SR-602 PIR sensor not working. Ideas ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I'm trying to build a motion-activated light for my front door.....sounds simple enough. I had two SR602 PIRs on hand in my parts bin which I got for a similar project that never happened, so I thought these would be perfect to use here. They don't seem to work though. Either I'm doing something wrong or they're defective in some way...
    I power the sensor with a 12v wall-wart and use an SB8050 transistor and a 200ohm resistor between the collector and the "out" pin of the sensor to switch a 12v relay on and off....simple enough. It works, so there's nothing wrong with my circuit, but the problem is it keeps cycling on and off forever. What I did, according to the documentation, I changed the 0-ohm resistor to 56k to give me an on-time of around 11s. It's not perfect, but it's close enough - it's within a 2-5s error up or down, but that's acceptable. The problem is once the time elapses, the output pin stays low for about 2 seconds then comes back on by itself, again and again.....what gives ? I thought this may be like a "setup" time, but I left it alone for a good 5 minutes and it was still doing this.
    I tried the other sensor which I hadn't altered in any way and it's doing the same thing, except in smaller intervals, since it's still got that default 0ohm resistor for the on-time, so it comes on for 2 seconds, then off for 2 and so on...
    The strange part is that it only seems to do this when it's got the transistor's base connected to the output ! If I remove the resistor and let the output pin float, it works fine, as my multimeter shows !
    I tried adding some capacitors on both the output and the VIN pin, I even put a diode between the output pin and the transistor, but nothing helped ! It simply won't stay off for longer than 2s !
    Any suggestions, including some "better" small form-factor sensors ? Size is an important factor, since I could just run down to the local store and get one, but those are massive in size for my project !
    Wattevah...
    • 31256
    Re: SR-602 PIR sensor not working. Ideas ?
    test with a battery - incase it's caused by ripple.
    • petehall347
      • Jan 2015
      • 4442
      have you put a flyback diode on the relay coil ?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Yes, it's the first thing I did
        I shall, though I tested two different AC adapters....they could both be sh!t after all
        Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Originally posted by budm
            I saw your original reply asked for the datasheet of the sensor. There doesn't appear to be one that's any different or containing more info than what I linked too in my starting post. All sources give the same info about choosing the value of the on-time resistor and some generic info but that's about it. For instance, one parameter which I couldn't find anywhere despite being important IMO is the maximum current the output pin can source ! It is unable to actuate a small 3v relay by itself, so I estimate it's less than 100mA.
            Wattevah...
              • 31256
              i notice the example schems for the part all show a 100uf smoothing cap
              • petehall347
                • Jan 2015
                • 4442
                not that i think it will work but you could try a voltage divider on the relay driver transistor base .
                another thing to try is the light bulb circuit in the instructions .that at least rules out the relay circuit
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  It's virtually identical to what I have ATM, just with a relay instead of the lamp. True, the values are different...
                  I tried adding one on both the VIN and the output, but didn't help. I THINK I saw a greater delay between cycles WITH the cap in place though, which makes sense since it takes longer to discharge into the base of the transistor...
                  Adding to the unpredictable and strange nature of the behaviour is that if I start the circuit with the base connected to the PIR, it cycles as described. If I remove the resistor to the base, it keeps cycling until I turn off the power and turn it back on again. It seems it doesn't like having something on its output pin, OR I'm drawing too much current with my 200ohm resistor, which I worked out to around 10mA for the S8050 tranny...
                  Wattevah...
                    • 31256
                    unless it's buffered, i would keep it under 5ma - it's a low power device.
                    use a darlington transistor or a fet with it.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      I think a 2n2222 has a higher gain, thus requiring less base current.
                      Wattevah...
                        So right now you have 4K7 resistor between the output pin and the Base of the relay driver transistor, correct?
                        If you hook up 4K7 resistor between output pin and ground, what Voltage do you see on the Output pin when it detects and not detects the object?
                        What is the resistance reading between Output pin and the + pin (measure when nothing is connected to the module)?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          No, I have a 200ohm resistor between the output pin and the base of the 8050....by my calculations (which could indeed be wrong), this was to give me around 10mA of base current.
                          Wattevah...
                            If you perform the 4K7 (or 200 Ohms) connection between output pin and ground and check the Voltage at the output pin, that will tell you if it can drive the current you need or not.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              WITH the transistor's base connected via 200ohm resistor, I measure 3.3v on the output pin, so it's not overloaded and dropping.
                              Wattevah...
                                So yes, you are getting about 13mA Base drive.
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  I used worst possible Vbe loss of 1.2v from the datasheet, so in reality yes, it's probably closer to 13mA than 10mA, as the drop is less than 1.2v...
                                  Wattevah...
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    Couple of other things I tried:
                                    -9v battery for power
                                    -FET instead of 8050
                                    -getting the relay off the breadboard in case the electromagnetic interference is affecting the PIR
                                    Neither worked: it still cycles....either these suck by construction, or I damaged them somehow....
                                    Wattevah...
                                    • Julian Tauscher
                                      • Jun 2024
                                      I had exact the same problem, running the SR602 with a CB3S Tuya Chip inside a "mini smart switch" from aliexpress. PIR was cycling on and off forever. OUT pin of the PIR was connected to TX1 (P11). So after changing it to P7 it worked normal. I have no clue what the problem was, checked for hours with impedances, capacities, oscilloscope and what not. Hope that might help anyone.
                                      What I checked:
                                      - Running just the PIR with battery and LED as Output: worked
                                      - Running with impedances and capacities within the CB3S mini smart switch: didnt work
                                      - Running with the CB3S but battery driven instead of AC power: didnt work
                                      - Running the PIR only with battery next to wifi device or AC wires: worked - no problems/interference here
                                      - changing input pin of the CB3S to P7: worked
                                      • CapLeaker
                                        AcuRite 5 in 1 temperature sensor replacement repair
                                        by CapLeaker
                                        Got a new victim:
                                        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                        B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                        04-15-2025, 01:32 PM
                                      • jinu_j
                                        by jinu_j
                                        Hi
                                        05-03-2025, 10:51 PM
                                      • mikey5791
                                        by mikey5791
                                        Hi to all forum members,
                                        12-26-2024, 04:55 AM
                                      • MidnightRoller
                                        Can a resistor lose resistance after hot air?
                                        by MidnightRoller
                                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                        02-02-2022, 11:46 PM
                                      • artvandalai
                                        What resistor ohm will work better to repair this waterpik?
                                        by artvandalai
                                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                        01-05-2025, 04:10 PM
