.
                  Barry
                  • mkdj
                    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                    by mkdj
                    About me, my goal and the equipment I (don't) have:
                    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                    About my issue and my goal:
                    A friend of mine has a MacBook Air M1 A2337 that does not...
                    04-03-2025, 08:28 AM
                  • jm1234
                    Yageo 400V 680uF measuring 580uF
                    by jm1234
                    I have a Yageo 400V 680uF that is currently measuring 580uF (Measured by UNI-T UT603). Does that normally qualify for replacement?
                    Details: Siemens tumble dryer getting Error 25 after an hour or so, on all last 3 runs.
                    I checked the circuit boards quickly and this capacitor sticks out, nothing visible, not even bulging though. It costs 12euro, so I'd like to get your feedback first. The main thing on that board seems to be a motor controller (for the compressor) https://www.mouser.sk/ProductDetail/...xvzUNHBQ%3D%3D.
                    Thanks...
                    01-12-2024, 10:13 AM
                  • Rado108
                    Measuring ESR in-circuit: LCR or ESR meter
                    by Rado108
                    Hello. Which tool is better for in-circuit testing of e-caps? I was thinking about getting proper LCR meter like DER DE5000 but as i have seen more accurate are ESR meters like ESR70 from Peak if we are measuring in-circuit. Is that true?
                    Sometimes ESR can not be accurate when in-circuit but still want to get the best tool for it.
                    09-10-2023, 10:42 AM
                  • DexMexDC
                    AMD RX 6800 XT no GFX and SOC voltage
                    by DexMexDC
                    Hello, I have one AMD RX 6800 XT and one RX 6700 XT with very similar problem. Both have no GFX and SOC voltage. But lets start with the 6800.
                    I have experience in electrical engineering and measuring instruments such as multimeters, oscilloscopes, laboratory power supplies, thermal imaging cameras but I just can't get anywhere here.
                    Let's start with the 6800 XT:
                    - no visible damage
                    - No short circuits
                    - VMEM - 1.35V
                    - VMEM Controller - 0.89V
                    - 5V0 - 5.02V
                    - 0V75 - 0.74V
                    - 3V3 - 3.27V
                    - 1V8 - 1.80V
                    - VDDCR GFX - 0.0V...
                    01-11-2025, 03:38 PM
                  • nicktasios
                    Macintosh Quadra 840AV PSU
                    by nicktasios
                    I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                    12-22-2024, 05:07 AM
