AMD RX 6800 XT no GFX and SOC voltage
  • DexMexDC
    • Dec 2023
    Hello, I have one AMD RX 6800 XT and one RX 6700 XT with very similar problem. Both have no GFX and SOC voltage. But lets start with the 6800.
    I have experience in electrical engineering and measuring instruments such as multimeters, oscilloscopes, laboratory power supplies, thermal imaging cameras but I just can't get anywhere here.
    Let's start with the 6800 XT:
    - no visible damage
    - No short circuits
    - VMEM - 1.35V
    - VMEM Controller - 0.89V
    - 5V0 - 5.02V
    - 0V75 - 0.74V
    - 3V3 - 3.27V
    - 1V8 - 1.80V
    - VDDCR GFX - 0.0V (missing!)
    - VDDCR SOC - 0.0V (missing!)
    The power controller (IC U500) is an Infineon XDPE132G5D-G000:
    - 3V3 on PIN 54 - 3.27V
    - VDDCR_GFX_SOC_EN on PIN 48 - 3.27V
    - GFX_SOC_PWRGD on PIN 18, 19 - 0.0V
    - EN_L2/PWROKon PIN 47 0.0V because GFX_SOC_PWRGD is OV (AND Gate from GFX_SOC_PWRGD and PERST#_BUF)
    - PWM channels 1.67V DC, not a single PWM pulse.
    - VINSEN PIN 52 - 0.84V
    What else should I measure? What could it be? Is the U500 itself defective or is there an input missing?
    https://www.badcaps.net/forum/troubl...36#post3546836
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    0V at PG output = chip is dead.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3607
      • slovakia
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Originally posted by ktmmotocross
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3607
          • slovakia
          what chip is dead and why?
          • прямо
            • Sep 2022
            • 261
            • Indonesia
            See his post. Phase controller chip doesn't output PG (power good), but it has EN signal and supply voltage. That's why I said it's dead.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3607
              • slovakia
              pg signal is released when output is ok. why u expect controller to output pg if there is no output? there is even other signals that can prevent ic from make output
              • jpreza
                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                by jpreza
                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                Looking at the card, it appears to be missing the following:
                1x 1.0uH inductor - orange square
                2x...
                11-01-2024, 10:54 PM
              • T4H
                RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
                by T4H
                I have an RTX 2080 ti (Zotac - triple fan) with no video output.
                So far I have measured the following:
                • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
                • 12V power rail present
                • 3.3V power rail present
                • 5V power rail present
                • 1.8V power rail present
                • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
                • Vmem power rail missing --> Not there because Vcore power rail is missing.
                Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
                Source: https://www.techp...
                08-19-2023, 08:14 AM
                AMD Radeon RX 6800 XT (RX6800XT) Schematic & Board View
                The Radeon RX 6800 XT is a high-end graphics card by AMD, launched on October 28th, 2020. Built on the 7 nm process, and based on the Navi 21 graphics processor, in its Navi 21 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6800 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 21 graphics processor is a large chip with a die area of 520 mm² and 26,800...
                10-01-2024, 12:17 PM
                ACER Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP Veriton 630 Specification for Upgrade or Repair
                This specification for the ACER Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP boardview and Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                09-12-2024, 03:36 PM
              • ugamazing
                820-02020 PPBUS_AON missing
                by ugamazing
                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                02-05-2025, 04:21 PM
