Where can I find a USB C charging controller board that will select the right chargin
    • Jul 2011
    • 6033
    I have some new devices that have the USB C protocol but I have not found a charger that will recognize which power level to use because I also do not have a USB C load tester that would recognize the different type of devices used
    Is there anyone on this forum that can help with this because I am not sure how or what to Google to find this information
    • 30979
    Re: Where can I find a USB C charging controller board that will select the right cha
    what are you actually looking for, a meter or a psu with PD3.0 protocol?
      • Jul 2011
      • 6033
      Both
        "usb-c pd load tester" search.
        May be looking at these:
        https://www.digikey.com/en/products/...4533/10238329?
        https://www.showmecables.com/klein-t...b-a-and-usb-c?
        https://www.youtube.com/watch?v=ID6RAlUDqx8
          • 30979
          https://rdtech.aliexpress.com/store/...2722606aloiHe5
          • master3112
            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
            by master3112
            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
            10-29-2024, 09:32 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • Spikeman
            Dell Precision 3440 support for CPU 11th gen
            by Spikeman
            Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
            I ask you if it is possible to add the correct microcodes for the Precision 3440.
            I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
            Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
            03-11-2025, 09:54 AM
          • ronnygracias
            Help with freemotion incline trainer with controller comm error
            by ronnygracias
            The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
            11-04-2024, 01:32 PM
            Tankless hot water heater controller board not powering up when power is applied
            I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
            I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
            However I would like to know if I could figure what happened to this controller board if possible
            Tomorrow I will take some better pictures of both side of both boards
            The...
            12-09-2022, 09:14 PM
