What's the ref of the component with written "LF" on it ?
  • 21839
    • Dec 2020
    • 4
    • France
    https://www.overclock.net/attachment...4-jpg.2462368/
    It's a long story but it got removed and I need to replace it by something similar, where can I buy one ?
    • 30979
    Re: What's the ref of the component with written "LF" on it ?
    are you talking about the 560uf 6.3v solid polymer capacitor with red print?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      Think it's a transistor, 2SC3052 or equivalent perhaps?
      • 21839
        • Dec 2020
        • 4
        • France
        the two identical ones at the top
        • 21839
          • Dec 2020
          • 4
          • France
          thank you
          • SluggerB
            Thinkpad T60 display, first no backlight, now nothing (long story and pictures inside
            by SluggerB
            I have an old T60 where the display was showing the "red haze" indicating the CCFL was on its way out. Eventually it developed a condition where upon a fresh reboot the display would be fine for a few minutes, and then the back light would go out. Plugging an external display into the VGA port showed the laptop was still working fine.
            I ordered a new screen, an AU Optronics 14.1" 30pin Matte LCD Screen B141XG09. I disassembled the laptop to prepare for the screen swap. When the screen showed up, the white plug was not the right kind to fit into my inverter. So I...
            01-10-2021, 05:37 PM
          • Dannyx
            "Kinetic" 433Mhz transmitter/receiver discussion
            by Dannyx
            Good day folks.
            TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
            Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
            03-08-2022, 11:01 AM
          • szreder6
            HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
            by szreder6
            Hello guys,
            I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
            What I did:
            - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
            As far as I know the laptop was in another service center...
            11-22-2024, 05:17 PM
          • chth96
            What is name of IC which is written "601Km" on its surface?
            by chth96
            Hello.
            I have T12-952 soldering station which is not able to display any screen But When I power on it, iron become hot.
            I desolder some components to check whether it have been faulty or not, But When I tried to desolder an IC Which is written "601Km" on the surface,I broke leftmost pin like attached photos.
            I use Mini Drill in order to peel off plastic suface but I cannot found copper sheet which is supposed to be pin3.
            What is name of IC which is written "601Km" on the surface?
            and Is there any...
            09-28-2024, 11:19 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
