Good day.
Just a quick question - I have the following toroidal transformer:
PRI: 2x 0-115 Blue-Grey Violet-black
SEC: 12v Red-Black
SEC: 12v Yellow-Orange
How should I wire it to get 230 on Primary and 24-0-24 on SEC if it is even possible?
Will 220 to single PRI winding and then Red-black_yellow-Orange do the work, or probably 220 on both PRI in parallel?
Both SEC are rated to 6.7A, so I guess if I you double the V on PRI, the rated amperage should be divided by 2?
Also, does it matter which ends of the wirings of the SEC are used for zero reference? Is there a difference whether it will be Red-Black_Yellow-Orange, Black-Red_yellow-Orange, etc.?
Thanks in advance!
SEC: 12v Red-Black
Thanks in advance!
. To avoid doing that, use a 100W incandescent light bulb in series with the transformer's primary (after wiring the two primary winding in series.) If the bulb lights up and stays lit, you've wired them incorrectly. If the bulb doesn't light up, check the voltage at one of the 12V secondary windings - it should be correct at 12V AC.
