Honeywell quartz clock component
  • sky_tech
    • Dec 2007
    #61
    Re: Honeywell quartz clock component
    I have a very similar timer module in a Honeywell Chronotherm thermostat. My 2/3AAA solder-tab battery was also dead, but it caused the timer to stop. I tried a test with a AA alkaline battery, but 1.5 volts caused it to run fast. A NiMH AA battery worked great as a temporary fix. I simply used a heavy rubber-band to hold the leads onto the battery. That was the good news. The bad is that an hour ago I went to solder in a std AAA battery holder so I could use a std AAA NiMh and screwed up! I neglected to remove the thermostat before soldering and the grounded tip of the iron drew a spark when it touched the battery wire. Now the clock is dead. I'm just beginning debug. Any suggestions? I'm a retired EE, but don't have a scope handy. I also neglected to recall which battery lead I had touched with the iron. I would love qualified suggestions!
    By the way, the other number on your Eurosil 1115A, 1585, should be a date code of the 15th week of 1985 (mine is 4887 or 48th wk of 1987). That should help you date your unit. My thermostat was installed in 1989.
    • sky_tech
      • Dec 2007
      #62
      It looks like an extremely similar timer subassembly was used in the very popular Honeywell Chronos T8082A series thermostats such as T8082A-1148 (and maybe T8095 series such as the T8095A1002). Look for them on eBay and use one as a parts source.
      • sofTest
        • Aug 2008
        • 361
        #63
        I'm sorry, this is only a hobby for me, so for more advanced troubleshooting I hope one of the guys helping me can give you some help. I would recommend you to upload pictures of the timer, so they have something to work from.
        As for my own clock, I received the battery on Friday, and completed the repairs according to my last posting above yesterday. The clock has been running directly of mains for about 30 hours now, with little or no drift in time. I plan to let it run another 18 hours of mains, then let the battery run down, before I desolder it of the mains cable. I'll upload pictures of the repaired unit tomorrow.
        Be a mensch
        • shelby5041
          clock radio / radio lifespan?
          by shelby5041
          hi
          ive got a modern digital clock radio approx 15yrs old
          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
          it uses very little power just a few watts i would imagine that may have something...
          09-14-2024, 03:30 AM
        • pc_okay
          Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
          by pc_okay
          Hello friends,
          Its been a while, i wish you an happy new year 2025 !
          I have this laptop doesn't start, power light up a second when pluging USB-C charger.
          Laptop take 0.11A.
          All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
          I get no oscilation on XTAL 32.768 KHZ
          Battery is not charging but charging led is here.
          PCH heat at 30° approximatively. (with no heatsink)
          I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
          It's a 2 pins Crystal.
          01-13-2025, 09:26 AM
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • Fontana
          71R-H14BW6-T830, clock stops when shutdown
          by Fontana
          Hi!
          Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
          The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
          I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
          I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
          Any suggestions?
          OBS: when the pc is off,...
          09-28-2022, 09:57 AM
        • kjchatman
          no display on ps4 slim ddc i2c clock shorted
          by kjchatman
          i replaced the hdmi port first with no luck then i noticed that it wouldn't do the two beeps for safe mode unless the televison wasn't connected to the console. Turns out that the ddc data bus has an issue. the clock signal is shorted to ground whenever the display is connected. Even if the console isn't plugged into the outlet. i'm not sure why the clock signal goes to ground. i removed the safety zener diode to rule that out as a culprit.
          12-09-2024, 08:23 PM
